I want to create a new layer,use my local uboot source and kernel , I look "yocto project development manual "
but I want to use local uboot and kernel source ,how can I config it
解決済! 解決策の投稿を見る。
Hi Xuhui Li,
I agree to Weidong Sun that this question is out of support range. But you can add a new machine to yocto. By adding new machine, you can modify the kernel, dtb and filesystem by this method, but creating custom u-boot is out of scope (in my point of view due to my lack of knowledge). I think you can find an answer from the link below
How to add support of custom board into YOCTO - iMX6 Rex Projects
Hi Xuhui Li,
Thank you for your guidance !!!
Hello xuhui,
After you set up yocto environment according to linux BSP document, you should compile u-boot, linux kernel, if compiling is successful, you can find u-boot & kernel source code in your building path.
As for how to add a new layer to yocto, you will have to read document of yocto, and do it by yourself, the question is out of our support range !
Weidong
