IMXRT1050-EVKB Design files in Altium Format
1,973 次查看
Matt_sampson
Posting the same question as the link below, I'm looking for the IMXRT1050-EVKB Design files in Altium format. I was told by NXP support that these converted files exist and could be shared. Could you please PM me the files in Altium format?
https://community.nxp.com/t5/i-MX-RT/IMXRT1050-EVKB-design-files-schematic-BOM-layout-for-A1-version...
Pete
1,964 次查看
kerryzhou
Hi @Matt_sampson ,
  Already send you the private message, please check that attachment!
Wish it helps you!
Kerry
1,959 次查看
Matt_sampson
Thanks!
1,956 次查看
kerryzhou
Hi @Matt_sampson ,
   You are welcome!
   If your question is solved,  please help to mark the correct answer, just to close this case, thanks.
Kerry
1,965 次查看
kerryzhou
Hi @Matt_sampson ,
Wish it helps you!
Kerry
