IMXRT1175 : HAB API does not work with 2 different IMG certificate
1,152 次查看
KrutarthRaut
I am trying to achieve extended secure boot in which we need to authenticate Sw with HAB API.
Verification Tree is like, Internal ROM to Bootloader and Bootloader to APP file.
In this scenario, I am using IMG1 certificate for Bootloader (from attached CSF section below Bootloader Sw file) and for IMG2 certificate for APP (from attached CSF section below APP Sw file). API "hab_authenticate_image" is used for authentication.
API always gives me issue if I used IMG2 certificate but works fine with IMG1 certificate. Looks like, for 2nd iteration, HAB is not at all considering CSF section. Which looks like bug in HAB API development. Please can you share information if we can overcome this issue.
regards
Krutarth Raut
1 回复
1,042 次查看
Julián_AragónM
Hi @KrutarthRaut,
I hope you are doing well! Please help me checking this community post: How to use HAB secure boot in i.MX RT1170 - NXP Community
Julián.
