IMX8MP RGMII Connection with No PHY
2,155 次查看
RyanMKB
I'm trying to setup an ethernet RGMII connection to a switch without using a PHY. Based on other posts I've configured my device tree as follows:
&fec {
	pinctrl-names = "default";
	pinctrl-0 = <&pinctrl_fec>, <&pinctrl_fec_phy>;
	phy-mode = "rgmii";
	status = "okay";
	fixed-link {
		speed = <1000>;
		full-duplex;
	pinctrl_fec: fecgrp {
		fsl,pins = <MX8MP_IOMUXC_SAI1_RXD2__ENET1_MDC		0x40000044>,
			   <MX8MP_IOMUXC_SAI1_RXD3__ENET1_MDIO		0x40000044>,
			   <MX8MP_IOMUXC_SAI1_RXD4__ENET1_RGMII_RD0	0x90>,
			   <MX8MP_IOMUXC_SAI1_RXD5__ENET1_RGMII_RD1	0x90>,
			   <MX8MP_IOMUXC_SAI1_RXD6__ENET1_RGMII_RD2	0x90>,
			   <MX8MP_IOMUXC_SAI1_RXD7__ENET1_RGMII_RD3	0x90>,
			   <MX8MP_IOMUXC_SAI1_TXC__ENET1_RGMII_RXC	0x90>,
			   <MX8MP_IOMUXC_SAI1_TXFS__ENET1_RGMII_RX_CTL	0x90>,
			   <MX8MP_IOMUXC_SAI1_TXD0__ENET1_RGMII_TD0	0x12>,
			   <MX8MP_IOMUXC_SAI1_TXD1__ENET1_RGMII_TD1	0x12>,
			   <MX8MP_IOMUXC_SAI1_TXD2__ENET1_RGMII_TD2	0x12>,
			   <MX8MP_IOMUXC_SAI1_TXD3__ENET1_RGMII_TD3	0x12>,
			   <MX8MP_IOMUXC_SAI1_TXD4__ENET1_RGMII_TX_CTL	0x12>,
			   <MX8MP_IOMUXC_SAI1_TXD5__ENET1_RGMII_TXC	0x14>;
	pinctrl_fec_phy: fecphygrp {
		fsl,pins = <MX8MP_IOMUXC_SAI1_RXFS__GPIO4_IO00		0x100>,
			   <MX8MP_IOMUXC_SAI1_RXC__GPIO4_IO01		0x1c0>;
 ethtool shows Link detected: yes, and ifconfig shows that an ip address was assigned. However I am unable to ping to or from the board. Can you confirm if the pins are set correctly for this use case? Thanks.
标记 (1)
3 回复数
2,020 次查看
joanxie
for RGMII, the current bsp supports this as default, you can refer to that
https://github.com/nxp-imx/linux-imx/blob/lf-6.12.y/arch/arm64/boot/dts/freescale/imx8mp-evk.dts#L39...
2,109 次查看
joanxie
pls refer to the enclosed file, which is very useful for your case
2,086 次查看
RyanMKB
Thank you for your reply, I have looked at that document already which helped me get this far. However, I still need further assistance in getting things working.
%3CLINGO-SUB%20id%3D%22lingo-sub-2254641%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E6%97%A0%20PHY%20%E7%9A%84%20IMX8MP%20RGMII%20%E8%BF%9E%E6%8E%A5%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2254641%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E6%82%A8%E5%A5%BD%EF%BC%8C%3C%2FP%3E%3CP%3E%E6%88%91%E6%AD%A3%E8%AF%95%E5%9B%BE%E5%9C%A8%E4%B8%8D%E4%BD%BF%E7%94%A8%E7%89%A9%E7%90%86%E5%B1%82%E7%9A%84%E6%83%85%E5%86%B5%E4%B8%8B%E5%BB%BA%E7%AB%8B%E4%B8%8E%E4%BA%A4%E6%8D%A2%E6%9C%BA%E7%9A%84%E4%BB%A5%E5%A4%AA%E7%BD%91%20RGMII%20%E8%BF%9E%E6%8E%A5%E3%80%82%E6%A0%B9%E6%8D%AE%E5%85%B6%E4%BB%96%E5%B8%96%E5%AD%90%EF%BC%8C%E6%88%91%E5%B0%86%E6%88%91%E7%9A%84%E8%AE%BE%E5%A4%87%E6%A0%91%E9%85%8D%E7%BD%AE%E5%A6%82%E4%B8%8B%EF%BC%9A%3C%2FP%3E%3CPRE%20class%3D%22lia-code-sample%20language-c%22%3E%3CCODE%20translate%3D%22no%22%3E%26amp%3Bfec%20%7B%0A%09pinctrl-names%20%3D%20%22default%22%3B%0A%09pinctrl-0%20%3D%20%26lt%3B%26amp%3Bpinctrl_fec%26gt%3B%2C%20%26lt%3B%26amp%3Bpinctrl_fec_phy%26gt%3B%3B%0A%09phy-mode%20%3D%20%22rgmii%22%3B%0A%09status%20%3D%20%22okay%22%3B%0A%0A%09fixed-link%20%7B%0A%09%09speed%20%3D%20%26lt%3B1000%26gt%3B%3B%0A%09%09full-duplex%3B%0A%09%7D%3B%0A%0A%7D%3B%0A%0A%09pinctrl_fec%3A%20fecgrp%20%7B%0A%09%09fsl%2Cpins%20%3D%20%3CMX8MP_IOMUXC_SAI1_RXD2__ENET1_MDC%200x40000044%3D%22%22%3E%2C%0A%09%09%09%20%20%20%3CMX8MP_IOMUXC_SAI1_RXD3__ENET1_MDIO%200x40000044%3D%22%22%3E%2C%0A%09%09%09%20%20%20%3CMX8MP_IOMUXC_SAI1_RXD4__ENET1_RGMII_RD0%200x90%3D%22%22%3E%2C%0A%09%09%09%20%20%20%3CMX8MP_IOMUXC_SAI1_RXD5__ENET1_RGMII_RD1%200x90%3D%22%22%3E%2C%0A%09%09%09%20%20%20%3CMX8MP_IOMUXC_SAI1_RXD6__ENET1_RGMII_RD2%200x90%3D%22%22%3E%2C%0A%09%09%09%20%20%20%3CMX8MP_IOMUXC_SAI1_RXD7__ENET1_RGMII_RD3%200x90%3D%22%22%3E%2C%0A%09%09%09%20%20%20%3CMX8MP_IOMUXC_SAI1_TXC__ENET1_RGMII_RXC%200x90%3D%22%22%3E%2C%0A%09%09%09%20%20%20%3CMX8MP_IOMUXC_SAI1_TXFS__ENET1_RGMII_RX_CTL%200x90%3D%22%22%3E%2C%0A%09%09%09%20%20%20%3CMX8MP_IOMUXC_SAI1_TXD0__ENET1_RGMII_TD0%200x12%3D%22%22%3E%2C%0A%09%09%09%20%20%20%3CMX8MP_IOMUXC_SAI1_TXD1__ENET1_RGMII_TD1%200x12%3D%22%22%3E%2C%0A%09%09%09%20%20%20%3CMX8MP_IOMUXC_SAI1_TXD2__ENET1_RGMII_TD2%200x12%3D%22%22%3E%2C%0A%09%09%09%20%20%20%3CMX8MP_IOMUXC_SAI1_TXD3__ENET1_RGMII_TD3%200x12%3D%22%22%3E%2C%0A%09%09%09%20%20%20%3CMX8MP_IOMUXC_SAI1_TXD4__ENET1_RGMII_TX_CTL%200x12%3D%22%22%3E%2C%0A%09%09%09%20%20%20%3CMX8MP_IOMUXC_SAI1_TXD5__ENET1_RGMII_TXC%200x14%3D%22%22%3E%3B%0A%09%7D%3B%0A%0A%09pinctrl_fec_phy%3A%20fecphygrp%20%7B%0A%09%09fsl%2Cpins%20%3D%20%3CMX8MP_IOMUXC_SAI1_RXFS__GPIO4_IO00%200x100%3D%22%22%3E%2C%0A%09%09%09%20%20%20%3CMX8MP_IOMUXC_SAI1_RXC__GPIO4_IO01%200x1c0%3D%22%22%3E%3B%0A%09%7D%3B%3C%2FMX8MP_IOMUXC_SAI1_RXC__GPIO4_IO01%3E%3C%2FMX8MP_IOMUXC_SAI1_RXFS__GPIO4_IO00%3E%3C%2FMX8MP_IOMUXC_SAI1_TXD5__ENET1_RGMII_TXC%3E%3C%2FMX8MP_IOMUXC_SAI1_TXD4__ENET1_RGMII_TX_CTL%3E%3C%2FMX8MP_IOMUXC_SAI1_TXD3__ENET1_RGMII_TD3%3E%3C%2FMX8MP_IOMUXC_SAI1_TXD2__ENET1_RGMII_TD2%3E%3C%2FMX8MP_IOMUXC_SAI1_TXD1__ENET1_RGMII_TD1%3E%3C%2FMX8MP_IOMUXC_SAI1_TXD0__ENET1_RGMII_TD0%3E%3C%2FMX8MP_IOMUXC_SAI1_TXFS__ENET1_RGMII_RX_CTL%3E%3C%2FMX8MP_IOMUXC_SAI1_TXC__ENET1_RGMII_RXC%3E%3C%2FMX8MP_IOMUXC_SAI1_RXD7__ENET1_RGMII_RD3%3E%3C%2FMX8MP_IOMUXC_SAI1_RXD6__ENET1_RGMII_RD2%3E%3C%2FMX8MP_IOMUXC_SAI1_RXD5__ENET1_RGMII_RD1%3E%3C%2FMX8MP_IOMUXC_SAI1_RXD4__ENET1_RGMII_RD0%3E%3C%2FMX8MP_IOMUXC_SAI1_RXD3__ENET1_MDIO%3E%3C%2FMX8MP_IOMUXC_SAI1_RXD2__ENET1_MDC%3E%3C%2FCODE%3E%3C%2FPRE%3E%3CP%3Eethtool%20%E6%98%BE%E7%A4%BA%E6%A3%80%E6%B5%8B%E5%88%B0%E9%93%BE%E6%8E%A5%EF%BC%9A%E6%98%AF%EF%BC%8Cifconfig%20%E6%98%BE%E7%A4%BA%E5%B7%B2%E5%88%86%E9%85%8D%20IP%20%E5%9C%B0%E5%9D%80%E3%80%82%E4%BD%86%E6%98%AF%E6%88%91%E6%97%A0%E6%B3%95%20ping%20%E5%88%B0%E6%9D%BF%E6%88%96%E4%BB%8E%E6%9D%BF%E4%B8%8A%E6%89%A7%E8%A1%8C%20ping%20%E6%93%8D%E4%BD%9C%E3%80%82%E6%82%A8%E8%83%BD%E7%A1%AE%E8%AE%A4%E9%92%88%E8%84%9A%E7%9A%84%E8%AE%BE%E7%BD%AE%E6%98%AF%E5%90%A6%E6%AD%A3%E7%A1%AE%E5%90%97%EF%BC%9F%E8%B0%A2%E8%B0%A2%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-2254641%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3Ei.MX%208%20%E7%B3%BB%E5%88%97%20%7C%20i.MX%208QuadMax%20(8QM)%20%7C%208QuadPlus%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2255426%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20IMX8MP%20RGMII%20Connection%20with%20No%20PHY%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2255426%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E8%B0%A2%E8%B0%A2%E6%82%A8%E7%9A%84%E7%AD%94%E5%A4%8D%EF%BC%8C%E6%88%91%E5%B7%B2%E7%BB%8F%E7%9C%8B%E8%BF%87%E9%82%A3%E4%BB%BD%E6%96%87%E4%BB%B6%EF%BC%8C%E5%AE%83%E5%B8%AE%E6%88%91%E8%B5%B0%E5%88%B0%E4%BA%86%E4%BB%8A%E5%A4%A9%E3%80%82%E4%B8%8D%E8%BF%87%EF%BC%8C%E6%88%91%E4%BB%8D%E7%84%B6%E9%9C%80%E8%A6%81%E8%BF%9B%E4%B8%80%E6%AD%A5%E7%9A%84%E5%B8%AE%E5%8A%A9%EF%BC%8C%E6%89%8D%E8%83%BD%E8%AE%A9%E4%BA%8B%E6%83%85%E9%A1%BA%E5%88%A9%E8%BF%9B%E8%A1%8C%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2255221%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20IMX8MP%20RGMII%20Connection%20with%20No%20PHY%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2255221%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E8%AF%B7%E5%8F%82%E9%98%85%E6%89%80%E9%99%84%E6%96%87%E4%BB%B6%EF%BC%8C%E8%AF%A5%E6%96%87%E4%BB%B6%E5%AF%B9%E6%82%A8%E7%9A%84%E6%83%85%E5%86%B5%E9%9D%9E%E5%B8%B8%E6%9C%89%E7%94%A8%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2256381%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20IMX8MP%20RGMII%20Connection%20with%20No%20PHY%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2256381%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E5%AF%B9%E4%BA%8E%20RGMII%EF%BC%8C%E5%BD%93%E5%89%8D%E7%94%B5%E8%B7%AF%E6%9D%BF%E6%94%AF%E6%8C%81%E5%8C%85%E9%BB%98%E8%AE%A4%E6%94%AF%E6%8C%81%E6%AD%A4%E5%8A%9F%E8%83%BD%EF%BC%8C%E4%BD%A0%E5%8F%AF%E4%BB%A5%E5%8F%82%E8%80%83%3C%2FP%3E%0A%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fgithub.com%2Fnxp-imx%2Flinux-imx%2Fblob%2Flf-6.12.y%2Farch%2Farm64%2Fboot%2Fdts%2Ffreescale%2Fimx8mp-evk.dts%23L390%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttps%3A%2F%2Fgithub.com%2Fnxp-imx%2Flinux-imx%2Fblob%2Flf-6.12.y%2Farch%2Farm64%2Fboot%2Fdts%2Ffreescale%2Fimx8mp-evk.dts%23L390%3C%2FA%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E
