Imx8mq: How to encrypt rootfs
6,189 次查看
kinjalGediya
I am using iMX8MQ based custom board and I want to encrypt rootfs.
I have gone through the community link
link: https://community.nxp.com/t5/i-MX-Processors/How-to-create-an-encrypted-rootfs-for-iMX8MQ-using-yoct...
I am facing the same as describe in above link. I am not able to create "/dev/caam-keygen" node.
I am working on kernel version 5.4.3 but I tried with kernel version 5.4.80 but still facing the same issue.
I am attaching kernel configuration for your reference.
Another thing I wanted to know that which device driver file is responsible to create "/dev/caam-keygen" node?
9 回复数
6,170 次查看
b36401
Please make sure that keygen sources are included (I mean drivers/crypto/caam/caamrng.c)
6,144 次查看
kinjalGediya
Thanks for reply.
I have follow the steps successfully and now I wanted to know that How to add support in yocto to create encrypted rootfs so that I can directly flash encrypted rootfs?
Hope for your quick response.
标记 (1)
6,119 次查看
b36401
I can offer this document regarding to rootfs encryption:
https://community.nxp.com/docs/DOC-342300
2,527 次查看
ssepulveda
Could you share the document with me, please?
6,082 次查看
kinjalGediya
I am not able to open link which you have provided.
Can you give any alternative link for the same.
5,518 次查看
Pugo
I am also trying to investigate encrypted rootfs, but can not read this document.
If it is an NDA matter I am currently trying to figure out how the process of that is handled within my organization.
5,545 次查看
gnulux
Is it possible to have the documentation too ? I can't download it
5,971 次查看
b36401
I sent you the article over email.
5,898 次查看
Aimo
@b36401 Can I get the same article, please.
标记 (1)
