[IMX8MP] reboot call trace
578 次查看
jjiimmyy
During overnight stress test (keep rebooting), we found IMX8MP EVK has a call trace problem. This does not happen every time.
We use "crontab" to execute reboot command.
BSP version: 6.6.36
Please see the attached picture for the call trace problem.
544 次查看
JorgeCas
This overnight reboot approach is not a representative real use case scenario because certain components of the system may not be fully loaded and then immediately trigger a reboot, this method could leads to anomalies as you mention.
You could try adding a delay in the reboot after the system has finished loading.
Best regards.
