IMX8QXP Running Hello World Bin on M4
1,302 次查看
GShiva
Trying to run the application on M4 core using the steps mentioned https://imxdev.gitlab.io/tutorial/Enabling_Cortex-M4_on_i.MX_8QXP_MEK/
=> dhcp
=> setenv serverip <ip_from_host_pc>
=> tftp 0x88000000 hello_world.bin
=> dcache flush
=> bootaux 0x88000000
And I am getting the following error on the below step
Using ethernet@5b040000 device
TFTP from server 192.168.1.2; our IP address is 192.168.1.3
Filename 'hello_world.bin'.
TFTP error: trying to overwrite reserved memory...
Let me know the right CM address for IMX8QXP please. Referred to a few documents too and couldnt get the address
1,288 次查看
Harvey021
Hi @GShiva
Assume that you load a program running on TCM, then the address to load should not be 0x88000000.
Please check which image you built and load it to correct address referring to memory map of i.MX 8QXP RM.
Harvey
