IMXRT1050-EVKB DC Power Jack Part Number?
2,166 次查看
Matt_sampson
Looking for the part number for J2, the 5V DC barrel jack connector on the IMXRT1050-EVKB schematic. I need to order some barrel jacks and would like a P/N to confirm I have the right sized jack. Haven't found this information on the schematic or in the user guide.
3 回复数
2,159 次查看
kerryzhou
Hi @Matt_sampson ,
   You need to check it in the BOM file, J2, you can find the following information
Wish it helps you!
Kerry
2,154 次查看
Matt_sampson
Thanks for sharing. Unfortunately when I search for the part number "DC060024202" I still cannot find this part and therefore don't know what sized plug to buy. There look to be some datasheets but ther are in Chinese. Can you provide a P/N for the mating plug or the size of the plug on the eval board?
Mark
2,145 次查看
kerryzhou
Hi @Matt_sampson ,
   In find the mouser also have this DC plug:
https://www.mouser.com/ProductDetail/Gravitech/CON-SOCJ-2155?qs=fkzBJ5HM%252BdCcpvFQyQZHtA%3D%3D
Size like this:
I also compare the size with the MIMXRT1050-EVKB J2, it is the same.
So, you can use it.
Wish it helps you!
Kerry
