In IMXRT1060 How to Configure I2C Master with Interrupt using Config Tool
793 次查看
I am Trying to Create I2C Master Configuration in EVKB IMXRT1060 Development Board. I Want to Configure I2C1 as Master and It transmit and Receive Data using interrupt mode. I saw evkbmimxrt1060_lpi2c_interrupt Example Code and doing Similar Configuration in my Project using Peripherals Config tool But It's not Working ?? Please Share me Simple Project On I2C using Config Tool.
764 次查看
RaRo
Hello @krushnapagadeA2Cautomotiv,
Unfortunately, there is not an example of evkbmimxrt1060_lpi2c_interrupt in Config Tools. Config Tools only does the initial configuration for the drivers, in this case for the I2C, so for achieve a similar code in your project you should write the rest of the it.
Best regards, Raul.
