Hello @krushnapagadeA2Cautomotiv,
Unfortunately, there is not an example of evkbmimxrt1060_lpi2c_interrupt in Config Tools. Config Tools only does the initial configuration for the drivers, in this case for the I2C, so for achieve a similar code in your project you should write the rest of the it.
Best regards, Raul.
