Imx8 IPU Output
Imx8 IPU Output
3,557件の閲覧回数
omerbenezra
I'm working in IMX8QM of varicite.
We are looking to change the ipu output to RGBA.
Where in the kernel source code should be change?
Thank you
Omer
2 返答(返信)
3,454件の閲覧回数
Hi Omer
i.MX8QM has DPU not IPU, linux driver description can be found in
sect.6.2 Display Overview, sect.6.3.1.3 Source Code Structure
attached Linux Manual.
linux-imx - i.MX Linux kernel
3,454件の閲覧回数
omerbenezra
thank you.
i will check the drivers source.
there is example how to connect dpu output to ldb for lvds output?
