IMX8MP Inline ECC
IMX8MP Inline ECC
James33
Dear NXP Technical Support Team,
I am currently attempting to utilize the Inline ECC feature on the IMX8MP(Follow the steps in AN13566.pdf and https://community.nxp.com/t5/NXP-Tech-Blog/xxx ).  According to section 9.2.5.1.20.3 of IMX8MPRM.pdf, I attempted to set ecc_region_parity_lock to Unlocked.
 I modified the content of lpddr4_timing.c and set the value of the 0x3d400074 register to 0x780.
struct dram_cfg_param ddr_ddrc_cfg[] = {
{0x3d400304, 0x1},
{0x3d400030, 0x1},
{0x3d400000, 0xa3080020},
{0x3d400020, 0x1323},
{0x3d400024, 0x1e84800},
{0x3d400064, 0x7a0118},
{0x3d400070, 0x070277D4},
{0x3d400074, 0x780},
However, the register value read via the memtool tool is 0x790.
root@imx8mp-lpddr4-evk:~# /unit_tests/memtool 0x3d400074 1
E
Reading 0x1 count starting at address 0x3D400074
0x3D400074: 00000790
I would like to know how to properly configure this register.
Thank you in advance for your support.
pengyong_zhang
Hi @James33
你是自己手动修改的寄存器的值吗?
B.R
James33
Hello!!
James33
The lpddr4_timing.c file was generated by a DDR tool( * Code generated with DDR Tool v4.0.0_10-1eade933a.). The default value of this register is 0x790. According to the description in AN13566, section 3.2.3, I wanted to access the ECC parity region, so I manually changed it to 0x780, but it didn't work.
 * Copyright 2026 NXP
 * SPDX-License-Identifier: BSD-3-Clause
 * DDR PHY FW2020.06
 * Part number: NXP LPDDR4 EVK board's default DDR part
#include <linux/kernel.h>
#include <asm/arch/ddr.h>
/* Initialize DDRC registers */
    {0x3d400304, 0x1},
    {0x3d400030, 0x1},
    {0x3d400070, 0x7027fd4},
    {0x3d400074, 0x790},
    {0x3d4000d0, 0xc00307a3},
    {0x3d4000d4, 0xc50000},
    {0x3d4000dc, 0xf4003f},
    {0x3d4000e0, 0x330000},
    {0x3d4000e8, 0x660048},
    {0x3d4000ec, 0x160048},
    {0x3d400100, 0x2028222a},
    {0x3d400104, 0x8083f},
    {0x3d40010c, 0xe0e000},
    {0x3d400110, 0x12040a12},
    {0x3d400114, 0x2050f0f},
    {0x3d400118, 0x1010009},
    {0x3d40011c, 0x502},
    {0x3d400130, 0x20800},
    {0x3d400134, 0xe100002},
    {0x3d400138, 0x120},
    {0x3d400144, 0xc80064},
    {0x3d400180, 0x3e8001e},
    {0x3d400184, 0x3207a12},
    {0x3d400188, 0x0},
    {0x3d400190, 0x49f820e},
    {0x3d400194, 0x80303},
    {0x3d4001b4, 0x1f0e},
    {0x3d4001a0, 0xe0400018},
    {0x3d4001a4, 0xdf00e4},
    {0x3d4001a8, 0x80000000},
    {0x3d4001b0, 0x11},
    {0x3d4001c0, 0x1},
    {0x3d4001c4, 0x1},
    {0x3d4000f4, 0x799},
    {0x3d400108, 0x9121b1c},
    {0x3d400200, 0x14},
    {0x3d400208, 0x0},
    {0x3d40020c, 0x14141400},
    {0x3d400210, 0x1f1f},
    {0x3d400204, 0x50505},
    {0x3d400214, 0x4040404},
    {0x3d400218, 0x4040404},
    {0x3d40021c, 0xf0f},
    {0x3d400250, 0x1705},
    {0x3d400254, 0x2c},
    {0x3d40025c, 0x4000030},
    {0x3d400264, 0x900093e7},
    {0x3d40026c, 0x2005574},
    {0x3d400400, 0x111},
    {0x3d400404, 0x72ff},
    {0x3d400408, 0x72ff},
    {0x3d400494, 0x2100e07},
    {0x3d400498, 0x620096},
    {0x3d40049c, 0x1100e07},
    {0x3d4004a0, 0xc8012c},
    {0x3d402020, 0x1021},
    {0x3d402024, 0x30d400},
    {0x3d402050, 0x20d000},
    {0x3d402064, 0xc001c},
    {0x3d4020dc, 0x840000},
    {0x3d4020e0, 0x330000},
    {0x3d4020e8, 0x660048},
    {0x3d4020ec, 0x160048},
    {0x3d402100, 0xa040305},
    {0x3d402104, 0x30407},
    {0x3d402108, 0x203060b},
    {0x3d40210c, 0x505000},
    {0x3d402110, 0x2040202},
    {0x3d402114, 0x2030202},
    {0x3d402118, 0x1010004},
    {0x3d40211c, 0x302},
    {0x3d402130, 0x20300},
    {0x3d402134, 0xa100002},
    {0x3d402138, 0x1d},
    {0x3d402144, 0x14000a},
    {0x3d402180, 0x640004},
    {0x3d402190, 0x3818200},
    {0x3d402194, 0x80303},
    {0x3d4021b4, 0x100},
    {0x3d4020f4, 0x599},
    {0x3d403020, 0x1021},
    {0x3d403024, 0xc3500},
    {0x3d403050, 0x20d000},
    {0x3d403064, 0x30007},
    {0x3d4030dc, 0x840000},
    {0x3d4030e0, 0x330000},
    {0x3d4030e8, 0x660048},
    {0x3d4030ec, 0x160048},
    {0x3d403100, 0xa010102},
    {0x3d403104, 0x30404},
    {0x3d403108, 0x203060b},
    {0x3d40310c, 0x505000},
    {0x3d403110, 0x2040202},
    {0x3d403114, 0x2030202},
    {0x3d403118, 0x1010004},
    {0x3d40311c, 0x302},
    {0x3d403130, 0x20300},
    {0x3d403134, 0xa100002},
    {0x3d403138, 0x8},
    {0x3d403144, 0x50003},
    {0x3d403180, 0x190004},
    {0x3d403190, 0x3818200},
    {0x3d403194, 0x80303},
    {0x3d4031b4, 0x100},
    {0x3d4030f4, 0x599},
    {0x3d400028, 0x0},
 Thank you for your reply.
pengyong_zhang
Hi @James33
Please share your modified RPA file.
B.R
James33
Hello!!!
James33
Thank you for your support!
%3CLINGO-SUB%20id%3D%22lingo-sub-2369962%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EIMX8MP%20Inline%20ECC%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2369962%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EDear%20NXP%20Technical%20Support%20Team%2C%3C%2FP%3E%3CP%3EI%20am%20currently%20attempting%20to%20utilize%20the%20Inline%20ECC%20feature%20on%20the%20IMX8MP(Follow%20the%20steps%20in%20AN13566.pdf%20and%20%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2FNXP-Tech-Blog%2F%25E3%2582%25A4%25E3%2583%25B3%25E3%2583%25A9%25E3%2582%25A4%25E3%2583%25B3ECC-%25E6%25A9%259F%25E8%2583%25BD%25E3%2581%25A8%25E5%25AE%259F%25E8%25A3%2585%25E6%2596%25B9%25E6%25B3%2595%25E3%2581%25AB%25E3%2581%25A4%25E3%2581%2584%25E3%2581%25A6-%25E6%2597%25A5%25E6%259C%25AC%25E8%25AA%259E%25E3%2583%2596%25E3%2583%25AD%25E3%2582%25B0%2Fba-p%2F2259699%22%20target%3D%22_blank%22%3Ehttps%3A%2F%2Fcommunity.nxp.com%2Ft5%2FNXP-Tech-Blog%2Fxxx%3C%2FA%3E%26nbsp%3B).%26nbsp%3B%26nbsp%3BAccording%20to%20section%209.2.5.1.20.3%20of%20IMX8MPRM.pdf%2C%20I%20attempted%20to%20set%20ecc_region_parity_lock%20to%20Unlocked.%26nbsp%3B%3C%2FP%3E%3CP%3E%26nbsp%3BI%20modified%20the%20content%20of%20lpddr4_timing.c%20and%20set%20the%20value%20of%20the%200x3d400074%20register%20to%200x780.%3C%2FP%3E%3CPRE%20class%3D%22lia-code-sample%20language-markup%22%3E%3CCODE%3Estruct%20dram_cfg_param%20ddr_ddrc_cfg%5B%5D%20%3D%20%7B%0A%7B0x3d400304%2C%200x1%7D%2C%0A%7B0x3d400030%2C%200x1%7D%2C%0A%7B0x3d400000%2C%200xa3080020%7D%2C%0A%7B0x3d400020%2C%200x1323%7D%2C%0A%7B0x3d400024%2C%200x1e84800%7D%2C%0A%7B0x3d400064%2C%200x7a0118%7D%2C%0A%7B0x3d400070%2C%200x070277D4%7D%2C%0A%7B0x3d400074%2C%200x780%7D%2C%0A......%3C%2FCODE%3E%3C%2FPRE%3E%3CP%3EHowever%2C%20the%20register%20value%20read%20via%20the%20memtool%20tool%20is%200x790.%3C%2FP%3E%3CBR%20%2F%3E%3CPRE%20class%3D%22lia-code-sample%20language-markup%22%3E%3CCODE%3Eroot%40imx8mp-lpddr4-evk%3A~%23%20%2Funit_tests%2Fmemtool%200x3d400074%201%0AE%0AReading%200x1%20count%20starting%20at%20address%200x3D400074%0A%0A0x3D400074%3A%2000000790%3C%2FCODE%3E%3C%2FPRE%3E%3CP%3EI%20would%20like%20to%20know%20how%20to%20properly%20configure%20this%20register.%3CBR%20%2F%3E%3CBR%20%2F%3EThank%20you%20in%20advance%20for%20your%20support.%3C%2FP%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2370944%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20IMX8MP%20Inline%20ECC%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2370944%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EThank%20you%20for%20your%20support%EF%BC%81%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2370483%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20IMX8MP%20Inline%20ECC%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2370483%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F255264%22%20target%3D%22_blank%22%3E%40James33%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%3EPlease%20share%20your%20modified%20RPA%20file.%3C%2FP%3E%0A%3CP%3EB.R%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2374724%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20IMX8MP%20Inline%20ECC%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2374724%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%20%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F255264%22%20target%3D%22_blank%22%3E%40James33%3C%2FA%3E%20%3C%2FP%3E%0A%3CP%3EDid%20you%20manually%20change%20the%20register%20values%20yourself%3F%3C%2FP%3E%0A%3CP%3EB.R%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2374755%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20IMX8MP%20Inline%20ECC%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2374755%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EThe%20lpddr4_timing.c%20file%20was%20generated%20by%20a%20DDR%20tool(%20*%20Code%20generated%20with%20DDR%20Tool%20v4.0.0_10-1eade933a.).%20The%20default%20value%20of%20this%20register%20is%200x790.%20According%20to%20the%20description%20in%20AN13566%2C%20section%203.2.3%2C%20I%20wanted%20to%20access%20the%20ECC%20parity%20region%2C%20so%20I%20manually%20changed%20it%20to%200x780%2C%20but%20it%20didn't%20work.%3C%2FP%3E%3CPRE%20class%3D%22lia-code-sample%20language-c%22%3E%3CCODE%3E%2F*%0A%20*%20Copyright%202026%20NXP%0A%20*%0A%20*%20SPDX-License-Identifier%3A%20BSD-3-Clause%0A%20*%0A%20*%20Code%20generated%20with%20DDR%20Tool%20v4.0.0_10-1eade933a.%0A%20*%20DDR%20PHY%20FW2020.06%20%0A%20*%20Part%20number%3A%20NXP%20LPDDR4%20EVK%20board's%20default%20DDR%20part%0A%20*%2F%0A%0A%23include%20%3CLINUX%3E%0A%23include%20%3CASM%3E%0A%0A%2F*%20Initialize%20DDRC%20registers%20*%2F%0Astruct%20dram_cfg_param%20ddr_ddrc_cfg%5B%5D%20%3D%20%7B%0A%20%20%20%20%7B0x3d400304%2C%200x1%7D%2C%0A%20%20%20%20%7B0x3d400030%2C%200x1%7D%2C%0A%20%20%20%20%7B0x3d400000%2C%200xa3080020%7D%2C%0A%20%20%20%20%7B0x3d400020%2C%200x1323%7D%2C%0A%20%20%20%20%7B0x3d400024%2C%200x1e84800%7D%2C%0A%20%20%20%20%7B0x3d400064%2C%200x7a0118%7D%2C%0A%20%20%20%20%7B0x3d400070%2C%200x7027fd4%7D%2C%0A%20%20%20%20%7B0x3d400074%2C%200x790%7D%2C%0A%20%20%20%20%7B0x3d4000d0%2C%200xc00307a3%7D%2C%0A%20%20%20%20%7B0x3d4000d4%2C%200xc50000%7D%2C%0A%20%20%20%20%7B0x3d4000dc%2C%200xf4003f%7D%2C%0A%20%20%20%20%7B0x3d4000e0%2C%200x330000%7D%2C%0A%20%20%20%20%7B0x3d4000e8%2C%200x660048%7D%2C%0A%20%20%20%20%7B0x3d4000ec%2C%200x160048%7D%2C%0A%20%20%20%20%7B0x3d400100%2C%200x2028222a%7D%2C%0A%20%20%20%20%7B0x3d400104%2C%200x8083f%7D%2C%0A%20%20%20%20%7B0x3d40010c%2C%200xe0e000%7D%2C%0A%20%20%20%20%7B0x3d400110%2C%200x12040a12%7D%2C%0A%20%20%20%20%7B0x3d400114%2C%200x2050f0f%7D%2C%0A%20%20%20%20%7B0x3d400118%2C%200x1010009%7D%2C%0A%20%20%20%20%7B0x3d40011c%2C%200x502%7D%2C%0A%20%20%20%20%7B0x3d400130%2C%200x20800%7D%2C%0A%20%20%20%20%7B0x3d400134%2C%200xe100002%7D%2C%0A%20%20%20%20%7B0x3d400138%2C%200x120%7D%2C%0A%20%20%20%20%7B0x3d400144%2C%200xc80064%7D%2C%0A%20%20%20%20%7B0x3d400180%2C%200x3e8001e%7D%2C%0A%20%20%20%20%7B0x3d400184%2C%200x3207a12%7D%2C%0A%20%20%20%20%7B0x3d400188%2C%200x0%7D%2C%0A%20%20%20%20%7B0x3d400190%2C%200x49f820e%7D%2C%0A%20%20%20%20%7B0x3d400194%2C%200x80303%7D%2C%0A%20%20%20%20%7B0x3d4001b4%2C%200x1f0e%7D%2C%0A%20%20%20%20%7B0x3d4001a0%2C%200xe0400018%7D%2C%0A%20%20%20%20%7B0x3d4001a4%2C%200xdf00e4%7D%2C%0A%20%20%20%20%7B0x3d4001a8%2C%200x80000000%7D%2C%0A%20%20%20%20%7B0x3d4001b0%2C%200x11%7D%2C%0A%20%20%20%20%7B0x3d4001c0%2C%200x1%7D%2C%0A%20%20%20%20%7B0x3d4001c4%2C%200x1%7D%2C%0A%20%20%20%20%7B0x3d4000f4%2C%200x799%7D%2C%0A%20%20%20%20%7B0x3d400108%2C%200x9121b1c%7D%2C%0A%20%20%20%20%7B0x3d400200%2C%200x14%7D%2C%0A%20%20%20%20%7B0x3d400208%2C%200x0%7D%2C%0A%20%20%20%20%7B0x3d40020c%2C%200x14141400%7D%2C%0A%20%20%20%20%7B0x3d400210%2C%200x1f1f%7D%2C%0A%20%20%20%20%7B0x3d400204%2C%200x50505%7D%2C%0A%20%20%20%20%7B0x3d400214%2C%200x4040404%7D%2C%0A%20%20%20%20%7B0x3d400218%2C%200x4040404%7D%2C%0A%20%20%20%20%7B0x3d40021c%2C%200xf0f%7D%2C%0A%20%20%20%20%7B0x3d400250%2C%200x1705%7D%2C%0A%20%20%20%20%7B0x3d400254%2C%200x2c%7D%2C%0A%20%20%20%20%7B0x3d40025c%2C%200x4000030%7D%2C%0A%20%20%20%20%7B0x3d400264%2C%200x900093e7%7D%2C%0A%20%20%20%20%7B0x3d40026c%2C%200x2005574%7D%2C%0A%20%20%20%20%7B0x3d400400%2C%200x111%7D%2C%0A%20%20%20%20%7B0x3d400404%2C%200x72ff%7D%2C%0A%20%20%20%20%7B0x3d400408%2C%200x72ff%7D%2C%0A%20%20%20%20%7B0x3d400494%2C%200x2100e07%7D%2C%0A%20%20%20%20%7B0x3d400498%2C%200x620096%7D%2C%0A%20%20%20%20%7B0x3d40049c%2C%200x1100e07%7D%2C%0A%20%20%20%20%7B0x3d4004a0%2C%200xc8012c%7D%2C%0A%20%20%20%20%7B0x3d402020%2C%200x1021%7D%2C%0A%20%20%20%20%7B0x3d402024%2C%200x30d400%7D%2C%0A%20%20%20%20%7B0x3d402050%2C%200x20d000%7D%2C%0A%20%20%20%20%7B0x3d402064%2C%200xc001c%7D%2C%0A%20%20%20%20%7B0x3d4020dc%2C%200x840000%7D%2C%0A%20%20%20%20%7B0x3d4020e0%2C%200x330000%7D%2C%0A%20%20%20%20%7B0x3d4020e8%2C%200x660048%7D%2C%0A%20%20%20%20%7B0x3d4020ec%2C%200x160048%7D%2C%0A%20%20%20%20%7B0x3d402100%2C%200xa040305%7D%2C%0A%20%20%20%20%7B0x3d402104%2C%200x30407%7D%2C%0A%20%20%20%20%7B0x3d402108%2C%200x203060b%7D%2C%0A%20%20%20%20%7B0x3d40210c%2C%200x505000%7D%2C%0A%20%20%20%20%7B0x3d402110%2C%200x2040202%7D%2C%0A%20%20%20%20%7B0x3d402114%2C%200x2030202%7D%2C%0A%20%20%20%20%7B0x3d402118%2C%200x1010004%7D%2C%0A%20%20%20%20%7B0x3d40211c%2C%200x302%7D%2C%0A%20%20%20%20%7B0x3d402130%2C%200x20300%7D%2C%0A%20%20%20%20%7B0x3d402134%2C%200xa100002%7D%2C%0A%20%20%20%20%7B0x3d402138%2C%200x1d%7D%2C%0A%20%20%20%20%7B0x3d402144%2C%200x14000a%7D%2C%0A%20%20%20%20%7B0x3d402180%2C%200x640004%7D%2C%0A%20%20%20%20%7B0x3d402190%2C%200x3818200%7D%2C%0A%20%20%20%20%7B0x3d402194%2C%200x80303%7D%2C%0A%20%20%20%20%7B0x3d4021b4%2C%200x100%7D%2C%0A%20%20%20%20%7B0x3d4020f4%2C%200x599%7D%2C%0A%20%20%20%20%7B0x3d403020%2C%200x1021%7D%2C%0A%20%20%20%20%7B0x3d403024%2C%200xc3500%7D%2C%0A%20%20%20%20%7B0x3d403050%2C%200x20d000%7D%2C%0A%20%20%20%20%7B0x3d403064%2C%200x30007%7D%2C%0A%20%20%20%20%7B0x3d4030dc%2C%200x840000%7D%2C%0A%20%20%20%20%7B0x3d4030e0%2C%200x330000%7D%2C%0A%20%20%20%20%7B0x3d4030e8%2C%200x660048%7D%2C%0A%20%20%20%20%7B0x3d4030ec%2C%200x160048%7D%2C%0A%20%20%20%20%7B0x3d403100%2C%200xa010102%7D%2C%0A%20%20%20%20%7B0x3d403104%2C%200x30404%7D%2C%0A%20%20%20%20%7B0x3d403108%2C%200x203060b%7D%2C%0A%20%20%20%20%7B0x3d40310c%2C%200x505000%7D%2C%0A%20%20%20%20%7B0x3d403110%2C%200x2040202%7D%2C%0A%20%20%20%20%7B0x3d403114%2C%200x2030202%7D%2C%0A%20%20%20%20%7B0x3d403118%2C%200x1010004%7D%2C%0A%20%20%20%20%7B0x3d40311c%2C%200x302%7D%2C%0A%20%20%20%20%7B0x3d403130%2C%200x20300%7D%2C%0A%20%20%20%20%7B0x3d403134%2C%200xa100002%7D%2C%0A%20%20%20%20%7B0x3d403138%2C%200x8%7D%2C%0A%20%20%20%20%7B0x3d403144%2C%200x50003%7D%2C%0A%20%20%20%20%7B0x3d403180%2C%200x190004%7D%2C%0A%20%20%20%20%7B0x3d403190%2C%200x3818200%7D%2C%0A%20%20%20%20%7B0x3d403194%2C%200x80303%7D%2C%0A%20%20%20%20%7B0x3d4031b4%2C%200x100%7D%2C%0A%20%20%20%20%7B0x3d4030f4%2C%200x599%7D%2C%0A%20%20%20%20%7B0x3d400028%2C%200x0%7D%2C%0A%7D%3B%3C%2FASM%3E%3C%2FLINUX%3E%3C%2FCODE%3E%3C%2FPRE%3E%3CP%3E%26nbsp%3BThank%20you%20for%20your%20reply.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2374706%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20IMX8MP%20Inline%20ECC%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2374706%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EHello!!!%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2375563%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20IMX8MP%20Inline%20ECC%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2375563%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%3EHello!%3C%2FLINGO-BODY%3E
