Imx93 compilation error.
2,669 次查看
xiang_1001
Imx93 compiler bitbake matter reported an error. See the attachment for the error.
Excuse me, how to solve it?
2,622 次查看
xiang_1001
My question is git-lfs: not found
4 回复数
2,641 次查看
Zhiming_Liu
It looks like a network issue, fail to fetch matter source code from github.
Zhiming
2,635 次查看
xiang_1001
How to solve it?
2,622 次查看
xiang_1001
2,662 次查看
Bugger
bitbake errors pulled my hair out as well. Took me several days to get a imx-image-core build through. Finally ended up with a VM and Ubuntu 20.04, 16GB memory and 4 CPU,  no changed to local.conf. and 300GB disk and about 30 all hard to understand errors that ALL  were no errors by just retrying.. (another MPU64 bit vendor only took 32GB or so not sure why IMX is so big) . Attempting "full" probably goes over 300G.  Just keep retrying the build !
