IMX8MP returns No HAB Events Found for unsigned Kernel image.
kartheek
I'm working on Secure Boot using the UG10163 (10.9 Security Reference Design). I generated a wic image that includes signed bootloader and signed kernel images.
After flashing this image to an SD card, I manually replaced the signed kernel image in the /boot folder with an unsigned kernel image.
Then, on the target device, I executed the following command in U-Boot:
hab_auth_img ${loadaddr} ${filesize} 0x1a90000
I expected HAB events to be triggered due to the unsigned kernel image, but the output showed:
No HAB Events Found!
Why is no HAB event being reported even though the kernel image is unsigned?
I've attached the log below for reference.
Kartheek
Harvey021
Are these steps tested after board reboot? and make sure if that the singed image was replaced.
Harvey
%3CLINGO-SUB%20id%3D%22lingo-sub-2182799%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EIMX8MP%20returns%20No%20HAB%20Events%20Found%20for%20unsigned%20Kernel%20image.%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2182799%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%2C%3C%2FP%3E%3CP%3E%3CSTRONG%3EI'm%20working%20on%20Secure%20Boot%20using%20the%20UG10163%20(10.9%20Security%20Reference%20Design).%20I%20generated%20a%20wic%20image%20that%20includes%20signed%20bootloader%20and%20signed%20kernel%20images.%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3EAfter%20flashing%20this%20image%20to%20an%20SD%20card%2C%20I%20manually%20replaced%20the%20signed%20kernel%20image%20in%20the%20%2Fboot%20folder%20with%20an%20%3CSTRONG%3Eunsigned%20kernel%20image%3C%2FSTRONG%3E.%3C%2FP%3E%3CP%3EThen%2C%20on%20the%20target%20device%2C%20I%20executed%20the%20following%20command%20in%20U-Boot%3A%3C%2FP%3E%3CP%3Ehab_auth_img%20%24%7Bloadaddr%7D%20%24%7Bfilesize%7D%200x1a90000%3C%2FP%3E%3CP%3EI%20expected%20HAB%20events%20to%20be%20triggered%20due%20to%20the%20unsigned%20kernel%20image%2C%20but%20the%20output%20showed%3A%3C%2FP%3E%3CPRE%3ENo%20HAB%20Events%20Found!%3C%2FPRE%3E%3CP%3E%3CSTRONG%3EWhy%20is%20no%20HAB%20event%20being%20reported%20even%20though%20the%20kernel%20image%20is%20unsigned%3F%3C%2FSTRONG%3E%3CBR%20%2F%3EI've%20attached%20the%20log%20below%20for%20reference.%3C%2FP%3E%3CP%3EThanks%2C%3C%2FP%3E%3CP%3EKartheek%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-2182799%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3Ei.MX%208M%20%7C%20i.MX%208M%20Mini%20%7C%20i.MX%208M%20Nano%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2183726%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20IMX8MP%20returns%20No%20HAB%20Events%20Found%20for%20unsigned%20Kernel%20image.%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2183726%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%2C%3C%2FP%3E%0A%3CP%3EAre%20these%20steps%20tested%20after%20board%20reboot%3F%20and%20make%20sure%20if%20that%20the%20singed%20image%20was%20replaced.%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3ERegards%3C%2FP%3E%0A%3CP%3EHarvey%3C%2FP%3E%3C%2FLINGO-BODY%3E
