Installing Ltib
Installing Ltib
3,490 次查看
Mr_GustavoCosta
I'm trying to install Ltib in linux 2.6.35.3 in Ubuntu 9.10 and after I ran successfully "./ltib/install" I try to run ./ltib but this error had occurred.
   distak-pc@distak-pc:~/iMX51/linux-2.6.35.3/ltib$ ./ltib
   Installing host support packages.
   This only needs to be done once per host, but may take up to
   an hour to complete ...
   If an error occurs, a log file with the full output may be found in:
   /home/distak-pc/iMX51/linux-2.6.35.3/ltib/host_config.log
   Exiting on error or interrupt
   Please see >> /home/distak-pc/iMX51/linux-2.6.35.3/ltib/host_config.log for details
What should I do now?
Follows the  host_config.log.
Build path taken because: no prebuilt rpm,
rpmbuild --dbpath ///opt/freescale/ltib/var/lib/rpm --target i686 --define '_unpackaged_files_terminate_build 0' --define '_target_cpu i686' --define '__strip strip' --define '_topdir /opt/freescale/ltib/usr/src/rpm' --define '_prefix /opt/freescale/ltib/usr' --define '_tmppath /home/distak-pc/iMX51/linux-2.6.35.3/ltib/tmp' --define '_rpmdir /opt/freescale/ltib/usr/src/rpm/RPMS'  --define '_mandir /opt/freescale/ltib/usr/share/man' --define '_sysconfdir /opt/freescale/ltib/etc' --define '_localstatedir /var' -bb --clean --rmsource  /home/distak-pc/iMX51/linux-2.6.35.3/ltib/dist/lfs-5.1/mtd-utils/mtd-utils.spec
Building target platforms: i686
Building for target i686
Executing(%prep): /bin/sh -e /home/distak-pc/iMX51/linux-2.6.35.3/ltib/tmp/rpm-tmp.11178
+ umask 022
+ cd /opt/freescale/ltib/usr/src/rpm/BUILD
+ rm -rf mtd-utils
+ /bin/bzip2 -dc /opt/freescale/ltib/usr/src/rpm/SOURCES/mtd-utils-201006.tar.bz2
+ tar -xvvf -
tar: Record size = 8 blocks
drwxr-x--- r65388/s2101      0 2010-01-15 14:12 mtd-utils/
-rw-r----- r65388/s2101   1418 2010-01-15 14:12 mtd-utils/flash_unlock.c
-rw-r----- r65388/s2101   7788 2010-01-15 14:12 mtd-utils/nftldump.c
drwxr-x--- r65388/s2101      0 2010-01-15 14:12 mtd-utils/mkfs.ubifs/
-rw-r----- r65388/s2101     12 2010-01-15 14:12 mtd-utils/mkfs.ubifs/.gitignore
-rw-r----- r65388/s2101  15842 2010-01-15 14:12 mtd-utils/mkfs.ubifs/lpt.c
-rw-r----- r65388/s2101   5378 2010-01-15 14:12 mtd-utils/mkfs.ubifs/crc32.c
-rw-r----- r65388/s2101   4454 2010-01-15 14:12 mtd-utils/mkfs.ubifs/mkfs.ubifs.h
-rw-r----- r65388/s2101   5078 2010-01-15 14:12 mtd-utils/mkfs.ubifs/key.h
-rw-r----- r65388/s2101  14732 2010-01-15 14:12 mtd-utils/mkfs.ubifs/devtable.c
-rw-r----- r65388/s2101    599 2010-01-15 14:12 mtd-utils/mkfs.ubifs/crc16.h
-rw-r----- r65388/s2101    608 2010-01-15 14:12 mtd-utils/mkfs.ubifs/README
-rw-r----- r65388/s2101  61496 2010-01-15 14:12 mtd-utils/mkfs.ubifs/mkfs.ubifs.c
-rw-r----- r65388/s2101   1437 2010-01-15 14:12 mtd-utils/mkfs.ubifs/compr.h
-rw-r----- r65388/s2101  18007 2010-01-15 14:12 mtd-utils/mkfs.ubifs/COPYING
-rw-r----- r65388/s2101    679 2010-01-15 14:12 mtd-utils/mkfs.ubifs/Makefile
-rw-r----- r65388/s2101    467 2010-01-15 14:12 mtd-utils/mkfs.ubifs/crc32.h
-rw-r----- r65388/s2101  21934 2010-01-15 14:12 mtd-utils/mkfs.ubifs/ubifs-media.h
-rw-r----- r65388/s2101   1990 2010-01-15 14:12 mtd-utils/mkfs.ubifs/defs.h
drwxr-x--- r65388/s2101      0 2010-01-15 14:12 mtd-utils/mkfs.ubifs/hashtable/
-rw-r----- r65388/s2101   4092 2010-01-15 14:12 mtd-utils/mkfs.ubifs/hashtable/hashtable_itr.h
-rw-r----- r65388/s2101   9031 2010-01-15 14:12 mtd-utils/mkfs.ubifs/hashtable/hashtable.c
-rw-r----- r65388/s2101   2961 2010-01-15 14:12 mtd-utils/mkfs.ubifs/hashtable/hashtable_private.h
-rw-r----- r65388/s2101   5789 2010-01-15 14:12 mtd-utils/mkfs.ubifs/hashtable/hashtable_itr.c
-rw-r----- r65388/s2101   7401 2010-01-15 14:12 mtd-utils/mkfs.ubifs/hashtable/hashtable.h
-rw-r----- r65388/s2101   2618 2010-01-15 14:12 mtd-utils/mkfs.ubifs/crc16.c
-rw-r----- r65388/s2101    980 2010-01-15 14:12 mtd-utils/mkfs.ubifs/lpt.h
-rw-r----- r65388/s2101   4639 2010-01-15 14:12 mtd-utils/mkfs.ubifs/compr.c
-rw-r----- r65388/s2101  11457 2010-01-15 14:12 mtd-utils/mkfs.ubifs/ubifs.h
drwxr-x--- r65388/s2101      0 2010-01-15 14:12 mtd-utils/ubi-utils/
-rw-r----- r65388/s2101    124 2010-01-15 14:12 mtd-utils/ubi-utils/.gitignore
drwxr-x--- r65388/s2101      0 2010-01-15 14:12 mtd-utils/ubi-utils/src/
-rw-r----- r65388/s2101   5378 2010-01-15 14:12 mtd-utils/ubi-utils/src/crc32.c
-rw-r----- r65388/s2101  24406 2010-01-15 14:12 mtd-utils/ubi-utils/src/ubiformat.c
-rw-r----- r65388/s2101   6589 2010-01-15 14:12 mtd-utils/ubi-utils/src/dictionary.h
-rw-r----- r65388/s2101  10409 2010-01-15 14:12 mtd-utils/ubi-utils/src/libubigen.c
-rw-r----- r65388/s2101   3038 2010-01-15 14:12 mtd-utils/ubi-utils/src/common.h
-rw-r----- r65388/s2101  20096 2010-01-15 14:12 mtd-utils/ubi-utils/src/ubinize.c
-rw-r----- r65388/s2101   5883 2010-01-15 14:12 mtd-utils/ubi-utils/src/ubiattach.c
-rw-r----- r65388/s2101  28157 2010-01-15 14:12 mtd-utils/ubi-utils/src/libubi.c
-rw-r----- r65388/s2101   8628 2010-01-15 14:12 mtd-utils/ubi-utils/src/mtdinfo.c
-rw-r----- r65388/s2101   2873 2010-01-15 14:12 mtd-utils/ubi-utils/src/ubicrc32.c
-rw-r----- r65388/s2101   5180 2010-01-15 14:12 mtd-utils/ubi-utils/src/ubirmvol.c
-rw-r----- r65388/s2101    358 2010-01-15 14:12 mtd-utils/ubi-utils/src/crc32.h
-rw-r----- r65388/s2101   4031 2010-01-15 14:12 mtd-utils/ubi-utils/src/ubirename.c
-rw-r----- r65388/s2101   7371 2010-01-15 14:12 mtd-utils/ubi-utils/src/ubiupdatevol.c
-rw-r----- r65388/s2101   8405 2010-01-15 14:12 mtd-utils/ubi-utils/src/ubimkvol.c
-rw-r----- r65388/s2101  24434 2010-01-15 14:12 mtd-utils/ubi-utils/src/libmtd.c
-rw-r----- r65388/s2101  20010 2010-01-15 14:12 mtd-utils/ubi-utils/src/libiniparser.c
-rw-r----- r65388/s2101  11445 2010-01-15 14:12 mtd-utils/ubi-utils/src/dictionary.c
-rw-r----- r65388/s2101   4258 2010-01-15 14:12 mtd-utils/ubi-utils/src/libubi_int.h
-rw-r----- r65388/s2101   8694 2010-01-15 14:12 mtd-utils/ubi-utils/src/libmtd_legacy.c
-rw-r----- r65388/s2101  10994 2010-01-15 14:12 mtd-utils/ubi-utils/src/ubinfo.c
-rw-r----- r65388/s2101   4986 2010-01-15 14:12 mtd-utils/ubi-utils/src/common.c
-rw-r----- r65388/s2101   5572 2010-01-15 14:12 mtd-utils/ubi-utils/src/libscan.c
-rw-r----- r65388/s2101   4873 2010-01-15 14:12 mtd-utils/ubi-utils/src/ubidetach.c
-rw-r----- r65388/s2101   2668 2010-01-15 14:12 mtd-utils/ubi-utils/src/libmtd_int.h
-rw-r----- r65388/s2101   6380 2010-01-15 14:12 mtd-utils/ubi-utils/src/ubirsvol.c
-rw-r----- r65388/s2101   1712 2010-01-15 14:12 mtd-utils/ubi-utils/Makefile
-rw-r----- r65388/s2101   1083 2010-01-15 14:12 mtd-utils/ubi-utils/LICENSE.libiniparser
drwxr-x--- r65388/s2101      0 2010-01-15 14:12 mtd-utils/ubi-utils/old-utils/
-rw-r----- r65388/s2101     90 2010-01-15 14:12 mtd-utils/ubi-utils/old-utils/.gitignore
drwxr-x--- r65388/s2101      0 2010-01-15 14:12 mtd-utils/ubi-utils/old-utils/scripts/
-rw-r----- r65388/s2101   1662 2010-01-15 14:12 mtd-utils/ubi-utils/old-utils/scripts/inject_biterror.pl
-rwxr-x--- r65388/s2101   2053 2010-01-15 14:12 mtd-utils/ubi-utils/old-utils/scripts/run_all.sh
-rw-r----- r65388/s2101   3519 2010-01-15 14:12 mtd-utils/ubi-utils/old-utils/scripts/unubi_test.sh
-rw-r----- r65388/s2101   3938 2010-01-15 14:12 mtd-utils/ubi-utils/old-utils/scripts/bin2nand2bin_test.sh
-rwxr-x--- r65388/s2101   2117 2010-01-15 14:12 mtd-utils/ubi-utils/old-utils/scripts/jffs2_test.sh
-rw-r----- r65388/s2101    266 2010-01-15 14:12 mtd-utils/ubi-utils/old-utils/scripts/README
-rwxr-x--- r65388/s2101    663 2010-01-15 14:12 mtd-utils/ubi-utils/old-utils/scripts/mkdevs.pl
-rw-r----- r65388/s2101   1600 2010-01-15 14:12 mtd-utils/ubi-utils/old-utils/scripts/Makefile
-rwxr-x--- r65388/s2101   5858 2010-01-15 14:12 mtd-utils/ubi-utils/old-utils/scripts/ubi_tools_test.sh
-rw-r----- r65388/s2101    380 2010-01-15 14:12 mtd-utils/ubi-utils/old-utils/scripts/test.cfg
-rw-r----- r65388/s2101    100 2010-01-15 14:12 mtd-utils/ubi-utils/old-utils/scripts/TODO
-rw-r----- r65388/s2101    517 2010-01-15 14:12 mtd-utils/ubi-utils/old-utils/scripts/pdd.txt
-rwxr-x--- r65388/s2101   7870 2010-01-15 14:12 mtd-utils/ubi-utils/old-utils/scripts/ubi_test.sh
-rwxr-x--- r65388/s2101   9197 2010-01-15 14:12 mtd-utils/ubi-utils/old-utils/scripts/ubi_jffs2_test.sh
-rw-r----- r65388/s2101    413 2010-01-15 14:12 mtd-utils/ubi-utils/old-utils/testcases.txt
-rw-r----- r65388/s2101   4599 2010-01-15 14:12 mtd-utils/ubi-utils/old-utils/UBI.TXT
drwxr-x--- r65388/s2101      0 2010-01-15 14:12 mtd-utils/ubi-utils/old-utils/src/
-rw-r----- r65388/s2101   2333 2010-01-15 14:12 mtd-utils/ubi-utils/old-utils/src/list.c
-rw-r----- r65388/s2101   4410 2010-01-15 14:12 mtd-utils/ubi-utils/old-utils/src/error.c
-rw-r----- r65388/s2101   7371 2010-01-15 14:12 mtd-utils/ubi-utils/old-utils/src/pfi.h
-rw-r----- r65388/s2101   2688 2010-01-15 14:12 mtd-utils/ubi-utils/old-utils/src/unubi_analyze.h
-rw-r----- r65388/s2101   2152 2010-01-15 14:12 mtd-utils/ubi-utils/old-utils/src/crc32.c
-rw-r----- r65388/s2101  11041 2010-01-15 14:12 mtd-utils/ubi-utils/old-utils/src/libubigen.c
-rw-r----- r65388/s2101  31016 2010-01-15 14:12 mtd-utils/ubi-utils/old-utils/src/libpfiflash.c
-rw-r----- r65388/s2101  10464 2010-01-15 14:12 mtd-utils/ubi-utils/old-utils/src/reader.c
-rw-r----- r65388/s2101  10969 2010-01-15 14:12 mtd-utils/ubi-utils/old-utils/src/pddcustomize.c
-rw-r----- r65388/s2101   8132 2010-01-15 14:12 mtd-utils/ubi-utils/old-utils/src/bin2nand.c
-rw-r----- r65388/s2101  19720 2010-01-15 14:12 mtd-utils/ubi-utils/old-utils/src/libubi.c
-rw-r----- r65388/s2101   1771 2010-01-15 14:12 mtd-utils/ubi-utils/old-utils/src/list.h
-rw-r----- r65388/s2101   2260 2010-01-15 14:12 mtd-utils/ubi-utils/old-utils/src/error.h
-rw-r----- r65388/s2101  24475 2010-01-15 14:12 mtd-utils/ubi-utils/old-utils/src/unubi.c
-rw-r----- r65388/s2101   7011 2010-01-15 14:12 mtd-utils/ubi-utils/old-utils/src/pfiflash.c
-rw-r----- r65388/s2101   1020 2010-01-15 14:12 mtd-utils/ubi-utils/old-utils/src/nandecc.h
-rw-r----- r65388/s2101   2280 2010-01-15 14:12 mtd-utils/ubi-utils/old-utils/src/pfiflash.h
-rw-r----- r65388/s2101   1213 2010-01-15 14:12 mtd-utils/ubi-utils/old-utils/src/crc32.h
-rw-r----- r65388/s2101  10013 2010-01-15 14:12 mtd-utils/ubi-utils/old-utils/src/pfi.c
-rw-r----- r65388/s2101  12422 2010-01-15 14:12 mtd-utils/ubi-utils/old-utils/src/bootenv.h
-rw-r----- r65388/s2101   5056 2010-01-15 14:12 mtd-utils/ubi-utils/old-utils/src/nandecc.c
-rw-r----- r65388/s2101    987 2010-01-15 14:12 mtd-utils/ubi-utils/old-utils/src/example_ubi.h
-rw-r----- r65388/s2101    994 2010-01-15 14:12 mtd-utils/ubi-utils/old-utils/src/config.h
-rw-r----- r65388/s2101  11340 2010-01-15 14:12 mtd-utils/ubi-utils/old-utils/src/unubi_analyze.c
-rw-r----- r65388/s2101   9720 2010-01-15 14:12 mtd-utils/ubi-utils/old-utils/src/ubigen.c
-rw-r----- r65388/s2101  12118 2010-01-15 14:12 mtd-utils/ubi-utils/old-utils/src/nand2bin.c
-rw-r----- r65388/s2101   4657 2010-01-15 14:12 mtd-utils/ubi-utils/old-utils/src/libubi_int.h
-rw-r----- r65388/s2101   5594 2010-01-15 14:12 mtd-utils/ubi-utils/old-utils/src/libubimirror.c
-rw-r----- r65388/s2101   7030 2010-01-15 14:12 mtd-utils/ubi-utils/old-utils/src/hashmap.c
-rw-r----- r65388/s2101  19507 2010-01-15 14:12 mtd-utils/ubi-utils/old-utils/src/bootenv.c
-rw-r----- r65388/s2101   5077 2010-01-15 14:12 mtd-utils/ubi-utils/old-utils/src/ubimirror.c
-rw-r----- r65388/s2101   1755 2010-01-15 14:12 mtd-utils/ubi-utils/old-utils/src/hashmap.h
-rw-r----- r65388/s2101   4379 2010-01-15 14:12 mtd-utils/ubi-utils/old-utils/src/ubigen.h
-rw-r----- r65388/s2101   4135 2010-01-15 14:12 mtd-utils/ubi-utils/old-utils/src/mkbootenv.c
-rw-r----- r65388/s2101   2438 2010-01-15 14:12 mtd-utils/ubi-utils/old-utils/src/reader.h
-rw-r----- r65388/s2101   2331 2010-01-15 14:12 mtd-utils/ubi-utils/old-utils/src/ubimirror.h
-rw-r----- r65388/s2101  15488 2010-01-15 14:12 mtd-utils/ubi-utils/old-utils/src/pfi2bin.c
-rw-r----- r65388/s2101   1353 2010-01-15 14:12 mtd-utils/ubi-utils/old-utils/src/peb.h
-rw-r----- r65388/s2101   6720 2010-01-15 14:12 mtd-utils/ubi-utils/old-utils/src/eb_chain.c
-rw-r----- r65388/s2101   2256 2010-01-15 14:12 mtd-utils/ubi-utils/old-utils/src/pfiflash_error.h
-rw-r----- r65388/s2101   2420 2010-01-15 14:12 mtd-utils/ubi-utils/old-utils/src/nandcorr.c
-rw-r----- r65388/s2101   2175 2010-01-15 14:12 mtd-utils/ubi-utils/old-utils/src/peb.c
drwxr-x--- r65388/s2101      0 2010-01-15 14:12 mtd-utils/ubi-utils/old-utils/perl/
-rw-r----- r65388/s2101    607 2010-01-15 14:12 mtd-utils/ubi-utils/old-utils/perl/f64_nor_sample.cfg
-rwxr-x--- r65388/s2101   1372 2010-01-15 14:12 mtd-utils/ubi-utils/old-utils/perl/ubicrc32.pl
-rwxr-x--- r65388/s2101  16982 2010-01-15 14:12 mtd-utils/ubi-utils/old-utils/perl/mkpfi
-rw-r----- r65388/s2101    578 2010-01-15 14:12 mtd-utils/ubi-utils/old-utils/perl/f128_nand_sample.cfg
-rw-r----- r65388/s2101   8112 2010-01-15 14:12 mtd-utils/ubi-utils/old-utils/README
drwxr-x--- r65388/s2101      0 2010-01-15 14:12 mtd-utils/ubi-utils/old-utils/inc/
-rw-r----- r65388/s2101   8010 2010-01-15 14:12 mtd-utils/ubi-utils/old-utils/inc/libubi.h
-rw-r----- r65388/s2101   1602 2010-01-15 14:12 mtd-utils/ubi-utils/old-utils/Makefile
drwxr-x--- r65388/s2101      0 2010-01-15 14:12 mtd-utils/ubi-utils/old-utils/doc/
-rw-r----- r65388/s2101   5241 2010-01-15 14:12 mtd-utils/ubi-utils/old-utils/doc/unubi.roff
drwxr-x--- r65388/s2101      0 2010-01-15 14:12 mtd-utils/ubi-utils/old-utils/lib/
-rw-r----- r65388/s2101   2090 2010-01-15 14:12 mtd-utils/ubi-utils/old-utils/lib/Makefile.am
drwxr-x--- r65388/s2101      0 2010-01-15 14:12 mtd-utils/ubi-utils/include/
-rw-r----- r65388/s2101  10270 2010-01-15 14:12 mtd-utils/ubi-utils/include/libiniparser.h
-rw-r----- r65388/s2101   3509 2010-01-15 14:12 mtd-utils/ubi-utils/include/libubigen.h
-rw-r----- r65388/s2101   3156 2010-01-15 14:12 mtd-utils/ubi-utils/include/libscan.h
-rw-r----- r65388/s2101   7247 2010-01-15 14:12 mtd-utils/ubi-utils/include/libmtd.h
-rw-r----- r65388/s2101  14786 2010-01-15 14:12 mtd-utils/ubi-utils/include/libubi.h
-rw-r----- r65388/s2101    657 2010-01-15 14:12 mtd-utils/.gitignore
-rw-r----- r65388/s2101   7400 2010-01-15 14:12 mtd-utils/flash_eraseall.c
-rw-r----- r65388/s2101   6676 2010-01-15 14:12 mtd-utils/mkfs.jffs2.1
-rw-r----- r65388/s2101   3264 2010-01-15 14:12 mtd-utils/doc_loadbios.c
-rw-r----- r65388/s2101  17841 2010-01-15 14:12 mtd-utils/nandwrite.c
-rw-r----- r65388/s2101   5378 2010-01-15 14:12 mtd-utils/crc32.c
drwxr-x--- r65388/s2101      0 2010-01-15 14:12 mtd-utils/tests/
drwxr-x--- r65388/s2101      0 2010-01-15 14:12 mtd-utils/tests/ubi-tests/
-rw-r----- r65388/s2101   2484 2010-01-15 14:12 mtd-utils/tests/ubi-tests/mkvol_paral.c
-rw-r----- r65388/s2101   4265 2010-01-15 14:12 mtd-utils/tests/ubi-tests/io_basic.c
-rwxr-x--- r65388/s2101    616 2010-01-15 14:12 mtd-utils/tests/ubi-tests/runtests.sh
-rw-r----- r65388/s2101    102 2010-01-15 14:12 mtd-utils/tests/ubi-tests/.gitignore
-rw-r----- r65388/s2101   4292 2010-01-15 14:12 mtd-utils/tests/ubi-tests/common.h
-rw-r----- r65388/s2101  19260 2010-01-15 14:12 mtd-utils/tests/ubi-tests/integ.c
-rw-r----- r65388/s2101   6536 2010-01-15 14:12 mtd-utils/tests/ubi-tests/rsvol.c
-rw-r----- r65388/s2101   7104 2010-01-15 14:12 mtd-utils/tests/ubi-tests/io_update.c
-rw-r----- r65388/s2101    818 2010-01-15 14:12 mtd-utils/tests/ubi-tests/Makefile
-rw-r----- r65388/s2101   8619 2010-01-15 14:12 mtd-utils/tests/ubi-tests/io_read.c
-rw-r----- r65388/s2101   7434 2010-01-15 14:12 mtd-utils/tests/ubi-tests/io_paral.c
-rw-r----- r65388/s2101   3023 2010-01-15 14:12 mtd-utils/tests/ubi-tests/volrefcnt.c
-rw-r----- r65388/s2101   5446 2010-01-15 14:12 mtd-utils/tests/ubi-tests/mkvol_basic.c
-rw-r----- r65388/s2101   7349 2010-01-15 14:12 mtd-utils/tests/ubi-tests/mkvol_bad.c
-rw-r----- r65388/s2101   8221 2010-01-15 14:12 mtd-utils/tests/ubi-tests/common.c
-rw-r----- r65388/s2101   1253 2010-01-15 14:12 mtd-utils/tests/ubi-tests/README.udev
drwxr-x--- r65388/s2101      0 2010-01-15 14:12 mtd-utils/tests/jittertest/
-rw-r----- r65388/s2101  34580 2010-01-15 14:12 mtd-utils/tests/jittertest/JitterTest.c
-rw-r----- r65388/s2101   6736 2010-01-15 14:12 mtd-utils/tests/jittertest/README
-rw-r----- r65388/s2101  18007 2010-01-15 14:12 mtd-utils/tests/jittertest/COPYING
-rw-r----- r65388/s2101   1788 2010-01-15 14:12 mtd-utils/tests/jittertest/Makefile
-rw-r----- r65388/s2101    251 2010-01-15 14:12 mtd-utils/tests/jittertest/filljffs2.sh
-rw-r----- r65388/s2101  10267 2010-01-15 14:12 mtd-utils/tests/jittertest/plotJittervsFill.c
drwxr-x--- r65388/s2101      0 2010-01-15 14:12 mtd-utils/tests/checkfs/
-rw-r----- r65388/s2101    216 2010-01-15 14:12 mtd-utils/tests/checkfs/common.h
-rw-r----- r65388/s2101   7002 2010-01-15 14:12 mtd-utils/tests/checkfs/README
-rw-r----- r65388/s2101    291 2010-01-15 14:12 mtd-utils/tests/checkfs/Makefile
-rw-r----- r65388/s2101  21769 2010-01-15 14:12 mtd-utils/tests/checkfs/checkfs.c
-rw-r----- r65388/s2101   1181 2010-01-15 14:12 mtd-utils/tests/checkfs/comm.c
-rw-r----- r65388/s2101   8520 2010-01-15 14:12 mtd-utils/tests/checkfs/makefiles.c
drwxr-x--- r65388/s2101      0 2010-01-15 14:12 mtd-utils/tests/fs-tests/
drwxr-x--- r65388/s2101      0 2010-01-15 14:12 mtd-utils/tests/fs-tests/utils/
-rw-r----- r65388/s2101   1510 2010-01-15 14:12 mtd-utils/tests/fs-tests/utils/free_space.c
-rw-r----- r65388/s2101    250 2010-01-15 14:12 mtd-utils/tests/fs-tests/utils/Makefile
-rw-r----- r65388/s2101   5272 2010-01-15 14:12 mtd-utils/tests/fs-tests/utils/fstest_monitor.c
-rwxr-x--- r65388/s2101    717 2010-01-15 14:12 mtd-utils/tests/fs-tests/run_all.sh
drwxr-x--- r65388/s2101      0 2010-01-15 14:12 mtd-utils/tests/fs-tests/stress/
-rw-r----- r65388/s2101    150 2010-01-15 14:12 mtd-utils/tests/fs-tests/stress/Makefile
-rwxr-x--- r65388/s2101    644 2010-01-15 14:12 mtd-utils/tests/fs-tests/stress/stress01.sh
-rwxr-x--- r65388/s2101   1124 2010-01-15 14:12 mtd-utils/tests/fs-tests/stress/stress00.sh
drwxr-x--- r65388/s2101      0 2010-01-15 14:12 mtd-utils/tests/fs-tests/stress/atoms/
-rw-r----- r65388/s2101   3129 2010-01-15 14:12 mtd-utils/tests/fs-tests/stress/atoms/stress_3.c
-rw-r----- r65388/s2101   3011 2010-01-15 14:12 mtd-utils/tests/fs-tests/stress/atoms/stress_2.c
-rw-r----- r65388/s2101   5281 2010-01-15 14:12 mtd-utils/tests/fs-tests/stress/atoms/rndwrite00.c
-rw-r----- r65388/s2101   5322 2010-01-15 14:12 mtd-utils/tests/fs-tests/stress/atoms/gcd_hupper.c
-rw-r----- r65388/s2101   5820 2010-01-15 14:12 mtd-utils/tests/fs-tests/stress/atoms/fwrite00.c
-rw-r----- r65388/s2101   3609 2010-01-15 14:12 mtd-utils/tests/fs-tests/stress/atoms/pdfrun.c
-rw-r----- r65388/s2101    511 2010-01-15 14:12 mtd-utils/tests/fs-tests/stress/atoms/Makefile
-rw-r----- r65388/s2101   3692 2010-01-15 14:12 mtd-utils/tests/fs-tests/stress/atoms/rmdir00.c
-rw-r----- r65388/s2101  10320 2010-01-15 14:12 mtd-utils/tests/fs-tests/stress/atoms/rndrm99.c
-rw-r----- r65388/s2101   2655 2010-01-15 14:12 mtd-utils/tests/fs-tests/stress/atoms/stress_1.c
-rw-r----- r65388/s2101   4329 2010-01-15 14:12 mtd-utils/tests/fs-tests/stress/atoms/rndrm00.c
-rw-r----- r65388/s2101    137 2010-01-15 14:12 mtd-utils/tests/fs-tests/Makefile
-rwxr-x--- r65388/s2101   1420 2010-01-15 14:12 mtd-utils/tests/fs-tests/help_all.sh
drwxr-x--- r65388/s2101      0 2010-01-15 14:12 mtd-utils/tests/fs-tests/simple/
-rw-r----- r65388/s2101   4330 2010-01-15 14:12 mtd-utils/tests/fs-tests/simple/test_1.c
-rw-r----- r65388/s2101    350 2010-01-15 14:12 mtd-utils/tests/fs-tests/simple/Makefile
-rw-r----- r65388/s2101   6356 2010-01-15 14:12 mtd-utils/tests/fs-tests/simple/test_2.c
-rw-r----- r65388/s2101   5069 2010-01-15 14:12 mtd-utils/tests/fs-tests/simple/perf.c
-rw-r----- r65388/s2101   2668 2010-01-15 14:12 mtd-utils/tests/fs-tests/simple/ftrunc.c
-rw-r----- r65388/s2101   4633 2010-01-15 14:12 mtd-utils/tests/fs-tests/simple/orph.c
drwxr-x--- r65388/s2101      0 2010-01-15 14:12 mtd-utils/tests/fs-tests/lib/
-rw-r----- r65388/s2101    166 2010-01-15 14:12 mtd-utils/tests/fs-tests/lib/Makefile
-rw-r----- r65388/s2101   7328 2010-01-15 14:12 mtd-utils/tests/fs-tests/lib/tests.h
-rw-r----- r65388/s2101  28463 2010-01-15 14:12 mtd-utils/tests/fs-tests/lib/tests.c
drwxr-x--- r65388/s2101      0 2010-01-15 14:12 mtd-utils/tests/fs-tests/integrity/
-rw-r----- r65388/s2101  46654 2010-01-15 14:12 mtd-utils/tests/fs-tests/integrity/integck.c
-rw-r----- r65388/s2101    259 2010-01-15 14:12 mtd-utils/tests/fs-tests/integrity/Makefile
-rw-r----- r65388/s2101   6027 2010-01-15 14:12 mtd-utils/nandtest.c
-rw-r----- r65388/s2101   3894 2010-01-15 14:12 mtd-utils/compr_zlib.c
-rw-r----- r65388/s2101   4247 2010-01-15 14:12 mtd-utils/device_table.txt
-rw-r----- r65388/s2101    366 2010-01-15 14:12 mtd-utils/feature-removal-schedule.txt
-rw-r----- r65388/s2101   2957 2010-01-15 14:12 mtd-utils/compr_lzo.c
-rw-r----- r65388/s2101   3388 2010-01-15 14:12 mtd-utils/rfdformat.c
-rw-r----- r65388/s2101   3363 2010-01-15 14:12 mtd-utils/compr.h
-rw-r----- r65388/s2101   1772 2010-01-15 14:12 mtd-utils/common.mk
-rw-r----- r65388/s2101   9520 2010-01-15 14:12 mtd-utils/mtd_debug.c
-rw-r----- r65388/s2101  18007 2010-01-15 14:12 mtd-utils/COPYING
-rw-r----- r65388/s2101   4860 2010-01-15 14:12 mtd-utils/summary.h
-rw-r----- r65388/s2101   1728 2010-01-15 14:12 mtd-utils/Makefile
-rw-r----- r65388/s2101   5173 2010-01-15 14:12 mtd-utils/rbtree.h
-rw-r----- r65388/s2101    352 2010-01-15 14:12 mtd-utils/crc32.h
-rw-r----- r65388/s2101   3687 2010-01-15 14:12 mtd-utils/flash_erase.c
-rw-r----- r65388/s2101  21151 2010-01-15 14:12 mtd-utils/jffs2reader.c
-rw-r----- r65388/s2101   2661 2010-01-15 14:12 mtd-utils/compr_rtime.c
-rw-r----- r65388/s2101   1780 2010-01-15 14:12 mtd-utils/flash_lock.c
-rw-r----- r65388/s2101  22200 2010-01-15 14:12 mtd-utils/jffs2dump.c
-rw-r----- r65388/s2101   8869 2010-01-15 14:12 mtd-utils/docfdisk.c
-rw-r----- r65388/s2101   9445 2010-01-15 14:12 mtd-utils/ftl_format.c
-rw-r----- r65388/s2101   1041 2010-01-15 14:12 mtd-utils/flash_otp_dump.c
-rw-r----- r65388/s2101  27082 2010-01-15 14:12 mtd-utils/sumtool.c
-rw-r----- r65388/s2101  14808 2010-01-15 14:12 mtd-utils/recv_image.c
-rw-r----- r65388/s2101  10786 2010-01-15 14:12 mtd-utils/nanddump.c
-rw-r----- r65388/s2101   6536 2010-01-15 14:12 mtd-utils/ftl_check.c
-rw-r----- r65388/s2101   1264 2010-01-15 14:12 mtd-utils/flash_otp_info.c
-rw-r----- r65388/s2101  12402 2010-01-15 14:12 mtd-utils/nftl_format.c
-rw-r----- r65388/s2101   1539 2010-01-15 14:12 mtd-utils/mcast_image.h
-rw-r----- r65388/s2101   7811 2010-01-15 14:12 mtd-utils/serve_image.c
-rw-r----- r65388/s2101   8641 2010-01-15 14:12 mtd-utils/jffs-dump.c
-rwxr-x--- r65388/s2101   4309 2010-01-15 14:12 mtd-utils/load_nandsim.sh
-rwxr-x--- r65388/s2101    786 2010-01-15 14:12 mtd-utils/MAKEDEV
-rw-r----- r65388/s2101    727 2010-01-15 14:12 mtd-utils/mtd-utils.spec
-rw-r----- r65388/s2101  14734 2010-01-15 14:12 mtd-utils/compr.c
-rw-r----- r65388/s2101   1047 2010-01-15 14:12 mtd-utils/flash_info.c
-rw-r----- r65388/s2101   1969 2010-01-15 14:12 mtd-utils/flash_otp_write.c
-rw-r----- r65388/s2101   8624 2010-01-15 14:12 mtd-utils/rbtree.c
-rw-r----- r65388/s2101   1980 2010-01-15 14:12 mtd-utils/fectest.c
-rw-r----- r65388/s2101   1534 2010-01-15 14:12 mtd-utils/flash_otp_lock.c
-rw-r----- r65388/s2101  10932 2010-01-15 14:12 mtd-utils/flashcp.c
-rw-r----- r65388/s2101   7281 2010-01-15 14:12 mtd-utils/rfddump.c
drwxr-x--- r65388/s2101      0 2010-01-15 14:12 mtd-utils/include/
drwxr-x--- r65388/s2101      0 2010-01-15 14:12 mtd-utils/include/linux/
-rw-r----- r65388/s2101   7034 2010-01-15 14:12 mtd-utils/include/linux/jffs2.h
-rw-r----- r65388/s2101   1903 2010-01-15 14:12 mtd-utils/include/mtd_swab.h
drwxr-x--- r65388/s2101      0 2010-01-15 14:12 mtd-utils/include/mtd/
-rw-r----- r65388/s2101   2646 2010-01-15 14:12 mtd-utils/include/mtd/ftl-user.h
-rw-r----- r65388/s2101   2371 2010-01-15 14:12 mtd-utils/include/mtd/jffs2-user.h
-rw-r----- r65388/s2101  15492 2010-01-15 14:12 mtd-utils/include/mtd/ubi-user.h
-rw-r----- r65388/s2101  16929 2010-01-15 14:12 mtd-utils/include/mtd/ubi-media.h
-rw-r----- r65388/s2101   4356 2010-01-15 14:12 mtd-utils/include/mtd/mtd-abi.h
-rw-r----- r65388/s2101   1401 2010-01-15 14:12 mtd-utils/include/mtd/nftl-user.h
-rw-r----- r65388/s2101    516 2010-01-15 14:12 mtd-utils/include/mtd/mtd-user.h
-rw-r----- r65388/s2101   1674 2010-01-15 14:12 mtd-utils/include/mtd/inftl-user.h
-rw-r----- r65388/s2101  24520 2010-01-15 14:12 mtd-utils/fec.c
-rw-r----- r65388/s2101  50496 2010-01-15 14:12 mtd-utils/mkfs.jffs2.c
+ STATUS=0
+ '[' 0 -ne 0 ']'
+ cd mtd-utils
+ echo 'Patch #1 (mtd-utils-201006-4K-218-224-support.patch):'
+ patch -p1 -s
+ exit 0
Executing(%build): /bin/sh -e /home/distak-pc/iMX51/linux-2.6.35.3/ltib/tmp/rpm-tmp.11178
+ umask 022
+ cd mtd-utils
+ make -j1 WITHOUT_XATTR=1
gcc -I./include   -DWITHOUT_XATTR -D_FILE_OFFSET_BITS=64 -O2 -g -Wall -Wextra -Wwrite-strings -Wno-sign-compare -c -o /opt/freescale/ltib/usr/src/rpm/BUILD/mtd-utils/ftl_format.o ftl_format.c -g -Wp,-MD,/opt/freescale/ltib/usr/src/rpm/BUILD/mtd-utils/.ftl_format.c.dep
gcc -O2 -g -Wall -Wextra -Wwrite-strings -Wno-sign-compare   -g -o /opt/freescale/ltib/usr/src/rpm/BUILD/mtd-utils/ftl_format /opt/freescale/ltib/usr/src/rpm/BUILD/mtd-utils/ftl_format.o
gcc -I./include   -DWITHOUT_XATTR -D_FILE_OFFSET_BITS=64 -O2 -g -Wall -Wextra -Wwrite-strings -Wno-sign-compare -c -o /opt/freescale/ltib/usr/src/rpm/BUILD/mtd-utils/flash_erase.o flash_erase.c -g -Wp,-MD,/opt/freescale/ltib/usr/src/rpm/BUILD/mtd-utils/.flash_erase.c.dep
gcc -O2 -g -Wall -Wextra -Wwrite-strings -Wno-sign-compare   -g -o /opt/freescale/ltib/usr/src/rpm/BUILD/mtd-utils/flash_erase /opt/freescale/ltib/usr/src/rpm/BUILD/mtd-utils/flash_erase.o
gcc -I./include   -DWITHOUT_XATTR -D_FILE_OFFSET_BITS=64 -O2 -g -Wall -Wextra -Wwrite-strings -Wno-sign-compare -c -o /opt/freescale/ltib/usr/src/rpm/BUILD/mtd-utils/flash_eraseall.o flash_eraseall.c -g -Wp,-MD,/opt/freescale/ltib/usr/src/rpm/BUILD/mtd-utils/.flash_eraseall.c.dep
gcc -I./include   -DWITHOUT_XATTR -D_FILE_OFFSET_BITS=64 -O2 -g -Wall -Wextra -Wwrite-strings -Wno-sign-compare -c -o /opt/freescale/ltib/usr/src/rpm/BUILD/mtd-utils/crc32.o crc32.c -g -Wp,-MD,/opt/freescale/ltib/usr/src/rpm/BUILD/mtd-utils/.crc32.c.dep
gcc -O2 -g -Wall -Wextra -Wwrite-strings -Wno-sign-compare   -g -o /opt/freescale/ltib/usr/src/rpm/BUILD/mtd-utils/flash_eraseall /opt/freescale/ltib/usr/src/rpm/BUILD/mtd-utils/flash_eraseall.o /opt/freescale/ltib/usr/src/rpm/BUILD/mtd-utils/crc32.o
gcc -I./include   -DWITHOUT_XATTR -D_FILE_OFFSET_BITS=64 -O2 -g -Wall -Wextra -Wwrite-strings -Wno-sign-compare -c -o /opt/freescale/ltib/usr/src/rpm/BUILD/mtd-utils/nanddump.o nanddump.c -g -Wp,-MD,/opt/freescale/ltib/usr/src/rpm/BUILD/mtd-utils/.nanddump.c.dep
nanddump.c: In function 'main':
nanddump.c:352: warning: ignoring return value of 'write', declared with attribute warn_unused_result
nanddump.c:355: warning: ignoring return value of 'write', declared with attribute warn_unused_result
nanddump.c:381: warning: ignoring return value of 'write', declared with attribute warn_unused_result
nanddump.c:394: warning: ignoring return value of 'write', declared with attribute warn_unused_result
nanddump.c:397: warning: ignoring return value of 'write', declared with attribute warn_unused_result
gcc -O2 -g -Wall -Wextra -Wwrite-strings -Wno-sign-compare   -g -o /opt/freescale/ltib/usr/src/rpm/BUILD/mtd-utils/nanddump /opt/freescale/ltib/usr/src/rpm/BUILD/mtd-utils/nanddump.o
gcc -I./include   -DWITHOUT_XATTR -D_FILE_OFFSET_BITS=64 -O2 -g -Wall -Wextra -Wwrite-strings -Wno-sign-compare -c -o /opt/freescale/ltib/usr/src/rpm/BUILD/mtd-utils/doc_loadbios.o doc_loadbios.c -g -Wp,-MD,/opt/freescale/ltib/usr/src/rpm/BUILD/mtd-utils/.doc_loadbios.c.dep
gcc -O2 -g -Wall -Wextra -Wwrite-strings -Wno-sign-compare   -g -o /opt/freescale/ltib/usr/src/rpm/BUILD/mtd-utils/doc_loadbios /opt/freescale/ltib/usr/src/rpm/BUILD/mtd-utils/doc_loadbios.o
gcc -I./include   -DWITHOUT_XATTR -D_FILE_OFFSET_BITS=64 -O2 -g -Wall -Wextra -Wwrite-strings -Wno-sign-compare -c -o /opt/freescale/ltib/usr/src/rpm/BUILD/mtd-utils/ftl_check.o ftl_check.c -g -Wp,-MD,/opt/freescale/ltib/usr/src/rpm/BUILD/mtd-utils/.ftl_check.c.dep
ftl_check.c: In function 'check_partition':
ftl_check.c:107: warning: ignoring return value of 'read', declared with attribute warn_unused_result
ftl_check.c:82: warning: unused parameter 'verbose'
gcc -O2 -g -Wall -Wextra -Wwrite-strings -Wno-sign-compare   -g -o /opt/freescale/ltib/usr/src/rpm/BUILD/mtd-utils/ftl_check /opt/freescale/ltib/usr/src/rpm/BUILD/mtd-utils/ftl_check.o
gcc -I./include   -DWITHOUT_XATTR -D_FILE_OFFSET_BITS=64 -O2 -g -Wall -Wextra -Wwrite-strings -Wno-sign-compare -c -o /opt/freescale/ltib/usr/src/rpm/BUILD/mtd-utils/mkfs.jffs2.o mkfs.jffs2.c -g -Wp,-MD,/opt/freescale/ltib/usr/src/rpm/BUILD/mtd-utils/.mkfs.jffs2.c.dep
mkfs.jffs2.c: In function 'recursive_add_host_directory':
mkfs.jffs2.c:435: warning: ignoring return value of 'asprintf', declared with attribute warn_unused_result
mkfs.jffs2.c:440: warning: ignoring return value of 'asprintf', declared with attribute warn_unused_result
mkfs.jffs2.c:442: warning: ignoring return value of 'asprintf', declared with attribute warn_unused_result
mkfs.jffs2.c: In function 'interpret_table_entry':
mkfs.jffs2.c:533: warning: ignoring return value of 'asprintf', declared with attribute warn_unused_result
mkfs.jffs2.c:600: warning: ignoring return value of 'asprintf', declared with attribute warn_unused_result
mkfs.jffs2.c:601: warning: ignoring return value of 'asprintf', declared with attribute warn_unused_result
mkfs.jffs2.c: In function 'recursive_populate_directory':
mkfs.jffs2.c:1336: warning: format '%9lu' expects type 'long unsigned int', but argument 3 has type '__off64_t'
mkfs.jffs2.c:1345: warning: format '%9lu' expects type 'long unsigned int', but argument 3 has type '__off64_t'
mkfs.jffs2.c:1354: warning: format '%9lu' expects type 'long unsigned int', but argument 3 has type '__off64_t'
mkfs.jffs2.c:1384: warning: format '%9lu' expects type 'long unsigned int', but argument 3 has type '__off64_t'
mkfs.jffs2.c:1395: warning: format '%9lu' expects type 'long unsigned int', but argument 3 has type '__off64_t'
mkfs.jffs2.c: At top level:
mkfs.jffs2.c:1519: warning: initialization discards qualifiers from pointer target type
mkfs.jffs2.c:1521: warning: initialization discards qualifiers from pointer target type
mkfs.jffs2.c: In function 'main':
mkfs.jffs2.c:1881: warning: passing argument 2 of 'recursive_add_host_directory' discards qualifiers from pointer target type
mkfs.jffs2.c:403: note: expected 'char *' but argument is of type 'const char *'
gcc -I./include   -DWITHOUT_XATTR -D_FILE_OFFSET_BITS=64 -O2 -g -Wall -Wextra -Wwrite-strings -Wno-sign-compare -c -o /opt/freescale/ltib/usr/src/rpm/BUILD/mtd-utils/compr_rtime.o compr_rtime.c -g -Wp,-MD,/opt/freescale/ltib/usr/src/rpm/BUILD/mtd-utils/.compr_rtime.c.dep
compr_rtime.c: In function 'jffs2_rtime_compress':
compr_rtime.c:27: warning: unused parameter 'model'
compr_rtime.c: In function 'jffs2_rtime_decompress':
compr_rtime.c:67: warning: unused parameter 'srclen'
compr_rtime.c:67: warning: unused parameter 'model'
compr_rtime.c: At top level:
compr_rtime.c:104: warning: initialization discards qualifiers from pointer target type
gcc -I./include   -DWITHOUT_XATTR -D_FILE_OFFSET_BITS=64 -O2 -g -Wall -Wextra -Wwrite-strings -Wno-sign-compare -c -o /opt/freescale/ltib/usr/src/rpm/BUILD/mtd-utils/compr_zlib.o compr_zlib.c -g -Wp,-MD,/opt/freescale/ltib/usr/src/rpm/BUILD/mtd-utils/.compr_zlib.c.dep
compr_zlib.c: In function 'jffs2_zlib_compress':
compr_zlib.c:54: warning: unused parameter 'model'
compr_zlib.c: In function 'jffs2_zlib_decompress':
compr_zlib.c:102: warning: unused parameter 'model'
compr_zlib.c: At top level:
compr_zlib.c:130: warning: initialization discards qualifiers from pointer target type
gcc -I./include   -DWITHOUT_XATTR -D_FILE_OFFSET_BITS=64 -O2 -g -Wall -Wextra -Wwrite-strings -Wno-sign-compare -c -o /opt/freescale/ltib/usr/src/rpm/BUILD/mtd-utils/compr_lzo.o compr_lzo.c -g -Wp,-MD,/opt/freescale/ltib/usr/src/rpm/BUILD/mtd-utils/.compr_lzo.c.dep
compr_lzo.c:29:23: error: lzo/lzo1x.h: No such file or directory
compr_lzo.c: In function 'jffs2_lzo_cmpr':
compr_lzo.c:51: error: 'lzo_uint' undeclared (first use in this function)
compr_lzo.c:51: error: (Each undeclared identifier is reported only once
compr_lzo.c:51: error: for each function it appears in.)
compr_lzo.c:51: error: expected ';' before 'compress_size'
compr_lzo.c:54: warning: implicit declaration of function 'lzo1x_999_compress'
compr_lzo.c:54: error: 'compress_size' undeclared (first use in this function)
compr_lzo.c:56: error: 'LZO_E_OK' undeclared (first use in this function)
compr_lzo.c:49: warning: unused parameter 'model'
compr_lzo.c: In function 'jffs2_lzo_decompress':
compr_lzo.c:72: error: 'lzo_uint' undeclared (first use in this function)
compr_lzo.c:72: error: expected ';' before 'dl'
compr_lzo.c:74: warning: implicit declaration of function 'lzo1x_decompress_safe'
compr_lzo.c:74: error: 'dl' undeclared (first use in this function)
compr_lzo.c:76: error: 'LZO_E_OK' undeclared (first use in this function)
compr_lzo.c:69: warning: unused parameter 'model'
compr_lzo.c: At top level:
compr_lzo.c:84: warning: initialization discards qualifiers from pointer target type
compr_lzo.c: In function 'jffs2_lzo_init':
compr_lzo.c:95: error: 'LZO1X_999_MEM_COMPRESS' undeclared (first use in this function)
make: *** [/opt/freescale/ltib/usr/src/rpm/BUILD/mtd-utils/compr_lzo.o] Error 1
rm /opt/freescale/ltib/usr/src/rpm/BUILD/mtd-utils/doc_loadbios.o /opt/freescale/ltib/usr/src/rpm/BUILD/mtd-utils/flash_erase.o /opt/freescale/ltib/usr/src/rpm/BUILD/mtd-utils/ftl_format.o /opt/freescale/ltib/usr/src/rpm/BUILD/mtd-utils/nanddump.o /opt/freescale/ltib/usr/src/rpm/BUILD/mtd-utils/ftl_check.o
error: Bad exit status from /home/distak-pc/iMX51/linux-2.6.35.3/ltib/tmp/rpm-tmp.11178 (%build)
RPM build errors:
Build time for mtd-utils: 2 seconds
Failed building mtd-utils
Died at ./ltib line 1380.
traceback:
 main::build_host_rpms:1380
  main::host_checks:1435
   main:542
Started: Thu Mar  8 08:57:19 2012
Ended:   Thu Mar  8 08:57:22 2012
Elapsed: 3 seconds
These packages failed to build:
mtd-utils
Build Failed
Thank you
标记 (2)
2,373 次查看
KrishnaPavan
Fresh Out Contributor
Open Synaptics Package Manager and install mtd-utils developer files and other supporting files as well.
I just provided the list of softwares, so that you can check, whether they are installed on your PC or not?
2,373 次查看
Mr_GustavoCosta
Krishna Pavan said:
# Installation packages needed by LTIB, on your Host
sudo aptitude -y install gettext libgtk2.0-dev rpm bison m4 libfreetype6-dev
sudo aptitude -y install libdbus-glib-1-dev liborbit2-dev intltool
sudo aptitude -y install ccache ncurses-dev zlib1g zlib1g-dev gcc g++ libtool
sudo aptitude -y install uuid-dev liblzo2-dev
sudo aptitude -y install tcl dpkg
Check!
I couldn't install any off these. I couldn't  find any of the links.
There is another way?
Thank you.
2,373 次查看
KrishnaPavan
Check!
