IMX93 SAI3 FSYNC
IMX93 SAI3 FSYNC
1,381件の閲覧回数
KMES
I'm using i.MX93 SAI3 audio interface to control "ADS8354" ADC with the following settings:
  • External clock 20 MHz
clock_root_config_t saiClkCfg = {
.clockOff = true,
.mux = kCLOCK_SAI3_ClockRoot_MuxExt,
.div = 1,
  • SAI3 configuration
sai_transceiver_t saiConfig;
SAI_GetClassicI2SConfig(saiConfig,kSAI_WordWidth16bits,kSAI_Stereo,0x01);
saiConfig.bitClock.bclkPolarity = kSAI_SampleOnFallingEdge;
saiConfig.serialData.dataWord0Length = 18;
saiConfig.frameSync.frameSyncWidth = 2;
saiConfig.serialData.dataWordNum      = 3;
saiConfig.frameSync.frameSyncEarly    = false;
saiConfig.frameSync.frameSyncPolarity = kSAI_PolarityActiveHigh;
SAI_TxSetConfig(SAI3, &g_saiConfig);
g_saiConfig.masterSlave = kSAI_Master;
g_saiConfig.syncMode = kSAI_ModeSync;
SAI_RxSetConfig(SAI3, &g_saiConfig);
SAI_TxSetBitClockRate(SAI3, 20000000, 400000, 50, 1);
SAI_RxSetBitClockRate(SAI3, 20000000, 400000, 50, 1);
target FSYNC/ADC_CS frequency: 400 KHz = 20Mhz / (18 bits + 2x16bits) = 20000000/50
Measured FSYNC/ADC_CS frequency: 200 KHz
Question: How can I generate an FSYNC/ADC_CS signal at 400 kHz with a frame length of 50 bits and 20 MHz external clock ?
NB: Worked properly using a 40 MHz external clock
M33 SDK version: SDK_2_14_0_MCIMX93-EVK
タグ(2)
3 返答(返信)
1,279件の閲覧回数
KMES
Yes with TDM mode.
PS: SYWD[8:12] of RCR4/TRC4 equal 0 (1 bit-clock cycle)
saiConfig.frameSync.frameSyncWidth = 1;
1,211件の閲覧回数
joanxie
sorry for my delay, I took my AL this week, since you use TDM mode, but the SAI_GetClassicI2SConfig is for I2S mode, and you only set one channel according to the function as below, pls check these settings again
1,342件の閲覧回数
joanxie
what mode do you use? TDM mode?
%3CLINGO-SUB%20id%3D%22lingo-sub-2164317%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EIMX93%20SAI3%20FSYNC%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2164317%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E7%A7%81%E3%81%AFi.MX93%20SAI3%E3%82%AA%E3%83%BC%E3%83%87%E3%82%A3%E3%82%AA%E3%82%A4%E3%83%B3%E3%82%BF%E3%83%BC%E3%83%95%E3%82%A7%E3%83%BC%E3%82%B9%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%80%81%E6%AC%A1%E3%81%AE%E8%A8%AD%E5%AE%9A%E3%81%A7%E3%80%8CADS8354%E3%80%8DADC%E3%82%92%E5%88%B6%E5%BE%A1%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CUL%3E%3CLI%3E%E5%A4%96%E9%83%A8%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%2020%20MHz%3C%2FLI%3E%3C%2FUL%3E%3CPRE%20class%3D%22lia-code-sample%20language-c%22%3E%3CCODE%20translate%3D%22no%22%3Eclock_root_config_t%20saiClkCfg%20%3D%20%7B%0A.clockOff%20%3D%20true%2C%0A.mux%20%3D%20kCLOCK_SAI3_ClockRoot_MuxExt%2C%0A.div%20%3D%201%2C%0A%7D%3B%E2%80%8B%3C%2FCODE%3E%3C%2FPRE%3E%3CUL%3E%3CLI%3ESAI3%E6%A7%8B%E6%88%90%3C%2FLI%3E%3C%2FUL%3E%3CPRE%20class%3D%22lia-code-sample%20language-markup%22%3E%3CCODE%20translate%3D%22no%22%3Esai_transceiver_t%20saiConfig%3B%0ASAI_GetClassicI2SConfig(saiConfig%2CkSAI_WordWidth16bits%2CkSAI_Stereo%2C0x01)%3B%0AsaiConfig.bitClock.bclkPolarity%20%3D%20kSAI_SampleOnFallingEdge%3B%0AsaiConfig.serialData.dataWord0Length%20%3D%2018%3B%0AsaiConfig.frameSync.frameSyncWidth%20%3D%202%3B%0AsaiConfig.serialData.dataWordNum%20%20%20%20%20%20%3D%203%3B%0AsaiConfig.frameSync.frameSyncEarly%20%20%20%20%3D%20false%3B%0AsaiConfig.frameSync.frameSyncPolarity%20%3D%20kSAI_PolarityActiveHigh%3B%0ASAI_TxSetConfig(SAI3%2C%20%26amp%3Bg_saiConfig)%3B%0Ag_saiConfig.masterSlave%20%3D%20kSAI_Master%3B%0Ag_saiConfig.syncMode%20%3D%20kSAI_ModeSync%3B%0ASAI_RxSetConfig(SAI3%2C%20%26amp%3Bg_saiConfig)%3B%0A%0ASAI_TxSetBitClockRate(SAI3%2C%2020000000%2C%20400000%2C%2050%2C%201)%3B%0ASAI_RxSetBitClockRate(SAI3%2C%2020000000%2C%20400000%2C%2050%2C%201)%3B%3C%2FCODE%3E%3C%2FPRE%3E%3CBR%20%2F%3E%3CP%3E%E3%82%BF%E3%83%BC%E3%82%B2%E3%83%83%E3%83%88FSYNC%2FADC_CS%E5%91%A8%E6%B3%A2%E6%95%B0%3A%20%3CFONT%20color%3D%22%2399CC00%22%3E400%20KHz%3C%2FFONT%3E%20%3D%2020Mhz%20%2F%20(18%E3%83%93%E3%83%83%E3%83%88%20%2B%202x16%E3%83%93%E3%83%83%E3%83%88)%20%3D%2020000000%2F50%3C%2FP%3E%3CP%3E%E6%B8%AC%E5%AE%9A%E3%81%95%E3%82%8C%E3%81%9FFSYNC%2FADC_CS%E5%91%A8%E6%B3%A2%E6%95%B0%3A%20%3CFONT%20color%3D%22%23FF0000%22%3E200%20KHz%3C%2FFONT%3E%3C%2FP%3E%3CP%3E%E8%B3%AA%E5%95%8F%3A%20%E3%83%95%E3%83%AC%E3%83%BC%E3%83%A0%E9%95%B7%2050%20%E3%83%93%E3%83%83%E3%83%88%E3%80%81%E5%A4%96%E9%83%A8%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%2020%20MHz%20%E3%81%A7%20400%20kHz%20%E3%81%AE%20FSYNC%2FADC_CS%20%E4%BF%A1%E5%8F%B7%E3%82%92%E7%94%9F%E6%88%90%E3%81%99%E3%82%8B%E3%81%AB%E3%81%AF%E3%81%A9%E3%81%86%E3%81%99%E3%82%8C%E3%81%B0%E3%82%88%E3%81%84%E3%81%A7%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3CP%3E%3CSTRONG%3E%E6%B3%A8%3A%3C%2FSTRONG%3E%2040%20MHz%20%E3%81%AE%E5%A4%96%E9%83%A8%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E6%AD%A3%E5%B8%B8%E3%81%AB%E5%8B%95%E4%BD%9C%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3C%2FP%3E%3CP%3E%3CSTRONG%3EM33%20SDK%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%3C%2FSTRONG%3E%3A%20SDK_2_14_0_MCIMX93-EVK%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2172609%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20IMX93%20SAI3%20FSYNC%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2172609%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E9%81%85%E3%82%8C%E3%81%A6%E7%94%B3%E3%81%97%E8%A8%B3%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%E4%BB%8A%E9%80%B1AL%E3%82%92%E5%8F%96%E5%BE%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82TDM%E3%83%A2%E3%83%BC%E3%83%89%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%81%8C%E3%80%81%20%3CSPAN%3ESAI_GetClassicI2SConfig%E3%81%AFI2S%E3%83%A2%E3%83%BC%E3%83%89%E7%94%A8%E3%81%A7%E3%81%82%E3%82%8A%E3%80%81%E4%BB%A5%E4%B8%8B%E3%81%AE%E3%82%88%E3%81%86%E3%81%AB%E9%96%A2%E6%95%B0%E3%81%AB%E5%BE%93%E3%81%A3%E3%81%A61%E3%81%A4%E3%81%AE%E3%83%81%E3%83%A3%E3%83%8D%E3%83%AB%E3%81%AE%E3%81%BF%E3%82%92%E8%A8%AD%E5%AE%9A%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E3%81%93%E3%82%8C%E3%82%89%E3%81%AE%E8%A8%AD%E5%AE%9A%E3%82%92%E3%82%82%E3%81%86%E4%B8%80%E5%BA%A6%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%0A%3CPRE%20class%3D%22lia-code-sample%20%20language-markup%22%3E%3CCODE%20translate%3D%22no%22%3ESAI_TxSetBitClockRate(SAI3%2C%2020000000%2C%20400000%2C%2050%2C%201)%3B%3C%2FCODE%3E%3C%2FPRE%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2169750%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20IMX93%20SAI3%20FSYNC%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2169750%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%AF%E3%81%84%E3%80%81TDM%20%E3%83%A2%E3%83%BC%E3%83%89%E3%81%A7%E3%81%AF%E5%8F%AF%E8%83%BD%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3EPS%3A%20RCR4%2FTRC4%E3%81%AESYWD%5B8%3A12%5D%E3%81%AF0%EF%BC%881%E3%83%93%E3%83%83%E3%83%88%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%E3%82%B5%E3%82%A4%E3%82%AF%E3%83%AB%EF%BC%89%3C%2FP%3E%3CPRE%20class%3D%22lia-code-sample%20language-markup%22%3E%3CCODE%20translate%3D%22no%22%3EsaiConfig.frameSync.frameSyncWidth%20%3D%201%3B%3C%2FCODE%3E%3C%2FPRE%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2164974%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20IMX93%20SAI3%20FSYNC%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2164974%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%A9%E3%81%AE%E3%83%A2%E3%83%BC%E3%83%89%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%BE%E3%81%99%E3%81%8B%3FTDM%20%E3%83%A2%E3%83%BC%E3%83%89%3F%3C%2FP%3E%3C%2FLINGO-BODY%3E
