IMXRT1050 XIP erase and program Serial NOR Flash
1,617 次查看
yuzhouhuang
I am using IMXRT1050. My program runs at Serial NOR Flash via FlexSPI. I want to erase and program Flash to save some user parameters. How can I erase and program Flash while continue to execute my code in the Flash. I don't want to block my code while Flash is erasing.
标记 (2)
1,468 次查看
Carlos_Musich
Hi Yuzhou,
you may run from sdram while you reflash. You can take a look here:
RT1050 - Booting from serial NOR flash to SDRAM
Carlos
NXP Technical Support
