[IMX8MP][Securiy]Does IMX8MP supports PWM input? How to implement PWM input
540 次查看
andy_kim
When review the datasheet for the IMX8MP, it supports 4x PWM. however, It supports only for output.
Could you let us know how to PWM input for iMX8M Plus?
Thank you.
Andy
标记 (1)
516 次查看
Zhiming_Liu
Hi @andy_kim
If i understanding is correct, you want to capture input signal, right?
The  General Purpose Timer (GPT)  can capture can compare the input signals.
Zhiming
517 次查看
Zhiming_Liu
Hi @andy_kim
Zhiming
