IMX93 custom board ethernet dts changes
1,433件の閲覧回数
vijay1251
we are using imx93 where the 2 ethernet port lines are connected to  2 DP83867ERGZT
give the proper dts changes for custom board , where reset pin we are using for gpio2_io09 and gpio2_io10
#imx93
#DP83867ERGZT
1,257件の閲覧回数
vijay1251
hi joseph,
The below dts node changes is working fine in custom.
&eqos {
pinctrl-names = "default";
pinctrl-0 = <&pinctrl_eqos>;
phy-mode = "rgmii-id";
phy-handle = <&ethphy_eqos>;
status = "okay";
mdio {
compatible = "snps,dwmac-mdio";
#address-cells = <1>;
#size-cells = <0>;
ethphy_eqos: ethernet-phy@0 {
compatible = "ethernet-phy-ieee802.3-c22";
reg = <0>;
pinctrl-0 = <&pinctrl_eqos_phy>;
interrupt-parent = <&gpi:wqo3>;
interrupts = <26 IRQ_TYPE_EDGE_FALLING>;
reset-gpios = <&expander1 0 GPIO_ACTIVE_LOW>;
reset-assert-us = <500000>;
reset-deassert-us = <50000>;
enet-phy-lane-no-swap;
ti,rx-internal-delay = <DP83867_RGMIIDCTL_2_25_NS>;
ti,tx-internal-delay = <DP83867_RGMIIDCTL_2_25_NS>;
ti,fifo-depth = <DP83867_PHYCR_FIFO_DEPTH_4_B_NIB>;
ti,dp83867-rxctrl-strap-quirk;
ti,clk-output-sel = <DP83867_CLK_O_SEL_OFF>;
&fec {
pinctrl-0 = <&pinctrl_fec>;
phy-handle = <&ethphy_fec>;
fsl,magic-packet;
status = "okay";
mdio {
#size-cells = <0>;
clock-frequency = <5000000>;
ethphy_fec: ethernet-phy@0 {
reg = <0>;
pinctrl-0 = <&pinctrl_fec_phy>;
interrupt-parent = <&gpio3>;
interrupts = <27 IRQ_TYPE_EDGE_FALLING>;
reset-gpios = <&expander1 1 GPIO_ACTIVE_LOW>;
#imx93 #dp38367
3 返答(返信)
1,314件の閲覧回数
JosephAtNXP
Thank you for your interest in NXP Semiconductor products,
First step is to confirm that your pin group matches EVK/FRDM so you can copy their pin group and pad configuration, if you are using RGMII most of the group will be reused.
Another important key is to know your MDIO topology, EVK/FRDM uses two MDIO buses to manage one PHY, if you used one bus to manage both, you will need to change DTS,
For module and PHY DTS, I can suggest this:
&eqos {
	pinctrl-names = "default", "sleep";
	pinctrl-1 = <&pinctrl_eqos_sleep>;
// Depends on your PHY address
	phy-handle = <&ethphy1>;
	status = "okay";
	mdio {
		#size-cells = <0>;
		ethphy1: ethernet-phy@1 {
			reg = <1>;
                        eee-broken-1000t;
			reset-gpios = <&gpio 2 9 GPIO_ACTIVE_LOW>;
			reset-assert-us = <10000>;
			reset-deassert-us = <80000>;
&fec {
	pinctrl-1 = <&pinctrl_fec_sleep>;
	phy-handle = <&ethphy2>;
	fsl,magic-packet;
	status = "okay";
	mdio {
		#size-cells = <0>;
		ethphy2: ethernet-phy@2 {
			reg = <2>;
			eee-broken-1000t;
			reset-gpios = <&gpio2 10 GPIO_ACTIVE_LOW>;
1,258件の閲覧回数
vijay1251
hi joseph,
&eqos {
status = "okay";
mdio {
#size-cells = <0>;
reg = <0>;
&fec {
fsl,magic-packet;
status = "okay";
mdio {
#size-cells = <0>;
reg = <0>;
#imx93 #dp38367
1,389件の閲覧回数
vijay1251
Hi jikehal
Thanks for your response.
I expect some reference node details.I didn't expect this kind of reply. May be you can say things in polite way.
%3CLINGO-SUB%20id%3D%22lingo-sub-2320962%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EIMX93%E3%82%AB%E3%82%B9%E3%82%BF%E3%83%A0%E3%83%9C%E3%83%BC%E3%83%89%E3%81%AE%E3%82%A4%E3%83%BC%E3%82%B5%E3%83%8D%E3%83%83%E3%83%88DTS%E3%81%AE%E5%A4%89%E6%9B%B4%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2320962%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E2%E3%81%A4%E3%81%AE%E3%82%A4%E3%83%BC%E3%82%B5%E3%83%8D%E3%83%83%E3%83%88%E3%83%9D%E3%83%BC%E3%83%88%E3%83%A9%E3%82%A4%E3%83%B3%E3%81%8C2%E3%81%A4%E3%81%AEDP83867ERGZT%E3%81%AB%E6%8E%A5%E7%B6%9A%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8Bimx93%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%20gpio2_io09%20%E3%81%A8%20gpio2_io10%20%E3%81%AB%E3%83%AA%E3%82%BB%E3%83%83%E3%83%88%E3%83%94%E3%83%B3%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E3%82%AB%E3%82%B9%E3%82%BF%E3%83%A0%E3%83%9C%E3%83%BC%E3%83%89%E3%81%AB%E9%81%A9%E5%88%87%E3%81%AA%20dts%20%E5%A4%89%E6%9B%B4%E3%82%92%E5%8A%A0%E3%81%88%E3%81%BE%E3%81%99%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FP%3E%3CP%3E%23imx93%3C%2FP%3E%3CP%3E%23DP83867ERGZT%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2321490%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20IMX93%20custom%20board%20ethernet%20dts%20changes%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2321490%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%3C%2FP%3E%0A%3CP%3ENXP%20Semiconductors%E8%A3%BD%E5%93%81%E3%81%AB%E3%81%94%E8%88%88%E5%91%B3%E3%82%92%E3%81%8A%E6%8C%81%E3%81%A1%E3%81%84%E3%81%9F%E3%81%A0%E3%81%8D%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%E6%9C%80%E5%88%9D%E3%81%AE%E3%82%B9%E3%83%86%E3%83%83%E3%83%97%E3%81%AF%E3%80%81%E3%83%94%E3%83%B3%20%E3%82%B0%E3%83%AB%E3%83%BC%E3%83%97%E3%81%8C%20EVK%2FFRDM%20%E3%81%A8%E4%B8%80%E8%87%B4%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E3%81%93%E3%81%A8%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%97%E3%80%81%E3%81%9D%E3%81%AE%E3%83%94%E3%83%B3%20%E3%82%B0%E3%83%AB%E3%83%BC%E3%83%97%E3%81%A8%E3%83%91%E3%83%83%E3%83%89%E6%A7%8B%E6%88%90%E3%82%92%E3%82%B3%E3%83%94%E3%83%BC%E3%81%A7%E3%81%8D%E3%82%8B%E3%82%88%E3%81%86%E3%81%AB%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%81%A7%E3%81%99%E3%80%82RGMII%20%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E5%A0%B4%E5%90%88%E3%81%AF%E3%80%81%E3%82%B0%E3%83%AB%E3%83%BC%E3%83%97%E3%81%AE%E5%A4%A7%E9%83%A8%E5%88%86%E3%81%8C%E5%86%8D%E5%88%A9%E7%94%A8%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%E3%82%82%E3%81%86%E4%B8%80%E3%81%A4%E3%81%AE%E9%87%8D%E8%A6%81%E3%81%AA%E9%8D%B5%E3%81%AF%E3%80%81MDIO%E3%83%88%E3%83%9D%E3%83%AD%E3%82%B8%E3%83%BC%E3%82%92%E7%9F%A5%E3%82%8B%E3%81%93%E3%81%A8%E3%81%A7%E3%81%99%E3%80%82EVK%2FFRDM%E3%81%AF1%E3%81%A4%E3%81%AEPHY%E3%82%92%E7%AE%A1%E7%90%86%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AB2%E3%81%A4%E3%81%AEMDIO%E3%83%90%E3%82%B9%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%BE%E3%81%99%E3%80%821%E3%81%A4%E3%81%AE%E3%83%90%E3%82%B9%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E4%B8%A1%E6%96%B9%E3%82%92%E7%AE%A1%E7%90%86%E3%81%97%E3%81%A6%E3%81%84%E3%81%9F%E5%A0%B4%E5%90%88%E3%81%AF%E3%80%81DTS%E3%82%92%E5%A4%89%E6%9B%B4%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%E3%83%A2%E3%82%B8%E3%83%A5%E3%83%BC%E3%83%AB%E3%81%A8%20PHY%20DTS%20%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%E3%81%AF%E3%80%81%E6%AC%A1%E3%81%AE%E3%81%93%E3%81%A8%E3%82%92%E3%81%8A%E5%8B%A7%E3%82%81%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CPRE%20class%3D%22lia-code-sample%20language-markup%22%3E%3CCODE%20translate%3D%22no%22%3E%26amp%3Beqos%20%7B%0A%09pinctrl-names%20%3D%20%22default%22%2C%20%22sleep%22%3B%0A%09pinctrl-0%20%3D%20%26lt%3B%26amp%3Bpinctrl_eqos%26gt%3B%3B%0A%09pinctrl-1%20%3D%20%26lt%3B%26amp%3Bpinctrl_eqos_sleep%26gt%3B%3B%0A%09phy-mode%20%3D%20%22rgmii-id%22%3B%0A%2F%2F%20Depends%20on%20your%20PHY%20address%0A%09phy-handle%20%3D%20%26lt%3B%26amp%3Bethphy1%26gt%3B%3B%0A%09status%20%3D%20%22okay%22%3B%0A%0A%09mdio%20%7B%0A%09%09compatible%20%3D%20%22snps%2Cdwmac-mdio%22%3B%0A%09%09%23address-cells%20%3D%20%26lt%3B1%26gt%3B%3B%0A%09%09%23size-cells%20%3D%20%26lt%3B0%26gt%3B%3B%0A%09%09clock-frequency%20%3D%20%26lt%3B5000000%26gt%3B%3B%0A%0A%2F%2F%20Depends%20on%20your%20PHY%20address%0A%09%09ethphy1%3A%20ethernet-phy%401%20%7B%0A%09%09%09reg%20%3D%20%26lt%3B1%26gt%3B%3B%0A%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20eee-broken-1000t%3B%0A%09%09%09reset-gpios%20%3D%20%26lt%3B%26amp%3Bgpio%202%209%20GPIO_ACTIVE_LOW%26gt%3B%3B%0A%09%09%09reset-assert-us%20%3D%20%26lt%3B10000%26gt%3B%3B%0A%09%09%09reset-deassert-us%20%3D%20%26lt%3B80000%26gt%3B%3B%0A%09%09%7D%3B%0A%09%7D%3B%0A%7D%3B%0A%0A%26amp%3Bfec%20%7B%0A%09pinctrl-names%20%3D%20%22default%22%2C%20%22sleep%22%3B%0A%09pinctrl-0%20%3D%20%26lt%3B%26amp%3Bpinctrl_fec%26gt%3B%3B%0A%09pinctrl-1%20%3D%20%26lt%3B%26amp%3Bpinctrl_fec_sleep%26gt%3B%3B%0A%09phy-mode%20%3D%20%22rgmii-id%22%3B%0A%09phy-handle%20%3D%20%26lt%3B%26amp%3Bethphy2%26gt%3B%3B%0A%09fsl%2Cmagic-packet%3B%0A%09status%20%3D%20%22okay%22%3B%0A%0A%09mdio%20%7B%0A%09%09%23address-cells%20%3D%20%26lt%3B1%26gt%3B%3B%0A%09%09%23size-cells%20%3D%20%26lt%3B0%26gt%3B%3B%0A%09%09clock-frequency%20%3D%20%26lt%3B5000000%26gt%3B%3B%0A%0A%09%09ethphy2%3A%20ethernet-phy%402%20%7B%0A%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20compatible%20%3D%20%22ethernet-phy-ieee802.3-c22%22%3B%0A%09%09%09reg%20%3D%20%26lt%3B2%26gt%3B%3B%0A%09%09%09eee-broken-1000t%3B%0A%09%09%09reset-gpios%20%3D%20%26lt%3B%26amp%3Bgpio2%2010%20GPIO_ACTIVE_LOW%26gt%3B%3B%0A%09%09%09reset-assert-us%20%3D%20%26lt%3B10000%26gt%3B%3B%0A%09%09%09reset-deassert-us%20%3D%20%26lt%3B80000%26gt%3B%3B%0A%09%09%7D%3B%0A%09%7D%3B%0A%7D%3B%3C%2FCODE%3E%3C%2FPRE%3E%0A%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2321017%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20IMX93%20custom%20board%20ethernet%20dts%20changes%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2321017%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%E3%82%B8%E3%82%B1%E3%83%8F%E3%83%AB%3CBR%20%2F%3E%E3%81%94%E8%BF%94%E4%BF%A1%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%E5%8F%82%E7%85%A7%E3%83%8E%E3%83%BC%E3%83%89%E3%81%AE%E8%A9%B3%E7%B4%B0%E3%82%92%E3%81%84%E3%81%8F%E3%81%A4%E3%81%8B%E6%9C%9F%E5%BE%85%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E3%81%93%E3%81%AE%E3%82%88%E3%81%86%E3%81%AA%E8%BF%94%E4%BF%A1%E3%81%AF%E4%BA%88%E6%83%B3%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%E3%81%A7%E3%81%97%E3%81%9F%E3%80%82%E4%B8%81%E5%AF%A7%E3%81%AA%E8%A8%80%E3%81%84%E6%96%B9%E3%81%A7%E7%89%A9%E4%BA%8B%E3%82%92%E8%A8%80%E3%81%88%E3%82%8B%E3%81%8B%E3%82%82%E3%81%97%E3%82%8C%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2320990%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20IMX93%20custom%20board%20ethernet%20dts%20changes%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2320990%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%8C%E3%81%8C%E3%81%82%E3%81%AA%E3%81%9F%E3%81%8C%E3%82%84%E3%82%8B%E3%81%B9%E3%81%8D%E4%BB%95%E4%BA%8B%E3%81%A7%E3%81%AF%E3%81%AA%E3%81%84%E3%81%AE%E3%81%A7%E3%81%99%E3%81%8B%3F%E3%82%A8%E3%83%B3%E3%82%B8%E3%83%8B%E3%82%A2%E3%81%A8%E3%81%97%E3%81%A6%E3%81%82%E3%81%AA%E3%81%9F%E3%82%92%E6%81%A5%E3%81%98%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2325417%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20IMX93%20custom%20board%20ethernet%20dts%20changes%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2325417%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%E3%82%B8%E3%83%A7%E3%82%BB%E3%83%95%3C%2FP%3E%3CP%3E%E4%BB%A5%E4%B8%8B%E3%81%AE%20dts%20%E3%83%8E%E3%83%BC%E3%83%89%E3%81%AE%E5%A4%89%E6%9B%B4%E3%81%AF%E3%82%AB%E3%82%B9%E3%82%BF%E3%83%A0%E3%81%A7%E6%AD%A3%E5%B8%B8%E3%81%AB%E6%A9%9F%E8%83%BD%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%3C%2FP%3E%3CP%3E%26amp%3Beqos%20%7B%3CBR%20%2F%3E%20pinctrl-names%20%3D%20%22%E3%83%87%E3%83%95%E3%82%A9%E3%83%AB%E3%83%88%22%3B%3CBR%20%2F%3E%20pinctrl-0%20%3D%20%26lt%3B%26amp%3Bpinctrl_eqos%26gt%3B%3B%3CBR%20%2F%3E%20phy-mode%20%3D%20%22rgmii-id%22%3B%3CBR%20%2F%3E%20phy-handle%20%3D%20%26lt%3B%26amp%3Bethphy_eqos%26gt%3B%3B%3CBR%20%2F%3E%E3%82%B9%E3%83%86%E3%83%BC%E3%82%BF%E3%82%B9%20%3D%20%22%E6%AD%A3%E5%B8%B8%22%3B%3C%2FP%3E%3CP%3E%E3%83%A1%E3%83%87%E3%82%A3%E3%82%AA%20%7B%3CBR%20%2F%3E%E4%BA%92%E6%8F%9B%E6%80%A7%20%3D%20%22snps%2Cdwmac-mdio%22%3B%3CBR%20%2F%3E%20%23%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%E3%82%BB%E3%83%AB%20%3D%20%26lt%3B1%26gt%3B%3B%3CBR%20%2F%3E%20%23%E3%82%BB%E3%83%AB%E3%82%B5%E3%82%A4%E3%82%BA%20%3D%20%26lt%3B0%26gt%3B%3B%3C%2FP%3E%3CP%3Eethphy_eqos%3A%20%E3%82%A4%E3%83%BC%E3%82%B5%E3%83%8D%E3%83%83%E3%83%88-phy%400%20%7B%3CBR%20%2F%3E%E4%BA%92%E6%8F%9B%E6%80%A7%20%3D%20%22%E3%82%A4%E3%83%BC%E3%82%B5%E3%83%8D%E3%83%83%E3%83%88-phy-ieee802.3-c22%22%3B%3CBR%20%2F%3E%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF%20%3D%20%26lt%3B0%26gt%3B%3B%3CBR%20%2F%3E%20pinctrl-names%20%3D%20%22%E3%83%87%E3%83%95%E3%82%A9%E3%83%AB%E3%83%88%22%3B%3CBR%20%2F%3E%20pinctrl-0%20%3D%20%26lt%3B%26amp%3Bpinctrl_eqos_phy%26gt%3B%3B%3CBR%20%2F%3E%E5%89%B2%E3%82%8A%E8%BE%BC%E3%81%BF%E8%A6%AA%20%3D%20%26lt%3B%26amp%3Bgpi%3Awqo3%26gt%3B%3B%3CBR%20%2F%3E%E5%89%B2%E3%82%8A%E8%BE%BC%E3%81%BF%20%3D%20%26lt%3B26%20IRQ_TYPE_EDGE_FALLING%26gt%3B%3B%3CBR%20%2F%3E%20reset-gpios%20%3D%20%26lt%3B%26amp%3Bexpander1%200%20GPIO_ACTIVE_LOW%26gt%3B%3B%3CBR%20%2F%3E%E3%83%AA%E3%82%BB%E3%83%83%E3%83%88%E3%82%A2%E3%82%B5%E3%83%BC%E3%83%88US%20%3D%20%26lt%3B500000%26gt%3B%3B%3CBR%20%2F%3E%E3%83%AA%E3%82%BB%E3%83%83%E3%83%88%E3%83%87%E3%82%A2%E3%82%B5%E3%83%BC%E3%83%88US%20%3D%20%26lt%3B50000%26gt%3B%3B%3CBR%20%2F%3E%20enet-phy-lane-no-swap%3B%3CBR%20%2F%3E%20ti%E3%80%81rx%E5%86%85%E9%83%A8%E9%81%85%E5%BB%B6%20%3D%20%3CDP83867_RGMIIDCTL_2_25_NS%3E%3B%3CBR%20%2F%3E%20ti%E3%80%81tx%E5%86%85%E9%83%A8%E9%81%85%E5%BB%B6%20%3D%20%3CDP83867_RGMIIDCTL_2_25_NS%3E%3B%3CBR%20%2F%3E%20ti%E3%80%81fifo%20%E6%B7%B1%E5%BA%A6%20%3D%20%3CDP83867_PHYCR_FIFO_DEPTH_4_B_NIB%3E%3B%3CBR%20%2F%3E%20ti%E3%80%81dp83867-rxctrl-%E3%82%B9%E3%83%88%E3%83%A9%E3%83%83%E3%83%97%E3%81%AE%E7%99%96%3B%3CBR%20%2F%3E%20ti%E3%80%81clk-output-sel%20%3D%20%3CDP83867_CLK_O_SEL_OFF%3E%3B%3CBR%20%2F%3E%20%7D%3B%3CBR%20%2F%3E%20%7D%3B%3CBR%20%2F%3E%20%7D%3B%3C%2FDP83867_CLK_O_SEL_OFF%3E%3C%2FDP83867_PHYCR_FIFO_DEPTH_4_B_NIB%3E%3C%2FDP83867_RGMIIDCTL_2_25_NS%3E%3C%2FDP83867_RGMIIDCTL_2_25_NS%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%26amp%3Bfec%20%7B%3CBR%20%2F%3E%20pinctrl-names%20%3D%20%22%E3%83%87%E3%83%95%E3%82%A9%E3%83%AB%E3%83%88%22%3B%3CBR%20%2F%3E%20pinctrl-0%20%3D%20%26lt%3B%26amp%3Bpinctrl_fec%26gt%3B%3B%3CBR%20%2F%3E%20phy-mode%20%3D%20%22rgmii-id%22%3B%3CBR%20%2F%3E%20phy-handle%20%3D%20%26lt%3B%26amp%3Bethphy_fec%26gt%3B%3B%3CBR%20%2F%3E%20fsl%E3%80%81%E3%83%9E%E3%82%B8%E3%83%83%E3%82%AF%E3%83%91%E3%82%B1%E3%83%83%E3%83%88%3B%3CBR%20%2F%3E%E3%82%B9%E3%83%86%E3%83%BC%E3%82%BF%E3%82%B9%20%3D%20%22%E6%AD%A3%E5%B8%B8%22%3B%3C%2FP%3E%3CP%3E%E3%83%A1%E3%83%87%E3%82%A3%E3%82%AA%20%7B%3CBR%20%2F%3E%20%23%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%E3%82%BB%E3%83%AB%20%3D%20%26lt%3B1%26gt%3B%3B%3CBR%20%2F%3E%20%23%E3%82%BB%E3%83%AB%E3%82%B5%E3%82%A4%E3%82%BA%20%3D%20%26lt%3B0%26gt%3B%3B%3CBR%20%2F%3E%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%E5%91%A8%E6%B3%A2%E6%95%B0%20%3D%20%26lt%3B5000000%26gt%3B%3B%3C%2FP%3E%3CP%3Eethphy_fec%3A%20%E3%82%A4%E3%83%BC%E3%82%B5%E3%83%8D%E3%83%83%E3%83%88-phy%400%20%7B%3CBR%20%2F%3E%E4%BA%92%E6%8F%9B%E6%80%A7%20%3D%20%22%E3%82%A4%E3%83%BC%E3%82%B5%E3%83%8D%E3%83%83%E3%83%88-phy-ieee802.3-c22%22%3B%3CBR%20%2F%3E%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF%20%3D%20%26lt%3B0%26gt%3B%3B%3CBR%20%2F%3E%20pinctrl-names%20%3D%20%22%E3%83%87%E3%83%95%E3%82%A9%E3%83%AB%E3%83%88%22%3B%3CBR%20%2F%3E%20pinctrl-0%20%3D%20%26lt%3B%26amp%3Bpinctrl_fec_phy%26gt%3B%3B%3CBR%20%2F%3E%E5%89%B2%E3%82%8A%E8%BE%BC%E3%81%BF%E8%A6%AA%20%3D%20%26lt%3B%26amp%3Bgpio3%26gt%3B%3B%3CBR%20%2F%3E%E5%89%B2%E3%82%8A%E8%BE%BC%E3%81%BF%20%3D%20%26lt%3B27%20IRQ_TYPE_EDGE_FALLING%26gt%3B%3B%3CBR%20%2F%3E%20reset-gpios%20%3D%20%26lt%3B%26amp%3Bexpander1%201%20GPIO_ACTIVE_LOW%26gt%3B%3B%3CBR%20%2F%3E%E3%83%AA%E3%82%BB%E3%83%83%E3%83%88%E3%82%A2%E3%82%B5%E3%83%BC%E3%83%88US%20%3D%20%26lt%3B500000%26gt%3B%3B%3CBR%20%2F%3E%E3%83%AA%E3%82%BB%E3%83%83%E3%83%88%E3%83%87%E3%82%A2%E3%82%B5%E3%83%BC%E3%83%88US%20%3D%20%26lt%3B50000%26gt%3B%3B%3CBR%20%2F%3E%20enet-phy-lane-no-swap%3B%3CBR%20%2F%3E%20ti%E3%80%81rx%E5%86%85%E9%83%A8%E9%81%85%E5%BB%B6%20%3D%20%3CDP83867_RGMIIDCTL_2_25_NS%3E%3B%3CBR%20%2F%3E%20ti%E3%80%81tx%E5%86%85%E9%83%A8%E9%81%85%E5%BB%B6%20%3D%20%3CDP83867_RGMIIDCTL_2_25_NS%3E%3B%3CBR%20%2F%3E%20ti%E3%80%81fifo%20%E6%B7%B1%E5%BA%A6%20%3D%20%3CDP83867_PHYCR_FIFO_DEPTH_4_B_NIB%3E%3B%3CBR%20%2F%3E%20ti%E3%80%81dp83867-rxctrl-%E3%82%B9%E3%83%88%E3%83%A9%E3%83%83%E3%83%97%E3%81%AE%E7%99%96%3B%3CBR%20%2F%3E%20ti%E3%80%81clk-output-sel%20%3D%20%3CDP83867_CLK_O_SEL_OFF%3E%3B%3CBR%20%2F%3E%20%7D%3B%3CBR%20%2F%3E%20%7D%3B%3CBR%20%2F%3E%20%7D%3B%3C%2FDP83867_CLK_O_SEL_OFF%3E%3C%2FDP83867_PHYCR_FIFO_DEPTH_4_B_NIB%3E%3C%2FDP83867_RGMIIDCTL_2_25_NS%3E%3C%2FDP83867_RGMIIDCTL_2_25_NS%3E%3C%2FP%3E%3CP%3E%23imx93%20%23dp38367%3C%2FP%3E%3C%2FLINGO-BODY%3E
