IMX8ULP Mode Registers LPDDR4
fisimalpro
Hi, I am trying to read the Mode Registers of the LPDDR4 RAM on the i.MX8ULP, but the reference manual is not clear on how to do it. Could you help me? Thanks!
fisimalpro
UP ??
Rita_Wang
What problem you met? Could you discribe more about it?
fisimalpro
I need to read mode registers 4, 5, 6, and 7 during the U-Boot phase. From the reference manual, it is not clear how to access these registers. A certain PERIPHERAL_MRR_DATA is mentioned, where the data of the requested MRR read should be located, but it does not specify in which register this is found. Furthermore, there is no indication of how to make a read request.
Rita_Wang
I see you also creat case to my colleague, he already give update to you, if still need help contact us freely.
Rita_Wang
I will give you update late today.
