Internal flash memory
saranbabu
Hello team,
I'm using MIMXRT1064 processor and I'm very new to this processor as well.  By using the SDK example of flexspi_nor_internal_polling_transfer I can perform write and read from the internal flash memory.  Please find my following questions,
1) Why I cannot read the internal flash memory using flexspi_nor_read_data api?
2) I can read data using memcpy function how?
Please clarify my doubts.
saranbabu
Hello team,
Still I'm having doubt in read the internal flash memory using memcpy api, please clarify my doubt.
How to access the internal flash memory using IP command?
Please list out some difference between the IP and AHB command?
jeremyzhou
Thanks for your reply.
To provide the fastest support, please refer to the Flash access by IP command and Flash access by AHB Command sections in the RM to learn the difference between the IP and AHB commands.
TIC
jeremyzhou
Hi @saranbabu ,
Thank you for your interest in NXP Semiconductor products and for the opportunity to serve you.
To enable the operations of the internal Flash, please refer to the tutorial to make it.
TIC
