IMX8QXP-B0 release details
2,860 次查看
darsh_dev
Contributor V
Hello Support Team,
Can I use the  latest or > L5.4.24_2_1_0 release for IMX8QXP-B0 revision?
In the release note of L5.4.24_2_1_0, mentioned only about the GA for 8QuadXplus C0 only.
Thanks.
2,848 次查看
AldoG
Yes, you may use it, please make sure that you download the B0 version, I'll leave the link here:
i.MX 8QuadXPlus(B0) MEK
Aldo.
2,837 次查看
darsh_dev
Contributor V
Hi @AldoG ,
Thanks for sharing the L5.4.24-2.1.0_images_MX8QXPMEK. We have custom board and debug LPUART is swaped in our case, so may be this images may not be help to us. Will check it our side.
What about the latest release L5.4.47 ? Because, in yocto machine conf file available for C0 only.
2,823 次查看
AldoG
Please try using the imx8qxpmek machine, you'll find it at meta-freescale/conf/machine.
Aldo.
