IMX8MP RAW10 ISI Capture
1,544件の閲覧回数
kim7604
Hi.  I am able to capture pixel data from a MIPI CSI-2 sensor that is a 10bit packed format.  I followed this post in order to capture: https://community.nxp.com/t5/i-MX-Processors/LF-5-15-32-2-0-0-Add-RAW10-support/m-p/1504583
I am not using ISP.  The pixel data I see for a 10 bit pixel that should have each bit set is: [0]0xc0 and [1]0xFF  The 10 bits are shift to the left 6 bits.  Is this expected?
Another question I have is how does the NXP/ISI capture "unpack" the mipi CSI-2 10bit packed data?  Is it automatic?  Where in the code does this happen?
Thank you for any help,
Kim
1,468件の閲覧回数
joanxie
this is imx8qm ISI issue, imx8mp doesn't have this issue
