Incorrect permissions for the “sudo” command in 6.12.20
1,516件の閲覧回数
cedric_starke
Hello community,
I have tried to change the user rights management of the Linux system I am using.
Instead of using root, I would like to add two new users. One as a “normal” user and one as a “sudo” user.
To solve this, I added the following lines to my local.conf:
inherit extrausers
EXTRA_USERS_PARAMS = "\
    useradd -M -N -G sudo -p 'test01' sudo_user; \
    useradd -M -N -G users -p 'test02' normal_user; \
This seems to work, as the users are listed in /etc/passwd and /etc/shadow.
To execute root commands, I also need the sudo command. To include this in my package, I added the following to local.conf:
IMAGE_INSTALL:append = " sudo"
This installs the sudo command in my package, but the permissions are incorrect and result in the following output:
sudo: /usr/bin/sudo must be owned by uid 0 and have the setuid bit set
To solve this problem, I can change the permissions in the running system as follows:
chown root:root /usr/bin/sudo
chmod 4755 /usr/bin/sudo
But I need this directly as bitbake output.
Does anyone have any idea what I might have overlooked?
I am using Linux 6.12.20 for an iMX8M Mini based on the DDR4 EVK and the Bitbake image "fsl-image-machine-test".
The image “imx-image-multimedia” already includes sudo, but the permissions appear to be the same.
ラベル(3)
1,004件の閲覧回数
cedric_starke
Hi @Oswalag,
Thanks for your reply, but when I run “bitbake”, with this option, I get an error.
In the end, I solved the problem by using a “bbappend” in my own layer, as shown in this example:
https://github.com/stromerbike/meta-medusa-dist/blob/master/recipes-extended/sudo/sudo_%25.bbappend
Maybe this will help someone else.
4 返答(返信)
1,462件の閲覧回数
Oswalag
1,431件の閲覧回数
cedric_starke
Hi @Oswalag,
Thanks for your reply, but the link has nothing to do with my problem.
I didn't mention in my question that I had already decided to change the sudoers file and comment out the line:
# %sudo ALL=(ALL) ALL
So my sudo user could run sudo IF the sudo command itself had the correct permissions.
However, after the YOCTO build, the sudo command shows me the following permissions:
---x--x--x 1 root root 334976 Mar  9  2018 /usr/bin/sudo
To run it as a member of the sudo group, the following is required:
-rwsr-xr-x 1 root root 334976 Mar  9  2018 /bin/sudo
Do you have any thoughts on this point
1,304件の閲覧回数
Oswalag
I understand, please try to add to your local.conf
EXTRA_IMAGE_FEATURES += "allow-setuid"
1,005件の閲覧回数
cedric_starke
Hi @Oswalag,
%3CLINGO-SUB%20id%3D%22lingo-sub-2306097%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E6.12.20%20%E3%81%AE%E3%80%8Csudo%E3%80%8D%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%81%AE%E6%A8%A9%E9%99%90%E3%81%8C%E6%AD%A3%E3%81%97%E3%81%8F%E3%81%AA%E3%81%84%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2306097%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%E3%82%B3%E3%83%9F%E3%83%A5%E3%83%8B%E3%83%86%E3%82%A3%E3%81%AE%E7%9A%86%E6%A7%98%3C%2FP%3E%3CP%3E%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%20Linux%20%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E3%81%AE%E3%83%A6%E3%83%BC%E3%82%B6%E3%83%BC%E6%A8%A9%E9%99%90%E3%83%9E%E3%83%8D%E3%82%B8%E3%83%A1%E3%83%B3%E3%83%88%E3%82%92%E5%A4%89%E6%9B%B4%E3%81%97%E3%82%88%E3%81%86%E3%81%A8%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3CBR%20%2F%3Eroot%20%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%E4%BB%A3%E3%82%8F%E3%82%8A%E3%81%AB%E3%80%812%20%E4%BA%BA%E3%81%AE%E6%96%B0%E8%A6%8F%E3%83%A6%E3%83%BC%E3%82%B6%E3%83%BC%E3%82%92%E8%BF%BD%E5%8A%A0%E3%81%97%E3%81%9F%E3%81%84%E3%81%A8%E6%80%9D%E3%81%84%E3%81%BE%E3%81%99%E3%80%821%20%E3%81%A4%E3%81%AF%E3%80%8C%E9%80%9A%E5%B8%B8%E3%80%8D%E3%83%A6%E3%83%BC%E3%82%B6%E3%83%BC%E3%81%A8%E3%81%97%E3%81%A6%E3%80%81%E3%82%82%E3%81%86%201%20%E3%81%A4%E3%81%AF%E3%80%8Csudo%E3%80%8D%E3%83%A6%E3%83%BC%E3%82%B6%E3%83%BC%E3%81%A8%E3%81%97%E3%81%A6%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%81%93%E3%81%AE%E5%95%8F%E9%A1%8C%E3%82%92%E8%A7%A3%E6%B1%BA%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AB%E3%80%81local.conf%20%E3%81%AB%E6%AC%A1%E3%81%AE%E8%A1%8C%E3%82%92%E8%BF%BD%E5%8A%A0%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CPRE%20class%3D%22lia-code-sample%20language-markup%22%3E%3CCODE%20translate%3D%22no%22%3Einherit%20extrausers%0AEXTRA_USERS_PARAMS%20%3D%20%22%5C%0A%20%20%20%20useradd%20-M%20-N%20-G%20sudo%20-p%20'test01'%20sudo_user%3B%20%5C%0A%20%20%20%20useradd%20-M%20-N%20-G%20users%20-p%20'test02'%20normal_user%3B%20%5C%0A%20%20%20%20%22%3C%2FCODE%3E%3C%2FPRE%3E%3CBR%20%2F%3E%3CP%3E%E3%83%A6%E3%83%BC%E3%82%B6%E3%83%BC%E3%81%AF%20%2Fetc%2Fpasswd%20%E3%81%A8%20%2Fetc%2Fshadow%20%E3%81%AB%E3%83%AA%E3%82%B9%E3%83%88%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E3%81%AE%E3%81%A7%E3%80%81%E3%81%93%E3%82%8C%E3%81%AF%E6%A9%9F%E8%83%BD%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E3%82%88%E3%81%86%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3Eroot%20%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%99%E3%82%8B%E3%81%AB%E3%81%AF%E3%80%81sudo%20%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%82%82%E5%BF%85%E8%A6%81%E3%81%A7%E3%81%99%E3%80%82%E3%81%93%E3%82%8C%E3%82%92%E3%83%91%E3%83%83%E3%82%B1%E3%83%BC%E3%82%B8%E3%81%AB%E5%90%AB%E3%82%81%E3%82%8B%E3%81%AB%E3%81%AF%E3%80%81local.conf%20%E3%81%AB%E6%AC%A1%E3%81%AE%E3%82%B3%E3%83%BC%E3%83%89%E3%82%92%E8%BF%BD%E5%8A%A0%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CPRE%20class%3D%22lia-code-sample%20language-markup%22%3E%3CCODE%20translate%3D%22no%22%3EIMAGE_INSTALL%3Aappend%20%3D%20%22%20sudo%22%3C%2FCODE%3E%3C%2FPRE%3E%3CBR%20%2F%3E%3CP%3E%E3%81%93%E3%82%8C%E3%81%AB%E3%82%88%E3%82%8A%E3%80%81%E3%83%91%E3%83%83%E3%82%B1%E3%83%BC%E3%82%B8%E3%81%AB%20sudo%20%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%81%8C%E3%82%A4%E3%83%B3%E3%82%B9%E3%83%88%E3%83%BC%E3%83%AB%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%81%8C%E3%80%81%E6%A8%A9%E9%99%90%E3%81%8C%E6%AD%A3%E3%81%97%E3%81%8F%E3%81%AA%E3%81%84%E3%81%9F%E3%82%81%E3%80%81%E6%AC%A1%E3%81%AE%E5%87%BA%E5%8A%9B%E3%81%8C%E7%94%9F%E6%88%90%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CPRE%20class%3D%22lia-code-sample%20language-markup%22%3E%3CCODE%20translate%3D%22no%22%3Esudo%3A%20%2Fusr%2Fbin%2Fsudo%20must%20be%20owned%20by%20uid%200%20and%20have%20the%20setuid%20bit%20set%3C%2FCODE%3E%3C%2FPRE%3E%3CBR%20%2F%3E%3CP%3E%E3%81%93%E3%81%AE%E5%95%8F%E9%A1%8C%E3%82%92%E8%A7%A3%E6%B1%BA%E3%81%99%E3%82%8B%E3%81%AB%E3%81%AF%E3%80%81%E5%AE%9F%E8%A1%8C%E4%B8%AD%E3%81%AE%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E3%81%AE%E6%A8%A9%E9%99%90%E3%82%92%E6%AC%A1%E3%81%AE%E3%82%88%E3%81%86%E3%81%AB%E5%A4%89%E6%9B%B4%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CPRE%20class%3D%22lia-code-sample%20language-markup%22%3E%3CCODE%20translate%3D%22no%22%3Echown%20root%3Aroot%20%2Fusr%2Fbin%2Fsudo%0Achmod%204755%20%2Fusr%2Fbin%2Fsudo%3C%2FCODE%3E%3C%2FPRE%3E%3CBR%20%2F%3E%3CP%3E%E3%81%97%E3%81%8B%E3%81%97%E3%80%81%E3%81%93%E3%82%8C%E3%82%92%E7%9B%B4%E6%8E%A5%20Bitbake%20%E5%87%BA%E5%8A%9B%E3%81%A8%E3%81%97%E3%81%A6%E5%BF%85%E8%A6%81%E3%81%A8%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E7%A7%81%E3%81%8C%E4%BD%95%E3%82%92%E8%A6%8B%E8%90%BD%E3%81%A8%E3%81%97%E3%81%9F%E3%81%AE%E3%81%8B%E3%80%81%E8%AA%B0%E3%81%8B%E5%88%86%E3%81%8B%E3%82%8B%E3%81%A7%E3%81%97%E3%82%87%E3%81%86%E3%81%8B%3F%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E7%A7%81%E3%81%AF%E3%80%81DDR4%20EVK%20%E3%81%A8%20Bitbake%20%E3%82%A4%E3%83%A1%E3%83%BC%E3%82%B8%E3%80%8Cfsl-image-machine-test%E3%80%8D%E3%82%92%E3%83%99%E3%83%BC%E3%82%B9%E3%81%AB%E3%81%97%E3%81%9F%20iMX8M%20Mini%20%E3%81%AB%20Linux%206.12.20%20%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%82%A4%E3%83%A1%E3%83%BC%E3%82%B8%E3%80%8Cimx-image-multimedia%E3%80%8D%E3%81%AB%E3%81%AF%E3%81%99%E3%81%A7%E3%81%AB%20sudo%20%E3%81%8C%E5%90%AB%E3%81%BE%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%81%8C%E3%80%81%E6%A8%A9%E9%99%90%E3%81%AF%E5%90%8C%E3%81%98%E3%81%A7%E3%81%82%E3%82%8B%E3%82%88%E3%81%86%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-2306097%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3Ei.MX%208M%20%7C%20i.MX%208M%20%E3%83%9F%E3%83%8B%20%7C%20i.MX%208M%20%E3%83%8A%E3%83%8E%3C%2FLINGO-LABEL%3E%3CLINGO-LABEL%3ELinux%3C%2FLINGO-LABEL%3E%3CLINGO-LABEL%3EYocto%20Project%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2314045%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Incorrect%20permissions%20for%20the%20%E2%80%9Csudo%E2%80%9D%20command%20in%206.12.20%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2314045%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%3C%2FP%3E%0A%3CP%3E%E4%BB%A5%E4%B8%8B%E3%81%AE%E3%83%AA%E3%83%B3%E3%82%AF%E3%82%92%E3%81%94%E7%A2%BA%E8%AA%8D%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%0A%3CP%3E%3CA%20href%3D%22https%3A%2F%2Funix.stackexchange.com%2Fquestions%2F375433%2Fetc-sudoers-vs-etc-sudoers-d-file-for-enabling-sudo-for-a-user%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttps%3A%2F%2Funix.stackexchange.com%2Fquestions%2F375433%2Fetc-sudoers-vs-etc-sudoers-d-file-for-enabling-sudo-for-a-user%3C%2FA%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2314370%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Incorrect%20permissions%20for%20the%20%E2%80%9Csudo%E2%80%9D%20command%20in%206.12.20%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2314370%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F199933%22%20target%3D%22_blank%22%3E%40Oswalag%3C%2FA%3E%20%E3%80%81%3C%2FP%3E%3CP%3E%E3%81%94%E8%BF%94%E4%BF%A1%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E3%81%9F%E3%81%A0%E3%81%97%E3%80%81%E3%81%9D%E3%81%AE%E3%83%AA%E3%83%B3%E3%82%AF%E3%81%AF%E7%A7%81%E3%81%AE%E5%95%8F%E9%A1%8C%E3%81%A8%E3%81%AF%E5%85%A8%E3%81%8F%E9%96%A2%E4%BF%82%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FP%3E%3CP%3E%E8%B3%AA%E5%95%8F%E3%81%A7%E3%81%AF%E3%80%81sudoers%20%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%92%E5%A4%89%E6%9B%B4%E3%81%97%E3%81%A6%E6%AC%A1%E3%81%AE%E8%A1%8C%E3%82%92%E3%82%B3%E3%83%A1%E3%83%B3%E3%83%88%E3%82%A2%E3%82%A6%E3%83%88%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%82%92%E3%81%99%E3%81%A7%E3%81%AB%E6%B1%BA%E5%AE%9A%E3%81%97%E3%81%A6%E3%81%84%E3%81%9F%E3%81%93%E3%81%A8%E3%82%92%E8%BF%B0%E3%81%B9%E3%81%A6%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%E3%81%A7%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CPRE%20class%3D%22lia-code-sample%20language-markup%22%3E%3CCODE%20translate%3D%22no%22%3E%23%20%25sudo%20ALL%3D(ALL)%20ALL%3C%2FCODE%3E%3C%2FPRE%3E%3CP%3ESO%E3%80%81sudo%20%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E8%87%AA%E4%BD%93%E3%81%AB%E6%AD%A3%E3%81%97%E3%81%84%E6%A8%A9%E9%99%90%E3%81%8C%E3%81%82%E3%82%8C%E3%81%B0%E3%80%81sudo%20%E3%83%A6%E3%83%BC%E3%82%B6%E3%83%BC%E3%81%AF%20sudo%20%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E3%81%9F%E3%81%A0%E3%81%97%E3%80%81YOCTO%20%E3%83%93%E3%83%AB%E3%83%89%E5%BE%8C%E3%80%81sudo%20%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%99%E3%82%8B%E3%81%A8%E6%AC%A1%E3%81%AE%E6%A8%A9%E9%99%90%E3%81%8C%E8%A1%A8%E7%A4%BA%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CPRE%20class%3D%22lia-code-sample%20language-markup%22%3E%3CCODE%20translate%3D%22no%22%3E---x--x--x%201%20root%20root%20334976%20Mar%20%209%20%202018%20%2Fusr%2Fbin%2Fsudo%3C%2FCODE%3E%3C%2FPRE%3E%3CP%3Esudo%20%E3%82%B0%E3%83%AB%E3%83%BC%E3%83%97%E3%81%AE%E3%83%A1%E3%83%B3%E3%83%90%E3%83%BC%E3%81%A8%E3%81%97%E3%81%A6%E5%AE%9F%E8%A1%8C%E3%81%99%E3%82%8B%E3%81%AB%E3%81%AF%E3%80%81%E4%BB%A5%E4%B8%8B%E3%81%8C%E5%BF%85%E8%A6%81%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CPRE%20class%3D%22lia-code-sample%20language-markup%22%3E%3CCODE%20translate%3D%22no%22%3E-rwsr-xr-x%201%20root%20root%20334976%20Mar%20%209%20%202018%20%2Fbin%2Fsudo%3C%2FCODE%3E%3C%2FPRE%3E%3CBR%20%2F%3E%3CP%3E%E3%81%93%E3%81%AE%E7%82%B9%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%E4%BD%95%E3%81%8B%E3%81%94%E6%84%8F%E8%A6%8B%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%81%8B%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2321433%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Incorrect%20permissions%20for%20the%20%E2%80%9Csudo%E2%80%9D%20command%20in%206.12.20%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2321433%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E5%88%86%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82local.conf%E3%81%AB%E8%BF%BD%E5%8A%A0%E3%81%97%E3%81%A6%E3%81%BF%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%0A%3CP%3E%3CSPAN%3EEXTRA_IMAGE_FEATURES%20%2B%3D%20%22allow-setuid%22%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2343496%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Incorrect%20permissions%20for%20the%20%E2%80%9Csudo%E2%80%9D%20command%20in%206.12.20%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2343496%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F199933%22%20target%3D%22_blank%22%3E%40Oswalag%3C%2FA%3E%20%E3%80%81%3C%2FP%3E%3CP%3E%E3%81%94%E5%9B%9E%E7%AD%94%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E3%81%97%E3%81%8B%E3%81%97%E3%80%81%E3%81%93%E3%81%AE%E3%82%AA%E3%83%97%E3%82%B7%E3%83%A7%E3%83%B3%E3%82%92%E6%8C%87%E5%AE%9A%E3%81%97%E3%81%A6%E3%80%8Cbitbake%E3%80%8D%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%99%E3%82%8B%E3%81%A8%E3%80%81%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E6%9C%80%E7%B5%82%E7%9A%84%E3%81%AB%E3%80%81%E3%81%93%E3%81%AE%E4%BE%8B%E3%81%AB%E7%A4%BA%E3%81%99%E3%82%88%E3%81%86%E3%81%AB%E3%80%81%E7%8B%AC%E8%87%AA%E3%81%AE%E3%83%AC%E3%82%A4%E3%83%A4%E3%83%BC%E3%81%A7%E3%80%8Cbbappend%E3%80%8D%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%81%A7%E5%95%8F%E9%A1%8C%E3%82%92%E8%A7%A3%E6%B1%BA%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3CBR%20%2F%3E%20%3CA%20href%3D%22https%3A%2F%2Fgithub.com%2Fstromerbike%2Fmeta-medusa-dist%2Fblob%2Fmaster%2Frecipes-extended%2Fsudo%2Fsudo_%2525.bbappend%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttps%3A%2F%2Fgithub.com%2Fstromerbike%2Fmeta-medusa-dist%2Fblob%2Fmaster%2Frecipes-extended%2Fsudo%2Fsudo_%2525.bbappend%3C%2FA%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E3%81%93%E3%82%8C%E3%81%8C%E8%AA%B0%E3%81%8B%E3%81%AE%E5%BD%B9%E3%81%AB%E7%AB%8B%E3%81%A4%E3%81%8B%E3%82%82%E3%81%97%E3%82%8C%E3%81%AA%E3%81%84%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E
