In linux kernel 3.14.28 source we unable to enable following configs.
aravinthkumarja
Senior Contributor II
Following configs can't enable in kernel 3.14.28:-
CONFIG_AC97_BUS
CONFIG_SND_VMASTER
CONFIG_SND_AC97_CODEC
i enabled the "depends on" configs of above mentioned configs, But it's working. Can you please mention the steps to enable the above mentioned configs.
Thanks!
aravinthkumarja
I can able to configure the above mentioned configuration by enablingCONFIG_SND_SOC_ALL_CODECS
Thanks!
Aravinth
aravinthkumarja
Thanks!
Aravinth
