IMX8MP flash
IMX8MP flash
1,105件の閲覧回数
Ajayvk
does fastboot 0 command will make imx8mp board to usb serial download mode?
1,094件の閲覧回数
Chavira
Hi @Ajayvk!
Thank you for contacting NXP Support!
Is not the same as the Download mode using the boot switches, but to flash the board using the uuu tool works fine.
You can try to use the command and then use the command "uuu -lsusb" on your host and you can see the device.
Best Regards!
Chavira
