Imx8mq Extended Display(HDMI) support
2,030 次查看
srinu_inaganti
I am trying configure MIPI-DSI as a primary display and HDMI as secondary extended display.
Can anyone help me, what is the procedure to configure uboot, kernel and DTB are required to achieve the HDMI display to work as a extended display.
Thanks and Regards,
Srinu Inaganti.
1,942 次查看
joanxie
in the demo images, you can find fsl-imx8mq-evk-dual-display.dtb which is used for connection the 4k monitor to the HDMI output and other HDMI display to the MIPI-DSI using the IMX MIPI-HDMI daughter-board.
1,942 次查看
srinu_inaganti
Thank you I will look into dtb.
