IMX8ULP DDR script
IMX8ULP DDR script
6,073件の閲覧回数
Maxjay
When I use i.MX8ULP DDR Tool for the step 3: download DDR script, the [ERROR] is show No 'armclk' parameter in DDR script, what's mean for that? Thank you.
4 返答(返信)
5,998件の閲覧回数
Maxjay
Sorry for late reply.
The issues is with custom board and EVK is OK, and the different is DDR3 & DDR4, so that is a key for this case?
The RPA file as attachment for your reference, thank you.
5,994件の閲覧回数
Manuel_Salas
Hello!
Also, could you please share the Part number of your memory? I can not see it in your RPA file.
If possible, the schematic (related to DDR).
Thank you.
Best regards.
Salas.
5,982件の閲覧回数
Maxjay
Hi Sir,
The memory is a Nanya eMCP, the datasheet and related schematic as attachment for your reference, thank you.
6,049件の閲覧回数
Manuel_Salas
Hello @Maxjay ,
Could you please share more details?
Are you using the EVK or Custom board?
If possible share your RPA.
Best regards.
Salas.
