IMX95 failed to reparent can1
436 次查看
HenryHsu
I tried to enable can1
my device tree pin is follow imx95 evk, and disable  &micfil
IMX95_PAD_PDM_CLK__AONMIX_TOP_CAN1_TX  0x39e
IMX95_PAD_PDM_BIT_STREAM0__AONMIX_TOP_CAN1_RX  0x39e
, but the following error occurred.
[ 9.968941] CAN device driver interface
[ 9.976800] scmi-pinctrl-imx scmi_dev.8: Error set config -13
[ 9.976814] scmi-pinctrl-imx scmi_dev.8: pin_config_set op failed for pin 121
[ 9.976893] clk: failed to reparent can1 to syspll1_pfd1_di: -1
[ 9.978973] Internal error: synchronous external abort: 0000000096000010 [#1] SMP
[ 9.978986] Modules linked in: flexcan(+) can_dev neoisp(+) at24 rpmsg_ctrl rpmsg_char pwm_fan enetc4_uio(O) fsl_ecat_enetc4 fsl_ecat_enetc_core moal(O) mlan(O) fuse
[ 9.979017] CPU: 5 UID: 0 PID: 357 Comm: (udev-worker) Tainted: G M O 6.18.2-rt3-1.0.0-1.0.0 #1 PREEMPT_RT
[ 9.979026] Tainted: [M]=MACHINE_CHECK, [O]=OOT_MODULE
[ 9.979028] Hardware name: Axiomtek i.MX95 scm136 board (DT)
[ 9.979031] pstate: 60400009 (nZCv daif +PAN -UAO -TCO -DIT -SSBS BTYPE=--)
[ 9.979035] pc : flexcan_read_le+0x0/0x20 [flexcan]
[ 9.979060] lr : flexcan_probe+0x454/0x834 [flexcan]
[ 9.979067] sp : ffff800086133820
[ 9.979069] x29: ffff800086133850 x28: ffff8000862b0000 x27: ffff000085a182a0
Does anyone know how to fix this?
407 次查看
Zhiming_Liu
Hi @HenryHsu
Here is my previous test on i.MX95 EVK, please check your dts with below modifications.
dts modification:
diff --git a/arch/arm64/boot/dts/freescale/imx95-19x19-evk.dts b/arch/arm64/boot/dts/freescale/imx95-19x19-evk.dts
index ab7bd4fdaadf..5eb3011f0894 100644
--- a/arch/arm64/boot/dts/freescale/imx95-19x19-evk.dts
+++ b/arch/arm64/boot/dts/freescale/imx95-19x19-evk.dts
@@ -380,7 +380,7 @@ &flexcan1 {
 	pinctrl-names = "default";
 	pinctrl-0 = <&pinctrl_flexcan1>;
 	xceiver-supply = <&reg_can1_stby>;
-	status = "disabled";
+	status = "okay";
 &flexcan2 {
@@ -623,23 +623,23 @@ spidev0: spi@0 {
-&micfil {
-	#sound-dai-cells = <0>;
-	pinctrl-names = "default", "sleep";
-	pinctrl-0 = <&pinctrl_pdm>;
-	pinctrl-1 = <&pinctrl_pdm_sleep>;
-	assigned-clocks = <&scmi_clk IMX95_CLK_AUDIOPLL1_VCO>,
-			  <&scmi_clk IMX95_CLK_AUDIOPLL2_VCO>,
-			  <&scmi_clk IMX95_CLK_AUDIOPLL1>,
-			  <&scmi_clk IMX95_CLK_AUDIOPLL2>,
-			  <&scmi_clk IMX95_CLK_PDM>;
-	assigned-clock-parents = <0>, <0>, <0>, <0>,
-				 <&scmi_clk IMX95_CLK_AUDIOPLL1>;
-	assigned-clock-rates = <3932160000>,
-			       <3612672000>, <393216000>,
-			       <361267200>, <49152000>;
-	status = "okay";
+// &micfil {
+// 	#sound-dai-cells = <0>;
+// 	pinctrl-names = "default", "sleep";
+// 	pinctrl-0 = <&pinctrl_pdm>;
+// 	pinctrl-1 = <&pinctrl_pdm_sleep>;
+// 	assigned-clocks = <&scmi_clk IMX95_CLK_AUDIOPLL1_VCO>,
+// 			  <&scmi_clk IMX95_CLK_AUDIOPLL2_VCO>,
+// 			  <&scmi_clk IMX95_CLK_AUDIOPLL1>,
+// 			  <&scmi_clk IMX95_CLK_AUDIOPLL2>,
+// 			  <&scmi_clk IMX95_CLK_PDM>;
+// 	assigned-clock-parents = <0>, <0>, <0>, <0>,
+// 				 <&scmi_clk IMX95_CLK_AUDIOPLL1>;
+// 	assigned-clock-rates = <3932160000>,
+// 			       <3612672000>, <393216000>,
+// 			       <361267200>, <49152000>;
+// 	status = "okay";
 &mu7 {
 	status = "okay";
@@ -960,19 +960,19 @@ IMX95_PAD_GPIO_IO35__HSIOMIX_TOP_PCIE2_CLKREQ_B		0x4000031e
-	pinctrl_pdm: pdmgrp {
-		fsl,pins = <
-			IMX95_PAD_PDM_CLK__AONMIX_TOP_PDM_CLK				0x31e
-			IMX95_PAD_PDM_BIT_STREAM0__AONMIX_TOP_PDM_BIT_STREAM_BIT0	0x31e
+	// pinctrl_pdm: pdmgrp {
+	// 	fsl,pins = <
+	// 		IMX95_PAD_PDM_CLK__AONMIX_TOP_PDM_CLK				0x31e
+	// 		IMX95_PAD_PDM_BIT_STREAM0__AONMIX_TOP_PDM_BIT_STREAM_BIT0	0x31e
-	pinctrl_pdm_sleep: pdmsleepgrp {
-		fsl,pins = <
-			IMX95_PAD_PDM_CLK__AONMIX_TOP_GPIO1_IO_BIT8			0x51e
-			IMX95_PAD_PDM_BIT_STREAM0__AONMIX_TOP_GPIO1_IO_BIT9		0x51e
+	// pinctrl_pdm_sleep: pdmsleepgrp {
+	// 	fsl,pins = <
+	// 		IMX95_PAD_PDM_CLK__AONMIX_TOP_GPIO1_IO_BIT8			0x51e
+	// 		IMX95_PAD_PDM_BIT_STREAM0__AONMIX_TOP_GPIO1_IO_BIT9		0x51e
 	pinctrl_ptn5110: ptn5110grp {
 		fsl,pins = <
system manager modification:
diff --git a/configs/mx95evk.cfg b/configs/mx95evk.cfg
index 9250d02..6722097 100755
--- a/configs/mx95evk.cfg
+++ b/configs/mx95evk.cfg
@@ -389,7 +389,7 @@ SYS                       ALL
 # Resources
 M7P                 OWNER  # CPUs must be first
-CAN_FD1             OWNER
+// CAN_FD1             OWNER
 FSB                 READONLY
 IRQSTEER_M7         OWNER
 LPIT1               OWNER
@@ -612,6 +612,7 @@ CAMERA5             OWNER
 CAMERA6             OWNER
 CAMERA7             OWNER
 CAMERA8             OWNER
+CAN_FD1             OWNER
 CAN_FD2             OWNER
 CAN_FD3             OWNER
 CAN_FD4             OWNER
Result:
408 次查看
Zhiming_Liu
Hi @HenryHsu
dts modification:
+	status = "okay";
 &flexcan2 {
-&micfil {
-	status = "okay";
+// &micfil {
 &mu7 {
 	status = "okay";
-		fsl,pins = <
+	// 	fsl,pins = <
-		fsl,pins = <
+	// 	fsl,pins = <
 		fsl,pins = <
 # Resources
-CAN_FD1             OWNER
+// CAN_FD1             OWNER
 FSB                 READONLY
 IRQSTEER_M7         OWNER
 LPIT1               OWNER
 CAMERA6             OWNER
 CAMERA7             OWNER
 CAMERA8             OWNER
+CAN_FD1             OWNER
 CAN_FD2             OWNER
 CAN_FD3             OWNER
 CAN_FD4             OWNER
Result:
400 次查看
HenryHsu
Hi,Zhiming_Liu
Thank you for the reply.
you are right ,I need to change system manager config.
%3CLINGO-SUB%20id%3D%22lingo-sub-2402331%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EIMX95%20%E6%97%A0%E6%B3%95%E9%87%8D%E6%96%B0%E7%88%B6%E7%BA%A7%20can1%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2402331%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E6%88%91%E5%B0%9D%E8%AF%95%E5%90%AF%E7%94%A8%20can1%3C%2FP%3E%3CP%3E%E6%88%91%E7%9A%84%E8%AE%BE%E5%A4%87%E6%A0%91%E5%BC%95%E8%84%9A%E9%81%B5%E5%BE%AA%20imx95%20evk%EF%BC%8C%E5%B9%B6%E7%A6%81%E7%94%A8%20%26amp%3Bmicfil%3C%2FP%3E%3CP%3EIMX95_PAD_PDM_CLK__AONMIX_TOP_CAN1_TX%200x39e%3C%2FP%3E%3CP%3EIMX95_PAD_PDM_BIT_STREAM0__AONMIX_TOP_CAN1_RX%200x39e%3C%2FP%3E%3CP%3E%E4%BD%86%E6%98%AF%E5%87%BA%E7%8E%B0%E4%BA%86%E4%BB%A5%E4%B8%8B%E9%94%99%E8%AF%AF%E3%80%82%3C%2FP%3E%3CP%3E%5B%209.968941%5D%20CAN%20%E8%AE%BE%E5%A4%87%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%E6%8E%A5%E5%8F%A3%3CBR%20%2F%3E%5B%209.976800%5D%20scmi-pinctrl-imx%20scmi_dev.8%3A%E8%AE%BE%E7%BD%AE%E9%85%8D%E7%BD%AE%E9%94%99%E8%AF%AF%20-13%3CBR%20%2F%3E%20%5B%209.976814%5D%20scmi-pinctrl-imx%20scmi_dev.8%3Apin_config_set%20%E6%93%8D%E4%BD%9C%E5%AF%B9%E5%BC%95%E8%84%9A%20121%20%E5%A4%B1%E8%B4%A5%3CBR%20%2F%3E%5B%209.976893%5D%20clk%EF%BC%9A%E6%97%A0%E6%B3%95%E5%B0%86%20can1%20%E9%87%8D%E6%96%B0%E7%88%B6%E7%BA%A7%E8%AE%BE%E7%BD%AE%E4%B8%BA%20syspll1_pfd1_di%EF%BC%9A-1%3CBR%20%2F%3E%20%5B%209.978973%5D%20%E5%86%85%E9%83%A8%E9%94%99%E8%AF%AF%EF%BC%9A%E5%90%8C%E6%AD%A5%E5%A4%96%E9%83%A8%E4%B8%AD%E6%AD%A2%EF%BC%9A0000000096000010%20%5B%231%5D%20SMP%3CBR%20%2F%3E%20%5B9.978986%5D%E9%93%BE%E6%8E%A5%E7%9A%84%E6%A8%A1%E5%9D%97%EF%BC%9Aflexcan%EF%BC%88%2B%EF%BC%89can_dev%20neoisp%EF%BC%88%2B%EF%BC%89at24%20rpmsg_ctrl%20rpmsg_char%20pwm_fan%20enetc4_uio%EF%BC%88O%EF%BC%89fsl_ecat_enetc4%20fsl_ecat_enetc_core%20moal%EF%BC%88O%EF%BC%89mlan%EF%BC%88O%EF%BC%89%E7%86%94%E4%B8%9D%3CBR%20%2F%3E%5B%209.979017%5D%20CPU%3A%205%20UID%3A%200%20PID%3A%20357%20Comm%3A%20(udev-worker)%20Tainted%3A%20GMO%206.18.2-rt3-1.0.0-1.0.0%20%231%20PREEMPT_RT%3CBR%20%2F%3E%20%5B%209.979026%5D%20%E5%B7%B2%E6%B1%A1%E6%9F%93%EF%BC%9A%5BM%5D%3DMACHINE_CHECK%EF%BC%8C%5BO%5D%3DOOT_MODULE%3CBR%20%2F%3E%20%5B%209.979028%5D%20%E7%A1%AC%E4%BB%B6%E5%90%8D%E7%A7%B0%EF%BC%9AAxiomtek%20i.MX95%20scm136%20%E6%9D%BF%20(DT)%3CBR%20%2F%3E%20%5B9.979031%5D%20pstate%EF%BC%9A60400009%EF%BC%88nZCv%20daif%20%2BPAN%20-UAO%20-TCO%20-DIT%20-SSBS%20BTYPE%3D--%EF%BC%89%3CBR%20%2F%3E%20%5B%209.979035%5D%20pc%20%3A%20flexcan_read_le%2B0x0%2F0x20%20%5Bflexcan%5D%3CBR%20%2F%3E%20%5B%209.979060%5D%20lr%20%3A%20flexcan_probe%2B0x454%2F0x834%20%5Bflexcan%5D%3CBR%20%2F%3E%20%5B%209.979067%5D%20sp%20%3A%20ffff800086133820%3CBR%20%2F%3E%20%5B9.979069%5Dx29%EF%BC%9Affff800086133850%20x28%EF%BC%9Affff8000862b0000%20x27%EF%BC%9Affff000085a182a0%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FP%3E%3CP%3E%E6%9C%89%E4%BA%BA%E7%9F%A5%E9%81%93%E6%80%8E%E4%B9%88%E8%A7%A3%E5%86%B3%E8%BF%99%E4%B8%AA%E9%97%AE%E9%A2%98%E5%90%97%EF%BC%9F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2402396%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20IMX95%20failed%20to%20reparent%20can1%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2402396%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E5%97%A8%EF%BC%8C%E5%88%98%E5%BF%97%E6%98%8E%3C%2FP%3E%3CP%3E%E8%B0%A2%E8%B0%A2%E4%BD%A0%E7%9A%84%E5%9B%9E%E5%A4%8D%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3E%E4%BD%A0%E8%AF%B4%E5%BE%97%E5%AF%B9%EF%BC%8C%E6%88%91%E9%9C%80%E8%A6%81%E6%9B%B4%E6%94%B9%E7%B3%BB%E7%BB%9F%E7%AE%A1%E7%90%86%E5%99%A8%E9%85%8D%E7%BD%AE%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2402375%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20IMX95%20failed%20to%20reparent%20can1%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2402375%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E5%97%A8%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F232205%22%20target%3D%22_blank%22%3E%40HenryHsu%3C%2FA%3E%3C%2FP%3E%0A%3CDIV%3E%E8%BF%99%E6%98%AF%E6%88%91%E4%B9%8B%E5%89%8D%E5%9C%A8%20i.MX95%20EVK%20%E4%B8%8A%E7%9A%84%E6%B5%8B%E8%AF%95%E7%BB%93%E6%9E%9C%EF%BC%8C%E8%AF%B7%E6%A0%B9%E6%8D%AE%E4%BB%A5%E4%B8%8B%E4%BF%AE%E6%94%B9%E6%A3%80%E6%9F%A5%E6%82%A8%E7%9A%84%20dts%20%E6%96%87%E4%BB%B6%E3%80%82%3C%2FDIV%3E%0A%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%0A%3CDIV%3E%3CSTRONG%3Edts%E4%BF%AE%E6%94%B9%EF%BC%9A%3C%2FSTRONG%3E%3C%2FDIV%3E%0A%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%0A%3CDIV%3E%0A%3CDIV%20id%3D%22tinyMceEditorZhiming_Liu_0%22%20class%3D%22mceNonEditable%20lia-copypaste-placeholder%22%3E%26nbsp%3B%3C%2FDIV%3E%0A%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Zhiming_Liu_2-1785995739657.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Zhiming_Liu_2-1785995739657.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F393841i9B137A246C3FDBBD%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22Zhiming_Liu_2-1785995739657.png%22%20alt%3D%22Zhiming_Liu_2-1785995739657.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%0A%3CBR%20%2F%3E%0A%3C%2FDIV%3E%0A%3CDIV%3E%0A%3CPRE%20class%3D%22x_language-markup%20language-undefined%22%3E%3CCODE%20translate%3D%22no%22%3Ediff%20--git%20a%2Farch%2Farm64%2Fboot%2Fdts%2Ffreescale%2Fimx95-19x19-evk.dts%20b%2Farch%2Farm64%2Fboot%2Fdts%2Ffreescale%2Fimx95-19x19-evk.dts%0Aindex%20ab7bd4fdaadf..5eb3011f0894%20100644%0A---%20a%2Farch%2Farm64%2Fboot%2Fdts%2Ffreescale%2Fimx95-19x19-evk.dts%0A%2B%2B%2B%20b%2Farch%2Farm64%2Fboot%2Fdts%2Ffreescale%2Fimx95-19x19-evk.dts%0A%40%40%20-380%2C7%20%2B380%2C7%20%40%40%20%26amp%3Bflexcan1%20%7B%0A%20%09pinctrl-names%20%3D%20%22default%22%3B%0A%20%09pinctrl-0%20%3D%20%26lt%3B%26amp%3Bpinctrl_flexcan1%26gt%3B%3B%0A%20%09xceiver-supply%20%3D%20%26lt%3B%26amp%3Breg_can1_stby%26gt%3B%3B%0A-%09status%20%3D%20%22disabled%22%3B%0A%2B%09status%20%3D%20%22okay%22%3B%0A%20%7D%3B%0A%20%0A%20%26amp%3Bflexcan2%20%7B%0A%40%40%20-623%2C23%20%2B623%2C23%20%40%40%20spidev0%3A%20spi%400%20%7B%0A%20%09%7D%3B%0A%20%7D%3B%0A%20%0A-%26amp%3Bmicfil%20%7B%0A-%09%23sound-dai-cells%20%3D%20%26lt%3B0%26gt%3B%3B%0A-%09pinctrl-names%20%3D%20%22default%22%2C%20%22sleep%22%3B%0A-%09pinctrl-0%20%3D%20%26lt%3B%26amp%3Bpinctrl_pdm%26gt%3B%3B%0A-%09pinctrl-1%20%3D%20%26lt%3B%26amp%3Bpinctrl_pdm_sleep%26gt%3B%3B%0A-%09assigned-clocks%20%3D%20%26lt%3B%26amp%3Bscmi_clk%20IMX95_CLK_AUDIOPLL1_VCO%26gt%3B%2C%0A-%09%09%09%20%20%26lt%3B%26amp%3Bscmi_clk%20IMX95_CLK_AUDIOPLL2_VCO%26gt%3B%2C%0A-%09%09%09%20%20%26lt%3B%26amp%3Bscmi_clk%20IMX95_CLK_AUDIOPLL1%26gt%3B%2C%0A-%09%09%09%20%20%26lt%3B%26amp%3Bscmi_clk%20IMX95_CLK_AUDIOPLL2%26gt%3B%2C%0A-%09%09%09%20%20%26lt%3B%26amp%3Bscmi_clk%20IMX95_CLK_PDM%26gt%3B%3B%0A-%09assigned-clock-parents%20%3D%20%26lt%3B0%26gt%3B%2C%20%26lt%3B0%26gt%3B%2C%20%26lt%3B0%26gt%3B%2C%20%26lt%3B0%26gt%3B%2C%0A-%09%09%09%09%20%26lt%3B%26amp%3Bscmi_clk%20IMX95_CLK_AUDIOPLL1%26gt%3B%3B%0A-%09assigned-clock-rates%20%3D%20%26lt%3B3932160000%26gt%3B%2C%0A-%09%09%09%20%20%20%20%20%20%20%26lt%3B3612672000%26gt%3B%2C%20%26lt%3B393216000%26gt%3B%2C%0A-%09%09%09%20%20%20%20%20%20%20%26lt%3B361267200%26gt%3B%2C%20%26lt%3B49152000%26gt%3B%3B%0A-%09status%20%3D%20%22okay%22%3B%0A-%7D%3B%0A%2B%2F%2F%20%26amp%3Bmicfil%20%7B%0A%2B%2F%2F%20%09%23sound-dai-cells%20%3D%20%26lt%3B0%26gt%3B%3B%0A%2B%2F%2F%20%09pinctrl-names%20%3D%20%22default%22%2C%20%22sleep%22%3B%0A%2B%2F%2F%20%09pinctrl-0%20%3D%20%26lt%3B%26amp%3Bpinctrl_pdm%26gt%3B%3B%0A%2B%2F%2F%20%09pinctrl-1%20%3D%20%26lt%3B%26amp%3Bpinctrl_pdm_sleep%26gt%3B%3B%0A%2B%2F%2F%20%09assigned-clocks%20%3D%20%26lt%3B%26amp%3Bscmi_clk%20IMX95_CLK_AUDIOPLL1_VCO%26gt%3B%2C%0A%2B%2F%2F%20%09%09%09%20%20%26lt%3B%26amp%3Bscmi_clk%20IMX95_CLK_AUDIOPLL2_VCO%26gt%3B%2C%0A%2B%2F%2F%20%09%09%09%20%20%26lt%3B%26amp%3Bscmi_clk%20IMX95_CLK_AUDIOPLL1%26gt%3B%2C%0A%2B%2F%2F%20%09%09%09%20%20%26lt%3B%26amp%3Bscmi_clk%20IMX95_CLK_AUDIOPLL2%26gt%3B%2C%0A%2B%2F%2F%20%09%09%09%20%20%26lt%3B%26amp%3Bscmi_clk%20IMX95_CLK_PDM%26gt%3B%3B%0A%2B%2F%2F%20%09assigned-clock-parents%20%3D%20%26lt%3B0%26gt%3B%2C%20%26lt%3B0%26gt%3B%2C%20%26lt%3B0%26gt%3B%2C%20%26lt%3B0%26gt%3B%2C%0A%2B%2F%2F%20%09%09%09%09%20%26lt%3B%26amp%3Bscmi_clk%20IMX95_CLK_AUDIOPLL1%26gt%3B%3B%0A%2B%2F%2F%20%09assigned-clock-rates%20%3D%20%26lt%3B3932160000%26gt%3B%2C%0A%2B%2F%2F%20%09%09%09%20%20%20%20%20%20%20%26lt%3B3612672000%26gt%3B%2C%20%26lt%3B393216000%26gt%3B%2C%0A%2B%2F%2F%20%09%09%09%20%20%20%20%20%20%20%26lt%3B361267200%26gt%3B%2C%20%26lt%3B49152000%26gt%3B%3B%0A%2B%2F%2F%20%09status%20%3D%20%22okay%22%3B%0A%2B%2F%2F%20%7D%3B%0A%20%0A%20%26amp%3Bmu7%20%7B%0A%20%09status%20%3D%20%22okay%22%3B%0A%40%40%20-960%2C19%20%2B960%2C19%20%40%40%20IMX95_PAD_GPIO_IO35__HSIOMIX_TOP_PCIE2_CLKREQ_B%09%090x4000031e%0A%20%09%09%26gt%3B%3B%0A%20%09%7D%3B%0A%20%0A-%09pinctrl_pdm%3A%20pdmgrp%20%7B%0A-%09%09fsl%2Cpins%20%3D%20%26lt%3B%0A-%09%09%09IMX95_PAD_PDM_CLK__AONMIX_TOP_PDM_CLK%09%09%09%090x31e%0A-%09%09%09IMX95_PAD_PDM_BIT_STREAM0__AONMIX_TOP_PDM_BIT_STREAM_BIT0%090x31e%0A-%09%09%26gt%3B%3B%0A-%09%7D%3B%0A%2B%09%2F%2F%20pinctrl_pdm%3A%20pdmgrp%20%7B%0A%2B%09%2F%2F%20%09fsl%2Cpins%20%3D%20%26lt%3B%0A%2B%09%2F%2F%20%09%09IMX95_PAD_PDM_CLK__AONMIX_TOP_PDM_CLK%09%09%09%090x31e%0A%2B%09%2F%2F%20%09%09IMX95_PAD_PDM_BIT_STREAM0__AONMIX_TOP_PDM_BIT_STREAM_BIT0%090x31e%0A%2B%09%2F%2F%20%09%26gt%3B%3B%0A%2B%09%2F%2F%20%7D%3B%0A%20%0A-%09pinctrl_pdm_sleep%3A%20pdmsleepgrp%20%7B%0A-%09%09fsl%2Cpins%20%3D%20%26lt%3B%0A-%09%09%09IMX95_PAD_PDM_CLK__AONMIX_TOP_GPIO1_IO_BIT8%09%09%090x51e%0A-%09%09%09IMX95_PAD_PDM_BIT_STREAM0__AONMIX_TOP_GPIO1_IO_BIT9%09%090x51e%0A-%09%09%26gt%3B%3B%0A-%09%7D%3B%0A%2B%09%2F%2F%20pinctrl_pdm_sleep%3A%20pdmsleepgrp%20%7B%0A%2B%09%2F%2F%20%09fsl%2Cpins%20%3D%20%26lt%3B%0A%2B%09%2F%2F%20%09%09IMX95_PAD_PDM_CLK__AONMIX_TOP_GPIO1_IO_BIT8%09%09%090x51e%0A%2B%09%2F%2F%20%09%09IMX95_PAD_PDM_BIT_STREAM0__AONMIX_TOP_GPIO1_IO_BIT9%09%090x51e%0A%2B%09%2F%2F%20%09%26gt%3B%3B%0A%2B%09%2F%2F%20%7D%3B%0A%20%0A%20%09pinctrl_ptn5110%3A%20ptn5110grp%20%7B%0A%20%09%09fsl%2Cpins%20%3D%20%26lt%3B%3C%2FCODE%3E%3C%2FPRE%3E%0A%3C%2FDIV%3E%0A%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%0A%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%0A%3CDIV%3E%3CSTRONG%3E%E7%B3%BB%E7%BB%9F%E7%AE%A1%E7%90%86%E5%99%A8%E4%BF%AE%E6%94%B9%EF%BC%9A%3C%2FSTRONG%3E%3C%2FDIV%3E%0A%3CDIV%3E%0A%3CPRE%20class%3D%22x_language-markup%20language-undefined%22%3E%3CCODE%20translate%3D%22no%22%3Ediff%20--git%20a%2Fconfigs%2Fmx95evk.cfg%20b%2Fconfigs%2Fmx95evk.cfg%0Aindex%209250d02..6722097%20100755%0A---%20a%2Fconfigs%2Fmx95evk.cfg%0A%2B%2B%2B%20b%2Fconfigs%2Fmx95evk.cfg%0A%40%40%20-389%2C7%20%2B389%2C7%20%40%40%20SYS%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20ALL%0A%20%23%20Resources%0A%20%0A%20M7P%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20OWNER%20%20%23%20CPUs%20must%20be%20first%0A-CAN_FD1%20%20%20%20%20%20%20%20%20%20%20%20%20OWNER%0A%2B%2F%2F%20CAN_FD1%20%20%20%20%20%20%20%20%20%20%20%20%20OWNER%0A%20FSB%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20READONLY%0A%20IRQSTEER_M7%20%20%20%20%20%20%20%20%20OWNER%0A%20LPIT1%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20OWNER%0A%40%40%20-612%2C6%20%2B612%2C7%20%40%40%20CAMERA5%20%20%20%20%20%20%20%20%20%20%20%20%20OWNER%0A%20CAMERA6%20%20%20%20%20%20%20%20%20%20%20%20%20OWNER%0A%20CAMERA7%20%20%20%20%20%20%20%20%20%20%20%20%20OWNER%0A%20CAMERA8%20%20%20%20%20%20%20%20%20%20%20%20%20OWNER%0A%2BCAN_FD1%20%20%20%20%20%20%20%20%20%20%20%20%20OWNER%0A%20CAN_FD2%20%20%20%20%20%20%20%20%20%20%20%20%20OWNER%0A%20CAN_FD3%20%20%20%20%20%20%20%20%20%20%20%20%20OWNER%0A%20CAN_FD4%20%20%20%20%20%20%20%20%20%20%20%20%20OWNER%3C%2FCODE%3E%3C%2FPRE%3E%0A%3C%2FDIV%3E%0A%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%0A%3CDIV%3E%E7%BB%93%E6%9E%9C%EF%BC%9A%3C%2FDIV%3E%0A%3CDIV%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Zhiming_Liu_3-1785995783165.png%22%20style%3D%22width%3A%20655px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Zhiming_Liu_3-1785995783165.png%22%20style%3D%22width%3A%20655px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F393842i8685179C00E2C53D%2Fimage-dimensions%2F655x254%3Fv%3Dv2%22%20width%3D%22655%22%20height%3D%22254%22%20role%3D%22button%22%20title%3D%22Zhiming_Liu_3-1785995783165.png%22%20alt%3D%22Zhiming_Liu_3-1785995783165.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%0A%3CBR%20%2F%3E%0A%3C%2FDIV%3E%0A%3CDIV%3E%0A%3CDIV%20id%3D%22tinyMceEditorZhiming_Liu_1%22%20class%3D%22mceNonEditable%20lia-copypaste-placeholder%22%3E%26nbsp%3B%3C%2FDIV%3E%0A%3CBR%20%2F%3E%0A%3C%2FDIV%3E%3C%2FLINGO-BODY%3E
