hello everyone,
I'm trying to add a package to use with Ltib. the package is "winexe".
I've downloaded it from this link: http://sourceforge.net/projects/winexe/
I've followed LtibFaq page in this link: http://www.bitshrine.org/autodocs/LtibFaq.html
and the steps were:
1)downloading the package (from above link)
2)mv winexe-1.00.tar.gz /opt/freescale/pkgs/
3)mkdir dist/lfs-5.1/winexe
4)cp dist/lfs-5.1/template/template.spec dist/lfs-5.1/winexe/winexe.spec
5)edit the winexe.spec file as attached. ad described in this link of the installation commands: http://whowhywhathow.blogspot.com/2011/04/winexe-to-run-code-on-windows-machines.html
6)ran ./ltib -m prep -p winexe --> succeeded
7)ran ./ltib -m scbuild -p winexe -->failed.
the terminal log is attached also in "terminal_log.txt" file.
i think it something with the dependencies path (python...) but i don't know how to point it to the correct path. (I've installed python with ltib so i have python 2.4 in my rootfs but winexe don't know about it....)
can someone please help me with this...
thanks,
snir
Original Attachment has been moved to: 281-winexe.spec
