Install a 32 bit application on i.MX8M Plus
1,022 次查看
apoorvajohn
Identified that the board is aarch64. Our application is 32 bit. Is there any way to run the application on the board ?
1,012 次查看
BiyongSUN
If you use NXP BSP release, which is by Yocto, BSP document i.MX Yocto Project User's Guide gives guide and this guide is copied from Yocto document.
1,017 次查看
Hi Apoorva
may be useful AN12212 Software Solutions for Migration Guide from Aarch32 to Aarch64
