[IMX8MP] [ISP] AWB issue
jp4
Hello experts,
Currently we are performing IMX8MP ISP tuning for our own sensor IMX662.
We have followed all the steps as mentioned in ISP Calibration Tool Suite User Guide,
After calibration, AWB is not settling properly We are getting color error in IMA Test.
I have attached AWB data from calibration tool.
Below are the observations:
1. When we are keeping AWB mode = manual, color errors are better comparing to AWB mode =AUTO. Below are the detailed comparison of color errors from IMA Test.
2. We were getting AWB bouncing issue, but this was resolved by changing the damping parameters (i.e DampCoefAdd, DampCoefSub, DampingCoefMin and DampingCoefMax). Please let us know , is this correct way to adjust?
Please have a look and let us know how can we improve the results.
Below are the data, I have attached
1. Captured images for various color temperature when AWB mode=Auto and AWB mode=manual.
2. calibration xml data mentioned below
<?xml version="1.0" encoding="UTF-8"?>
<matfile>
   <header type="struct" size="[1 1]">
      <creation_date index="1" type="char" size="[1 11]">12-Nov-2024</creation_date>
      <creator index="1" type="char" size="[1 2]">jp</creator>
      <sensor_name index="1" type="char" size="[1 6]">IMX662</sensor_name>
      <sample_name index="1" type="char" size="[1 9]">8Mlens_09</sample_name>
      <generator_version index="1" type="char" size="[1 6]">v2.1.1</generator_version>
      <resolution index="1" type="cell" size="[1 1]">
         <cell index="1" type="struct" size="[1 1]">
            <name index="1" type="char" size="[1 9]">1920x1080</name>
            <id index="1" type="char" size="[1 10]">0x00000001</id>
            <width index="1" type="double" size="[1 1]">[ 1920]</width>
            <height index="1" type="double" size="[1 1]">[ 1080]</height>
            <framerate index="1" type="cell" size="[1 3]">
                  <name index="1" type="char" size="[1 6]">FPS_15</name>
                  <fps index="1" type="double" size="[1 1]">[ 14.9916]</fps>
               </cell>
               <cell index="2" type="struct" size="[1 1]">
                  <name index="1" type="char" size="[1 6]">FPS_10</name>
                  <fps index="1" type="double" size="[1 1]">[ 9.9944]</fps>
               </cell>
               <cell index="3" type="struct" size="[1 1]">
                  <name index="1" type="char" size="[1 6]">FPS_05</name>
                  <fps index="1" type="double" size="[1 1]">[ 4.9972]</fps>
               </cell>
            </framerate>
         </cell>
      </resolution>
   </header>
   <sensor type="struct" size="[1 1]">
      <AWB index="1" type="struct" size="[1 1]">
         <globals index="1" type="cell" size="[1 1]">
               <resolution index="1" type="char" size="[1 9]">1920x1080</resolution>
               <SVDMeanValue index="1" type="double" size="[1 3]">[0.418139 0.409389 0.17247]</SVDMeanValue>
               <PCAMatrix index="1" type="double" size="[3 2]">[-0.74298 0.0782569 0.664723 0.338596 -0.812738 0.47414]</PCAMatrix>
               <CenterLine index="1" type="double" size="[1 3]">[-0.959033 -0.283293 -1.9307]</CenterLine>
               <afRg2 index="1" type="double" size="[1 16]">[1.0763 1.14303 1.17773 1.21242 1.24711 1.28181 1.3165 1.35119 1.38589 1.42058 1.45527 1.48997 1.52466 1.55935 1.59405 1.7287]</afRg2>
               <afMaxDist2 index="1" type="double" size="[1 16]">[0.0191008 0.00274695 -0.0118831 -0.0261824 -0.0392815 -0.0513513 -0.0620177 -0.070842 -0.0776721 -0.081697 -0.0820254 -0.0767682 -0.0623423 -0.0268512 0.0584626 0.1746]</afMaxDist2>
               <afRg1 index="1" type="double" size="[1 16]">[1.0763 1.14303 1.17773 1.21242 1.24711 1.28181 1.3165 1.35119 1.38589 1.42058 1.45527 1.48997 1.52466 1.55935 1.59405 1.7287]</afRg1>
               <afMaxDist1 index="1" type="double" size="[1 16]">[-0.00910078 0.00725305 0.0218831 0.0361824 0.0492815 0.0613513 0.0720177 0.080842 0.0876721 0.091697 0.0920254 0.0867682 0.0723423 0.0368512 -0.0484626 -0.1646]</afMaxDist1>
               <afGlobalFade2 index="1" type="double" size="[1 16]">[0.8 0.857916 0.915832 0.973748 1.03166 1.08958 1.1475 1.21052 1.26094 1.32124 1.37916 1.43708 1.49499 1.55291 1.61082 1.6687]</afGlobalFade2>
               <afGlobalGainDistance2 index="1" type="double" size="[1 16]">[0.25925 0.225437 0.19315 0.16153 0.131693 0.102935 0.0752127 0.09253 0.0980166 0.0118005 -0.00153116 -0.00742353 -0.000484802 0.0388869 0.187696 0.38814]</afGlobalGainDistance2>
               <afGlobalFade1 index="1" type="double" size="[1 16]">[0.8 0.857916 0.915832 0.973748 1.03166 1.08958 1.1475 1.20541 1.26333 1.32124 1.37916 1.43708 1.49499 1.55291 1.61082 1.6687]</afGlobalFade1>
               <afGlobalGainDistance1 index="1" type="double" size="[1 16]">[-0.09925 -0.0654374 -0.0331497 -0.00153042 0.0283066 0.0570649 0.0847873 0.108278 0.130195 0.1482 0.161531 0.167424 0.160485 0.121113 -0.0276956 -0.22814]</afGlobalGainDistance1>
               <fRgProjIndoorMin index="1" type="double" size="[1 1]">[ 1.0763]</fRgProjIndoorMin>
               <fRgProjMax index="1" type="double" size="[1 1]">[ 1.6287]</fRgProjMax>
               <fRgProjMaxSky index="1" type="double" size="[1 1]">[ 1.6687]</fRgProjMaxSky>
               <fRgProjOutdoorMin index="1" type="double" size="[1 1]">[ 1.4206]</fRgProjOutdoorMin>
               <awb_clip_outdoor index="1" type="char" size="[1 3]">D50</awb_clip_outdoor>
               <K_Factor index="1" type="double" size="[1 1]">[ 4.5676]</K_Factor>
               <afFade2 index="1" type="double" size="[1 6]">[0.75 1.28836 1.77672 2.164 2.6 3.0618]</afFade2>
               <afCbMinRegionMax index="1" type="double" size="[1 6]">[114 114 105 95 95 90]</afCbMinRegionMax>
               <afCrMinRegionMax index="1" type="double" size="[1 6]">[83 83 110 120 122 128]</afCrMinRegionMax>
               <afMaxCSumRegionMax index="1" type="double" size="[1 6]">[28 27 18 16 9 9]</afMaxCSumRegionMax>
               <afCbMinRegionMin index="1" type="double" size="[1 6]">[123 123 123 123 123 120]</afCbMinRegionMin>
               <afCrMinRegionMin index="1" type="double" size="[1 6]">[123 123 123 123 123 126]</afCrMinRegionMin>
               <afMaxCSumRegionMin index="1" type="double" size="[1 6]">[5 5 5 5 5 5]</afMaxCSumRegionMin>
               <RegionSize index="1" type="double" size="[1 1]">[ 1]</RegionSize>
               <RegionSizeInc index="1" type="double" size="[1 1]">[ 0.8]</RegionSizeInc>
               <RegionSizeDec index="1" type="double" size="[1 1]">[ 0.05]</RegionSizeDec>
               <IIR index="1" type="struct" size="[1 1]">
                  <DampCoefAdd index="1" type="double" size="[1 1]">[ 0.5]</DampCoefAdd>
                  <DampCoefSub index="1" type="double" size="[1 1]">[ 0.1]</DampCoefSub>
                  <DampFilterThreshold index="1" type="double" size="[1 1]">[ 0.4]</DampFilterThreshold>
                  <DampingCoefMin index="1" type="double" size="[1 1]">[ 0]</DampingCoefMin>
                  <DampingCoefMax index="1" type="double" size="[1 1]">[ 1]</DampingCoefMax>
                  <DampingCoefInit index="1" type="double" size="[1 1]">[ 0.5]</DampingCoefInit>
                  <ExpPriorFilterSizeMax index="1" type="double" size="[1 1]">[ 50]</ExpPriorFilterSizeMax>
                  <ExpPriorFilterSizeMin index="1" type="double" size="[1 1]">[ 1]</ExpPriorFilterSizeMin>
                  <ExpPriorMiddle index="1" type="double" size="[1 1]">[ 0.5]</ExpPriorMiddle>
               </IIR>
            </cell>
         </globals>
         <illumination index="1" type="cell" size="[1 6]">
               <name index="1" type="char" size="[1 1]">A</name>
               <doorType index="1" type="char" size="[1 6]">Indoor</doorType>
               <GMM index="1" type="struct" size="[1 1]">
                  <invCovMatrix index="1" type="double" size="[2 2]">[3889.38 5092.55 5092.55 8995.8063]</invCovMatrix>
                  <GaussianScalingFactor index="1" type="double" size="[1 1]">[ 478.8962]</GaussianScalingFactor>
                  <tau index="1" type="double" size="[1 2]">[1 1]</tau>
                  <GaussianMeanValue index="1" type="double" size="[1 2]">[0.0166788 -0.039505]</GaussianMeanValue>
               </GMM>
               <aLSC index="1" type="cell" size="[1 1]">
                     <LSC_PROFILE_LIST index="1" type="char" size="[1 15]">1920x1080_A_100</LSC_PROFILE_LIST>
                  </cell>
               </aLSC>
               <manualWB index="1" type="double" size="[1 4]">[1.12853 1 1 2.6864]</manualWB>
               <manualccMatrix index="1" type="double" size="[3 3]">[1.70554 0.0634162 -0.768386 -0.872631 2.41039 -0.439703 -0.369813 0.491819 1.4153]</manualccMatrix>
               <manualccOffsets index="1" type="double" size="[1 3]">[-2.32714 -118.193 -1512.336]</manualccOffsets>
               <awbType index="1" type="char" size="[1 4]">AUTO</awbType>
               <sat_CT index="1" type="struct" size="[1 1]">
                  <gains index="1" type="double" size="[1 4]">[1 2 4 8]</gains>
                  <sat index="1" type="double" size="[1 4]">[100 95 90 74]</sat>
               </sat_CT>
               <vig_CT index="1" type="struct" size="[1 1]">
                  <vig index="1" type="double" size="[1 4]">[100 95 90 70]</vig>
               </vig_CT>
               <aCC index="1" type="struct" size="[1 1]">
                  <CC_PROFILE_LIST index="1" type="char" size="[1 5]">A_100</CC_PROFILE_LIST>
               </aCC>
            </cell>
               <name index="1" type="char" size="[1 3]">D50</name>
               <doorType index="1" type="char" size="[1 7]">Outdoor</doorType>
                  <invCovMatrix index="1" type="double" size="[2 2]">[513.764 586.253 586.253 2505.3213]</invCovMatrix>
                  <GaussianScalingFactor index="1" type="double" size="[1 1]">[ 154.5895]</GaussianScalingFactor>
                  <GaussianMeanValue index="1" type="double" size="[1 2]">[0.196182 -0.031194]</GaussianMeanValue>
               </GMM>
                     <LSC_PROFILE_LIST index="1" type="char" size="[1 17]">1920x1080_D65_100</LSC_PROFILE_LIST>
                  </cell>
               </aLSC>
               <manualWB index="1" type="double" size="[1 4]">[1.71912 1 1 1.5623]</manualWB>
               <manualccMatrix index="1" type="double" size="[3 3]">[1.63872 -0.100647 -0.395879 -0.508077 2.0874 -0.41751 -0.291141 -1.05548 3.482]</manualccMatrix>
               <manualccOffsets index="1" type="double" size="[1 3]">[-582.302 -193.36 -1121.9325]</manualccOffsets>
               </sat_CT>
               </vig_CT>
                  <CC_PROFILE_LIST index="1" type="char" size="[1 7]">D50_100</CC_PROFILE_LIST>
               </aCC>
            </cell>
               <name index="1" type="char" size="[1 3]">D65</name>
                  <invCovMatrix index="1" type="double" size="[2 2]">[322.718 177.242 177.242 1803.6517]</invCovMatrix>
                  <GaussianScalingFactor index="1" type="double" size="[1 1]">[ 118.1028]</GaussianScalingFactor>
                  <GaussianMeanValue index="1" type="double" size="[1 2]">[0.200979 -0.046944]</GaussianMeanValue>
               </GMM>
                  </cell>
               </aLSC>
               <manualWB index="1" type="double" size="[1 4]">[1.83168 1 1 1.6323]</manualWB>
               <manualccMatrix index="1" type="double" size="[3 3]">[1.82783 0.03077 -0.743202 -0.449706 1.95856 -0.445475 -0.0445922 -0.361816 1.6574]</manualccMatrix>
               <manualccOffsets index="1" type="double" size="[1 3]">[-472.566 -127.732 -564.3045]</manualccOffsets>
               </sat_CT>
               </vig_CT>
                  <CC_PROFILE_LIST index="1" type="char" size="[1 7]">D65_100</CC_PROFILE_LIST>
               </aCC>
            </cell>
            <cell index="4" type="struct" size="[1 1]">
               <name index="1" type="char" size="[1 3]">D75</name>
                  <invCovMatrix index="1" type="double" size="[2 2]">[287.517 62.8802 62.8802 1611.0278]</invCovMatrix>
                  <GaussianScalingFactor index="1" type="double" size="[1 1]">[ 107.8555]</GaussianScalingFactor>
                  <GaussianMeanValue index="1" type="double" size="[1 2]">[0.222258 -0.039505]</GaussianMeanValue>
               </GMM>
                     <LSC_PROFILE_LIST index="1" type="char" size="[1 17]">1920x1080_D75_100</LSC_PROFILE_LIST>
                  </cell>
               </aLSC>
               <manualWB index="1" type="double" size="[1 4]">[1.915 1 1 1.5221]</manualWB>
               <manualccMatrix index="1" type="double" size="[3 3]">[1.57609 0.0675493 -0.546618 -0.480967 2.41898 -0.590472 0.0123617 -0.766672 2.9685]</manualccMatrix>
               <manualccOffsets index="1" type="double" size="[1 3]">[-397.317 -144.073 -696.0122]</manualccOffsets>
               </sat_CT>
               </vig_CT>
                  <CC_PROFILE_LIST index="1" type="char" size="[1 7]">D75_100</CC_PROFILE_LIST>
               </aCC>
            </cell>
            <cell index="5" type="struct" size="[1 1]">
               <name index="1" type="char" size="[1 8]">F2 (CWF)</name>
                  <invCovMatrix index="1" type="double" size="[2 2]">[484.749 36.2971 36.2971 1458.5805]</invCovMatrix>
                  <GaussianScalingFactor index="1" type="double" size="[1 1]">[ 133.7022]</GaussianScalingFactor>
                  <GaussianMeanValue index="1" type="double" size="[1 2]">[0.10322 -0.10483]</GaussianMeanValue>
               </GMM>
                     <LSC_PROFILE_LIST index="1" type="char" size="[1 16]">1920x1080_F2_100</LSC_PROFILE_LIST>
                  </cell>
               </aLSC>
               <manualWB index="1" type="double" size="[1 4]">[1.64295 1 1 2.6265]</manualWB>
               <manualccMatrix index="1" type="double" size="[3 3]">[1.99494 -0.314082 -0.603437 -0.688478 1.89 -0.145871 -0.166597 -0.255025 1.7868]</manualccMatrix>
               <manualccOffsets index="1" type="double" size="[1 3]">[-317.018 -131.518 -1000.3296]</manualccOffsets>
               </sat_CT>
               </vig_CT>
                  <CC_PROFILE_LIST index="1" type="char" size="[1 6]">F2_100</CC_PROFILE_LIST>
               </aCC>
            </cell>
            <cell index="6" type="struct" size="[1 1]">
               <name index="1" type="char" size="[1 10]">F11 (TL84)</name>
                  <invCovMatrix index="1" type="double" size="[2 2]">[498.302 307.113 307.113 1578.884]</invCovMatrix>
                  <GaussianScalingFactor index="1" type="double" size="[1 1]">[ 132.4378]</GaussianScalingFactor>
                  <GaussianMeanValue index="1" type="double" size="[1 2]">[0.0741909 -0.061696]</GaussianMeanValue>
               </GMM>
                     <LSC_PROFILE_LIST index="1" type="char" size="[1 17]">1920x1080_F11_100</LSC_PROFILE_LIST>
                  </cell>
               </aLSC>
               <manualWB index="1" type="double" size="[1 4]">[1.36013 1 1 2.4169]</manualWB>
               <manualccMatrix index="1" type="double" size="[3 3]">[1.6608 -0.0812034 -0.514466 -0.732627 2.05142 -0.229307 -0.992776 0.103685 2.4784]</manualccMatrix>
               <manualccOffsets index="1" type="double" size="[1 3]">[-266.708 -180.449 -1304.605]</manualccOffsets>
               </sat_CT>
               </vig_CT>
                  <CC_PROFILE_LIST index="1" type="char" size="[1 7]">F11_100</CC_PROFILE_LIST>
               </aCC>
            </cell>
         </illumination>
      </AWB>
      <LSC index="1" type="cell" size="[1 5]">
            <name index="1" type="char" size="[1 15]">1920x1080_A_100</name>
            <illumination index="1" type="char" size="[1 1]">A</illumination>
            <LSC_sectors index="1" type="double" size="[1 1]">[ 16]</LSC_sectors>
            <LSC_No index="1" type="double" size="[1 1]">[ 10]</LSC_No>
            <LSC_Xo index="1" type="double" size="[1 1]">[ 15]</LSC_Xo>
            <LSC_Yo index="1" type="double" size="[1 1]">[ 15]</LSC_Yo>
            <LSC_SECT_SIZE_X index="1" type="double" size="[1 8]">[58 84 102 115 131 148 158 164]</LSC_SECT_SIZE_X>
            <LSC_SECT_SIZE_Y index="1" type="double" size="[1 8]">[52 60 63 72 71 74 74 74]</LSC_SECT_SIZE_Y>
            <vignetting index="1" type="double" size="[1 1]">[ 100]</vignetting>
            <LSC_SAMPLES_red index="1" type="double" size="[17 17]">[2130 1943 1720 1564 1433 1324 1246 1205 1197 1222 1289 1401 1552 1768 2033 2432 2760 2041 1842 1675 1517 1368 1266 1210 1167 1153 1186 1249 1347 1494 1680 1999 2217 2599 1937 1758 1607 1458 1330 1239 1170 1139 1124 1149 1210 1309 1445 1625 1820 2169 2393 1858 1705 1551 1414 1286 1189 1152 1108 1099 1125 1179 1276 1404 1569 1791 2039 2249 1808 1663 1517 1378 1272 1186 1121 1089 1083 1106 1159 1252 1370 1541 1727 1967 2173 1780 1663 1490 1364 1257 1174 1115 1083 1076 1101 1150 1239 1355 1510 1702 1924 2106 1740 1613 1471 1349 1250 1163 1108 1075 1065 1091 1142 1224 1340 1486 1680 1868 2051 1708 1630 1462 1334 1238 1153 1100 1053 1049 1078 1132 1211 1326 1472 1665 1845 2020 1715 1599 1443 1324 1224 1141 1091 1046 1042 1068 1119 1200 1312 1451 1635 1820 1982 1682 1567 1437 1314 1218 1128 1106 1050 1029 1058 1114 1187 1305 1447 1603 1794 1952 1665 1567 1436 1314 1212 1125 1076 1040 1024 1058 1107 1184 1291 1439 1593 1794 1903 1673 1594 1449 1327 1214 1131 1080 1043 1040 1063 1112 1191 1305 1441 1602 1807 1951 1695 1623 1481 1340 1228 1153 1095 1062 1057 1080 1127 1218 1322 1461 1640 1817 2038 1733 1655 1523 1389 1279 1184 1124 1090 1085 1107 1152 1252 1360 1511 1698 1906 2064 1804 1706 1584 1425 1321 1226 1165 1119 1116 1141 1197 1285 1420 1577 1764 1994 2120 1889 1772 1659 1477 1388 1276 1207 1160 1153 1184 1244 1343 1488 1658 1835 2078 2258 1960 1833 1726 1571 1442 1319 1247 1202 1191 1220 1286 1398 1537 1714 1934 2219 2342]</LSC_SAMPLES_red>
            <LSC_SAMPLES_greenR index="1" type="double" size="[17 17]">[2117 1912 1689 1536 1409 1307 1233 1193 1186 1210 1274 1379 1527 1739 1997 2394 2729 2016 1809 1643 1490 1345 1248 1198 1157 1143 1175 1237 1330 1472 1654 1961 2174 2556 1906 1728 1580 1433 1314 1225 1161 1130 1117 1141 1200 1293 1424 1599 1783 2123 2343 1828 1674 1523 1391 1271 1177 1145 1103 1094 1120 1170 1264 1387 1544 1758 1997 2201 1779 1635 1494 1361 1261 1178 1117 1086 1081 1104 1154 1243 1356 1520 1698 1929 2122 1753 1642 1470 1351 1247 1169 1113 1083 1075 1100 1148 1232 1344 1492 1677 1888 2058 1716 1593 1455 1339 1247 1161 1110 1075 1066 1092 1143 1222 1334 1471 1658 1833 2011 1686 1610 1447 1326 1235 1152 1101 1055 1049 1081 1134 1210 1320 1460 1647 1812 1980 1693 1581 1430 1316 1221 1142 1094 1047 1045 1068 1121 1200 1308 1439 1614 1785 1944 1659 1547 1424 1306 1215 1128 1108 1050 1030 1058 1117 1185 1299 1435 1585 1760 1912 1641 1546 1421 1306 1209 1124 1077 1040 1024 1058 1108 1182 1284 1427 1575 1755 1862 1650 1572 1433 1317 1209 1129 1080 1042 1040 1064 1113 1187 1298 1428 1580 1765 1909 1671 1603 1462 1334 1231 1152 1096 1063 1059 1082 1127 1214 1314 1450 1613 1775 1984 1710 1634 1505 1378 1276 1185 1125 1094 1087 1109 1152 1250 1351 1498 1670 1858 2027 1782 1684 1567 1409 1316 1226 1166 1124 1121 1142 1197 1282 1412 1565 1725 1949 2121 1868 1755 1640 1462 1379 1273 1209 1163 1157 1187 1244 1340 1478 1643 1804 2041 2284 1946 1822 1710 1559 1433 1318 1249 1206 1196 1222 1289 1392 1535 1698 1889 2201 2379]</LSC_SAMPLES_greenR>
            <LSC_SAMPLES_greenB index="1" type="double" size="[17 17]">[2120 1915 1692 1538 1411 1308 1235 1193 1186 1210 1275 1377 1528 1733 1996 2387 2724 2019 1811 1648 1491 1347 1250 1198 1157 1145 1175 1238 1329 1471 1652 1955 2167 2553 1912 1729 1582 1434 1315 1226 1163 1132 1117 1143 1200 1295 1423 1600 1783 2122 2333 1831 1678 1525 1395 1273 1178 1146 1104 1095 1120 1173 1263 1388 1542 1756 1993 2195 1784 1639 1498 1362 1263 1180 1120 1088 1082 1105 1155 1245 1356 1519 1698 1926 2119 1754 1646 1473 1353 1251 1171 1114 1084 1076 1101 1149 1234 1345 1491 1676 1883 2058 1723 1594 1460 1342 1246 1163 1111 1077 1067 1092 1145 1221 1334 1471 1657 1830 2011 1687 1614 1449 1328 1237 1154 1103 1056 1050 1081 1135 1212 1320 1460 1644 1813 1977 1695 1585 1432 1319 1223 1143 1096 1049 1045 1070 1122 1201 1308 1441 1614 1785 1942 1661 1550 1426 1309 1218 1130 1109 1051 1032 1059 1117 1186 1300 1434 1583 1760 1911 1644 1549 1424 1308 1211 1126 1079 1041 1024 1059 1110 1183 1284 1429 1575 1758 1861 1653 1576 1437 1319 1212 1130 1082 1044 1041 1065 1115 1187 1300 1428 1580 1766 1905 1674 1606 1466 1338 1232 1155 1098 1065 1060 1082 1129 1215 1315 1449 1614 1776 1982 1715 1638 1509 1382 1280 1186 1126 1095 1089 1111 1153 1251 1352 1499 1671 1857 2030 1790 1689 1571 1413 1317 1229 1169 1126 1122 1145 1199 1283 1413 1566 1725 1950 2118 1875 1759 1645 1469 1384 1275 1211 1164 1159 1188 1245 1342 1479 1643 1806 2044 2283 1957 1827 1716 1564 1437 1322 1250 1211 1198 1225 1292 1396 1534 1700 1894 2198 2388]</LSC_SAMPLES_greenB>
            <LSC_SAMPLES_blue index="1" type="double" size="[17 17]">[1794 1654 1498 1400 1308 1231 1177 1147 1142 1161 1210 1285 1390 1539 1707 1938 2141 1735 1593 1488 1373 1268 1196 1160 1126 1118 1143 1191 1260 1360 1491 1680 1819 2035 1665 1545 1442 1335 1249 1183 1134 1109 1099 1119 1166 1235 1332 1450 1582 1783 1906 1610 1506 1400 1305 1216 1145 1121 1088 1082 1102 1142 1214 1306 1415 1559 1712 1821 1583 1485 1381 1285 1212 1150 1103 1078 1073 1093 1130 1200 1285 1399 1525 1666 1774 1567 1489 1370 1284 1205 1146 1099 1074 1070 1090 1130 1197 1275 1384 1512 1643 1737 1545 1455 1361 1274 1207 1140 1100 1071 1061 1085 1127 1187 1273 1368 1502 1609 1707 1526 1475 1352 1266 1198 1133 1094 1035 1052 1077 1119 1180 1261 1365 1493 1597 1690 1528 1452 1341 1257 1185 1125 1086 1038 1046 1066 1109 1172 1252 1348 1471 1576 1664 1502 1423 1333 1249 1178 1112 1095 1047 1032 1056 1103 1156 1245 1344 1450 1552 1638 1489 1420 1331 1245 1174 1108 1068 1035 1024 1052 1094 1153 1228 1335 1438 1541 1607 1494 1438 1336 1254 1173 1107 1071 1037 1036 1058 1097 1155 1239 1333 1438 1544 1622 1508 1454 1357 1265 1187 1125 1081 1054 1052 1069 1108 1174 1251 1348 1450 1546 1656 1533 1478 1389 1298 1224 1152 1107 1080 1075 1093 1126 1203 1279 1380 1489 1586 1699 1589 1519 1437 1323 1254 1187 1143 1108 1106 1124 1166 1232 1325 1432 1514 1643 1773 1654 1581 1498 1372 1315 1233 1185 1147 1142 1167 1213 1286 1387 1494 1584 1720 1898 1701 1612 1543 1434 1348 1261 1210 1177 1172 1194 1244 1323 1421 1522 1617 1815 1980]</LSC_SAMPLES_blue>
         </cell>
            <name index="1" type="char" size="[1 17]">1920x1080_D65_100</name>
            <illumination index="1" type="char" size="[1 3]">D65</illumination>
            <LSC_SECT_SIZE_X index="1" type="double" size="[1 8]">[66 88 104 117 131 143 151 160]</LSC_SECT_SIZE_X>
            <LSC_SECT_SIZE_Y index="1" type="double" size="[1 8]">[56 60 64 70 71 73 74 72]</LSC_SECT_SIZE_Y>
            <LSC_SAMPLES_red index="1" type="double" size="[17 17]">[1963 1800 1627 1509 1392 1310 1246 1211 1206 1225 1280 1364 1487 1646 1840 2130 2380 1895 1717 1595 1459 1344 1261 1213 1177 1166 1191 1243 1321 1431 1578 1803 1976 2256 1808 1660 1532 1407 1302 1226 1172 1146 1131 1153 1199 1280 1388 1527 1676 1930 2103 1735 1600 1474 1357 1257 1185 1138 1105 1097 1118 1161 1237 1338 1467 1634 1826 1988 1673 1547 1425 1313 1228 1154 1100 1074 1068 1086 1127 1201 1294 1426 1572 1750 1914 1636 1527 1388 1286 1199 1131 1082 1057 1049 1069 1107 1175 1266 1388 1534 1701 1848 1600 1482 1369 1271 1188 1115 1072 1043 1033 1055 1097 1158 1251 1359 1515 1653 1801 1581 1505 1363 1262 1180 1109 1068 1034 1024 1048 1091 1155 1242 1357 1509 1646 1785 1603 1494 1367 1268 1181 1113 1075 1038 1032 1049 1093 1156 1249 1356 1500 1646 1773 1596 1491 1381 1279 1196 1120 1108 1052 1036 1059 1107 1163 1261 1373 1503 1645 1790 1606 1511 1400 1295 1210 1133 1094 1061 1045 1073 1116 1179 1264 1384 1514 1667 1773 1625 1541 1417 1313 1211 1150 1097 1069 1065 1085 1127 1188 1286 1395 1528 1686 1812 1638 1565 1440 1316 1226 1161 1112 1083 1077 1099 1136 1211 1295 1410 1545 1694 1863 1654 1577 1461 1346 1252 1177 1121 1090 1091 1111 1146 1229 1313 1433 1582 1734 1880 1693 1598 1491 1364 1282 1195 1144 1100 1106 1125 1172 1239 1346 1472 1610 1789 1902 1742 1638 1532 1390 1316 1224 1172 1123 1124 1149 1198 1272 1383 1521 1648 1835 1980 1798 1678 1584 1457 1356 1259 1197 1155 1148 1175 1227 1311 1418 1552 1713 1920 2044]</LSC_SAMPLES_red>
            <LSC_SAMPLES_greenR index="1" type="double" size="[17 17]">[2076 1867 1667 1533 1409 1322 1257 1223 1212 1236 1291 1379 1511 1689 1915 2245 2582 1979 1773 1630 1479 1358 1269 1221 1183 1172 1198 1252 1333 1453 1614 1869 2061 2409 1875 1705 1560 1423 1313 1235 1178 1152 1136 1159 1208 1290 1403 1557 1715 2005 2207 1784 1636 1493 1369 1264 1190 1145 1109 1100 1122 1167 1244 1353 1489 1670 1878 2069 1713 1575 1442 1321 1234 1158 1104 1076 1070 1090 1133 1207 1306 1445 1599 1794 1973 1670 1555 1401 1295 1205 1133 1084 1057 1049 1073 1111 1182 1275 1400 1557 1737 1890 1628 1506 1384 1278 1196 1119 1076 1045 1035 1057 1101 1165 1262 1374 1536 1681 1842 1613 1533 1377 1274 1190 1117 1073 1037 1024 1053 1097 1163 1252 1375 1532 1676 1824 1638 1526 1382 1283 1194 1123 1083 1041 1037 1056 1103 1167 1265 1376 1525 1677 1819 1638 1520 1405 1296 1209 1131 1118 1058 1043 1066 1119 1176 1278 1398 1531 1677 1827 1648 1548 1423 1316 1227 1147 1106 1068 1051 1083 1129 1193 1284 1411 1549 1701 1808 1672 1580 1443 1335 1227 1165 1111 1079 1074 1097 1143 1205 1306 1421 1561 1721 1856 1685 1606 1468 1345 1252 1176 1124 1094 1088 1112 1149 1228 1317 1439 1577 1728 1908 1703 1618 1487 1370 1275 1192 1135 1106 1104 1124 1158 1246 1333 1463 1613 1762 1936 1751 1641 1524 1383 1299 1212 1160 1119 1118 1138 1185 1257 1368 1504 1635 1822 1994 1803 1686 1565 1411 1338 1240 1185 1142 1138 1164 1215 1291 1408 1554 1679 1874 2109 1867 1738 1628 1486 1374 1275 1212 1172 1165 1192 1246 1331 1449 1590 1740 1990 2206]</LSC_SAMPLES_greenR>
            <LSC_SAMPLES_greenB index="1" type="double" size="[17 17]">[2067 1861 1663 1530 1404 1317 1253 1218 1208 1232 1287 1372 1504 1683 1905 2236 2557 1976 1770 1625 1476 1353 1267 1216 1180 1169 1194 1248 1328 1447 1605 1857 2049 2393 1873 1700 1555 1418 1309 1232 1174 1147 1132 1156 1204 1286 1398 1549 1706 1996 2195 1783 1632 1489 1366 1262 1186 1141 1106 1097 1118 1162 1239 1348 1483 1662 1870 2053 1711 1571 1438 1317 1231 1155 1101 1073 1067 1087 1128 1205 1298 1439 1591 1786 1959 1667 1555 1397 1292 1201 1131 1080 1055 1045 1068 1108 1177 1272 1394 1551 1726 1884 1626 1503 1381 1275 1192 1117 1073 1042 1032 1053 1097 1161 1256 1369 1529 1675 1832 1609 1531 1375 1271 1187 1113 1070 1035 1024 1049 1095 1160 1250 1369 1526 1672 1819 1640 1520 1382 1280 1191 1120 1080 1039 1034 1052 1101 1164 1259 1373 1518 1672 1808 1632 1520 1401 1294 1208 1129 1116 1056 1040 1064 1116 1172 1275 1391 1527 1671 1822 1645 1543 1422 1312 1223 1144 1104 1064 1049 1079 1128 1190 1278 1407 1543 1696 1805 1666 1578 1442 1333 1226 1161 1107 1077 1072 1094 1139 1200 1302 1417 1554 1712 1851 1684 1604 1465 1342 1249 1174 1121 1089 1086 1108 1149 1224 1312 1435 1570 1723 1898 1701 1613 1485 1370 1271 1189 1132 1103 1100 1121 1154 1243 1329 1458 1608 1758 1929 1745 1641 1523 1379 1298 1210 1157 1117 1116 1135 1182 1253 1361 1500 1630 1815 1984 1802 1683 1562 1410 1334 1237 1182 1138 1135 1161 1211 1288 1403 1549 1673 1867 2097 1872 1733 1628 1485 1374 1274 1207 1173 1161 1190 1242 1328 1446 1583 1733 1983 2197]</LSC_SAMPLES_greenB>
            <LSC_SAMPLES_blue index="1" type="double" size="[17 17]">[1827 1659 1513 1415 1317 1255 1207 1176 1169 1188 1235 1296 1401 1531 1700 1920 2162 1753 1597 1492 1379 1285 1219 1182 1153 1144 1166 1208 1270 1362 1485 1659 1800 2031 1679 1548 1440 1333 1252 1193 1149 1127 1114 1134 1173 1238 1323 1437 1557 1754 1885 1604 1494 1383 1291 1212 1153 1120 1091 1084 1102 1137 1200 1283 1383 1516 1664 1778 1555 1445 1344 1251 1187 1129 1084 1063 1058 1077 1107 1167 1243 1346 1465 1599 1710 1521 1433 1314 1232 1162 1107 1067 1047 1041 1058 1094 1147 1221 1313 1432 1559 1649 1486 1394 1299 1219 1157 1096 1063 1036 1027 1048 1083 1135 1208 1294 1418 1519 1612 1482 1422 1297 1219 1153 1095 1061 1030 1024 1043 1082 1135 1206 1298 1417 1515 1607 1505 1414 1306 1230 1157 1104 1072 1037 1037 1049 1090 1141 1217 1301 1415 1520 1605 1505 1415 1325 1242 1176 1112 1103 1053 1044 1061 1106 1151 1230 1321 1427 1515 1612 1515 1435 1344 1260 1190 1128 1092 1062 1051 1075 1117 1166 1236 1335 1439 1535 1602 1531 1464 1359 1275 1193 1141 1097 1072 1069 1089 1127 1173 1255 1342 1447 1540 1624 1542 1482 1374 1280 1208 1148 1106 1081 1078 1098 1130 1191 1261 1354 1449 1541 1646 1550 1487 1386 1300 1225 1158 1114 1090 1088 1106 1131 1206 1269 1368 1468 1554 1671 1584 1503 1416 1305 1244 1174 1134 1099 1101 1116 1154 1211 1295 1400 1471 1584 1727 1629 1543 1449 1333 1279 1201 1156 1120 1117 1140 1182 1242 1332 1438 1509 1626 1839 1672 1566 1495 1383 1304 1224 1173 1142 1137 1162 1203 1269 1362 1454 1534 1721 1914]</LSC_SAMPLES_blue>
         </cell>
            <name index="1" type="char" size="[1 17]">1920x1080_D75_100</name>
            <illumination index="1" type="char" size="[1 3]">D75</illumination>
            <LSC_SECT_SIZE_X index="1" type="double" size="[1 8]">[60 84 102 118 131 146 158 161]</LSC_SECT_SIZE_X>
            <LSC_SECT_SIZE_Y index="1" type="double" size="[1 8]">[53 61 65 70 73 73 73 72]</LSC_SECT_SIZE_Y>
            <LSC_SAMPLES_red index="1" type="double" size="[17 17]">[1961 1797 1618 1490 1374 1280 1218 1181 1172 1194 1253 1345 1472 1656 1878 2226 2516 1888 1718 1581 1447 1320 1235 1180 1149 1137 1161 1216 1303 1420 1586 1854 2049 2369 1808 1659 1524 1400 1285 1203 1148 1117 1105 1127 1179 1267 1382 1533 1702 2012 2201 1743 1607 1479 1357 1250 1171 1121 1087 1081 1102 1152 1235 1345 1486 1676 1898 2106 1696 1570 1449 1326 1230 1152 1099 1070 1065 1083 1130 1212 1311 1459 1623 1834 2023 1671 1566 1425 1310 1215 1139 1087 1062 1056 1076 1119 1197 1295 1432 1596 1796 1963 1641 1527 1413 1298 1208 1131 1083 1052 1044 1066 1115 1183 1286 1413 1580 1753 1926 1627 1545 1404 1292 1200 1123 1079 1042 1032 1059 1106 1179 1276 1407 1577 1742 1904 1632 1527 1392 1287 1191 1120 1076 1037 1032 1051 1101 1173 1271 1398 1561 1730 1891 1617 1510 1397 1288 1196 1114 1096 1040 1024 1051 1102 1167 1272 1402 1552 1717 1898 1621 1520 1405 1292 1198 1119 1075 1039 1025 1053 1102 1170 1267 1403 1555 1730 1920 1642 1545 1417 1307 1199 1130 1074 1045 1039 1061 1108 1176 1283 1409 1569 1759 1944 1670 1578 1446 1322 1219 1149 1091 1062 1055 1078 1122 1203 1301 1434 1600 1810 1986 1704 1616 1482 1365 1257 1174 1115 1081 1080 1101 1145 1234 1337 1478 1671 1863 2125 1776 1667 1536 1409 1302 1211 1150 1107 1107 1131 1182 1267 1386 1545 1724 1986 2196 1862 1737 1605 1441 1359 1251 1191 1142 1141 1168 1229 1316 1448 1619 1820 2097 2334 1958 1810 1674 1525 1408 1299 1229 1184 1178 1208 1265 1368 1500 1676 1912 2213 2496]</LSC_SAMPLES_red>
            <LSC_SAMPLES_greenR index="1" type="double" size="[17 17]">[2074 1866 1657 1512 1383 1287 1220 1181 1174 1196 1257 1351 1492 1705 1965 2408 2833 1976 1773 1614 1462 1329 1238 1183 1149 1136 1161 1219 1308 1437 1617 1936 2170 2608 1876 1700 1548 1409 1289 1205 1147 1117 1104 1127 1180 1270 1393 1565 1744 2130 2358 1795 1647 1500 1367 1253 1173 1122 1086 1081 1102 1152 1239 1355 1508 1719 1985 2238 1746 1602 1469 1334 1236 1155 1099 1072 1064 1087 1132 1218 1322 1480 1659 1903 2129 1714 1603 1444 1321 1221 1144 1091 1062 1057 1079 1126 1203 1308 1451 1628 1858 2048 1688 1558 1432 1311 1218 1136 1088 1054 1045 1070 1120 1191 1301 1434 1615 1811 2008 1665 1583 1426 1303 1211 1131 1083 1044 1033 1064 1114 1187 1289 1430 1611 1793 1982 1679 1560 1412 1301 1203 1126 1082 1037 1034 1054 1108 1181 1287 1418 1592 1782 1966 1661 1539 1416 1300 1205 1121 1101 1042 1026 1052 1108 1174 1286 1423 1582 1764 1970 1663 1550 1423 1301 1208 1122 1081 1038 1024 1055 1107 1178 1276 1420 1589 1779 1992 1682 1574 1435 1317 1205 1135 1077 1046 1038 1062 1112 1182 1295 1424 1600 1808 2019 1715 1615 1467 1336 1231 1152 1094 1062 1057 1079 1125 1210 1309 1455 1626 1857 2064 1757 1655 1503 1381 1268 1181 1119 1085 1082 1105 1146 1242 1347 1500 1703 1919 2232 1847 1717 1565 1424 1317 1218 1159 1115 1114 1134 1188 1276 1403 1577 1765 2061 2363 1951 1797 1646 1462 1378 1262 1201 1154 1149 1178 1238 1331 1472 1659 1882 2197 2585 2073 1896 1729 1556 1430 1315 1241 1196 1188 1216 1283 1382 1535 1729 1975 2380 2812]</LSC_SAMPLES_greenR>
            <LSC_SAMPLES_greenB index="1" type="double" size="[17 17]">[2085 1866 1657 1512 1384 1285 1219 1181 1171 1196 1255 1347 1489 1701 1955 2399 2818 1975 1775 1614 1463 1328 1238 1182 1148 1136 1160 1218 1306 1435 1614 1929 2164 2593 1879 1704 1548 1411 1289 1204 1148 1117 1104 1127 1180 1270 1391 1560 1739 2127 2344 1798 1647 1499 1368 1254 1173 1122 1085 1080 1101 1151 1238 1353 1507 1716 1976 2234 1748 1602 1468 1336 1236 1155 1098 1071 1064 1086 1133 1214 1322 1477 1654 1895 2123 1714 1606 1446 1323 1221 1144 1090 1062 1056 1079 1125 1202 1308 1447 1628 1854 2045 1691 1558 1436 1312 1218 1138 1088 1054 1045 1070 1120 1191 1300 1433 1612 1805 2001 1668 1585 1427 1303 1212 1131 1083 1043 1033 1062 1113 1186 1289 1430 1607 1792 1973 1681 1561 1412 1302 1204 1126 1083 1038 1033 1054 1109 1180 1285 1417 1593 1778 1959 1662 1541 1419 1300 1205 1121 1101 1041 1026 1052 1108 1173 1283 1420 1579 1762 1966 1662 1550 1424 1303 1208 1124 1079 1038 1024 1054 1105 1178 1276 1420 1588 1775 1988 1685 1581 1435 1316 1206 1134 1077 1045 1039 1062 1111 1182 1292 1422 1600 1801 2014 1719 1615 1466 1338 1233 1152 1095 1062 1057 1078 1126 1208 1310 1454 1625 1853 2064 1758 1658 1504 1381 1270 1182 1119 1087 1083 1104 1146 1242 1345 1499 1703 1916 2225 1851 1718 1570 1425 1317 1220 1162 1116 1113 1136 1189 1275 1402 1577 1763 2060 2356 1958 1802 1649 1465 1379 1265 1202 1154 1150 1179 1238 1330 1470 1660 1878 2194 2581 2077 1903 1732 1559 1432 1315 1239 1199 1188 1219 1281 1385 1538 1729 1977 2379 2812]</LSC_SAMPLES_greenB>
            <LSC_SAMPLES_blue index="1" type="double" size="[17 17]">[1794 1637 1484 1380 1290 1216 1170 1140 1133 1151 1198 1265 1371 1524 1712 2012 2298 1724 1575 1465 1351 1251 1184 1145 1118 1107 1130 1172 1240 1334 1470 1690 1859 2142 1652 1530 1412 1313 1222 1162 1118 1096 1085 1103 1144 1214 1306 1427 1559 1824 1965 1596 1486 1380 1280 1196 1135 1098 1072 1069 1085 1121 1190 1279 1386 1542 1725 1890 1561 1457 1356 1258 1185 1125 1083 1062 1058 1076 1110 1175 1255 1369 1501 1668 1816 1545 1467 1345 1252 1179 1116 1077 1057 1052 1073 1107 1170 1247 1349 1479 1645 1754 1529 1428 1336 1248 1179 1114 1079 1052 1045 1066 1106 1160 1245 1340 1474 1607 1732 1514 1454 1334 1241 1173 1110 1076 1041 1037 1060 1101 1158 1237 1341 1473 1598 1713 1523 1435 1322 1239 1164 1107 1073 1036 1039 1050 1097 1153 1234 1330 1461 1587 1700 1510 1415 1326 1237 1167 1099 1089 1038 1030 1049 1095 1145 1232 1332 1451 1574 1698 1505 1422 1329 1237 1166 1103 1066 1033 1024 1047 1091 1145 1222 1330 1451 1572 1713 1518 1441 1333 1248 1162 1107 1062 1037 1033 1052 1093 1148 1233 1327 1458 1585 1720 1540 1468 1355 1260 1181 1120 1075 1049 1045 1064 1101 1168 1240 1349 1467 1614 1742 1567 1494 1381 1296 1210 1143 1094 1069 1065 1084 1115 1193 1267 1380 1516 1654 1845 1633 1542 1432 1327 1250 1173 1129 1095 1093 1111 1152 1221 1311 1439 1554 1740 1961 1721 1610 1497 1365 1303 1217 1167 1129 1125 1149 1198 1266 1373 1507 1643 1841 2137 1805 1675 1557 1427 1341 1251 1196 1160 1154 1180 1228 1308 1419 1547 1698 1975 2307]</LSC_SAMPLES_blue>
         </cell>
            <name index="1" type="char" size="[1 17]">1920x1080_F11_100</name>
            <illumination index="1" type="char" size="[1 3]">F11</illumination>
            <LSC_SECT_SIZE_X index="1" type="double" size="[1 8]">[58 82 101 119 129 147 160 164]</LSC_SECT_SIZE_X>
            <LSC_SECT_SIZE_Y index="1" type="double" size="[1 8]">[54 60 63 68 72 72 76 75]</LSC_SECT_SIZE_Y>
            <LSC_SAMPLES_red index="1" type="double" size="[17 17]">[2141 1945 1727 1573 1438 1335 1261 1218 1209 1233 1302 1409 1555 1767 2022 2401 2718 2049 1848 1690 1533 1383 1285 1224 1183 1168 1202 1262 1361 1500 1688 1988 2195 2561 1948 1768 1623 1475 1346 1255 1189 1156 1141 1166 1226 1324 1455 1636 1824 2149 2365 1868 1706 1560 1427 1299 1209 1165 1122 1111 1139 1190 1287 1412 1576 1794 2022 2227 1809 1660 1516 1383 1276 1186 1131 1097 1090 1111 1163 1255 1369 1541 1720 1946 2141 1761 1647 1479 1353 1247 1164 1113 1080 1073 1095 1142 1231 1340 1495 1678 1887 2055 1715 1590 1451 1335 1233 1150 1098 1064 1055 1078 1129 1208 1318 1461 1646 1819 1998 1676 1601 1441 1315 1218 1135 1086 1047 1034 1063 1116 1194 1300 1445 1628 1791 1959 1687 1572 1425 1308 1208 1129 1081 1037 1030 1055 1105 1184 1290 1429 1600 1775 1930 1666 1554 1427 1309 1210 1124 1100 1045 1024 1052 1108 1179 1294 1432 1582 1761 1916 1669 1569 1443 1322 1219 1127 1084 1047 1029 1062 1113 1190 1292 1441 1589 1783 1895 1691 1609 1467 1345 1227 1148 1091 1058 1054 1077 1127 1204 1315 1452 1610 1807 1954 1721 1643 1505 1362 1255 1176 1112 1080 1074 1100 1145 1237 1338 1478 1654 1822 2054 1757 1676 1541 1408 1294 1201 1138 1101 1096 1123 1168 1269 1370 1524 1705 1911 2074 1821 1718 1594 1444 1332 1241 1173 1119 1118 1153 1207 1296 1423 1580 1765 1998 2125 1900 1772 1657 1481 1385 1274 1212 1152 1148 1187 1245 1344 1477 1650 1822 2067 2245 1972 1829 1718 1565 1434 1313 1243 1187 1177 1217 1283 1388 1523 1693 1915 2192 2321]</LSC_SAMPLES_red>
            <LSC_SAMPLES_greenR index="1" type="double" size="[17 17]">[2138 1918 1696 1548 1413 1315 1245 1203 1197 1222 1284 1386 1531 1741 1996 2378 2723 2023 1818 1659 1500 1361 1265 1212 1172 1156 1189 1250 1341 1478 1663 1958 2161 2539 1920 1732 1592 1447 1325 1239 1177 1146 1131 1157 1214 1306 1433 1609 1792 2110 2328 1834 1675 1529 1401 1279 1194 1155 1115 1104 1131 1179 1272 1392 1550 1759 1985 2184 1772 1625 1485 1359 1258 1172 1123 1090 1084 1105 1153 1243 1350 1516 1689 1906 2097 1726 1617 1452 1331 1232 1153 1105 1074 1067 1089 1136 1218 1324 1471 1648 1845 2014 1678 1560 1427 1314 1219 1140 1092 1060 1050 1074 1122 1198 1304 1440 1616 1780 1951 1644 1570 1416 1297 1207 1128 1081 1043 1030 1060 1110 1184 1287 1424 1602 1754 1918 1656 1547 1402 1292 1198 1123 1077 1035 1029 1051 1103 1177 1279 1409 1574 1735 1885 1636 1528 1407 1294 1202 1118 1099 1043 1024 1050 1107 1173 1283 1417 1559 1727 1873 1640 1543 1422 1308 1211 1122 1082 1046 1028 1062 1112 1185 1281 1426 1569 1741 1850 1664 1583 1446 1331 1219 1143 1089 1057 1053 1077 1125 1198 1307 1437 1585 1768 1913 1688 1618 1483 1351 1250 1172 1111 1079 1073 1098 1143 1230 1326 1463 1625 1784 1999 1730 1646 1517 1393 1286 1198 1136 1104 1096 1121 1164 1261 1358 1508 1674 1863 2038 1795 1690 1571 1423 1319 1233 1171 1125 1119 1150 1201 1287 1410 1563 1720 1947 2124 1867 1747 1629 1458 1370 1264 1204 1154 1146 1184 1238 1331 1462 1626 1785 2024 2265 1942 1805 1693 1539 1417 1302 1233 1187 1176 1212 1276 1376 1509 1672 1866 2171 2348]</LSC_SAMPLES_greenR>
            <LSC_SAMPLES_greenB index="1" type="double" size="[17 17]">[2132 1919 1697 1546 1413 1315 1244 1204 1196 1219 1283 1383 1528 1737 1989 2367 2714 2029 1816 1660 1504 1359 1266 1211 1171 1157 1188 1250 1339 1476 1659 1950 2154 2534 1919 1735 1593 1447 1326 1239 1176 1145 1131 1155 1212 1305 1431 1606 1787 2108 2316 1837 1674 1529 1402 1278 1194 1154 1114 1103 1130 1178 1271 1390 1549 1754 1981 2176 1770 1629 1486 1359 1259 1172 1124 1090 1085 1105 1153 1241 1349 1512 1686 1902 2091 1727 1620 1452 1332 1233 1154 1104 1074 1067 1089 1134 1218 1323 1468 1644 1841 2009 1682 1559 1429 1315 1217 1140 1092 1060 1049 1073 1123 1197 1302 1436 1613 1778 1945 1645 1572 1416 1297 1207 1128 1081 1043 1030 1059 1110 1184 1285 1423 1598 1751 1914 1655 1549 1402 1293 1198 1123 1078 1035 1028 1051 1103 1176 1279 1408 1573 1733 1883 1637 1529 1409 1295 1202 1117 1099 1043 1024 1049 1107 1172 1281 1416 1557 1724 1871 1638 1546 1424 1310 1212 1123 1083 1045 1029 1061 1112 1183 1280 1424 1568 1738 1850 1665 1585 1449 1330 1220 1143 1089 1057 1053 1076 1124 1198 1306 1437 1583 1765 1910 1692 1621 1482 1353 1250 1173 1111 1080 1073 1099 1144 1228 1326 1463 1623 1781 1995 1732 1648 1520 1392 1289 1198 1137 1105 1096 1122 1164 1261 1357 1507 1674 1858 2034 1800 1693 1570 1424 1320 1235 1173 1125 1119 1150 1202 1286 1410 1561 1718 1947 2118 1871 1750 1633 1460 1371 1266 1205 1156 1146 1185 1238 1332 1462 1627 1784 2025 2258 1954 1806 1695 1542 1417 1302 1233 1189 1176 1213 1276 1376 1507 1669 1865 2162 2349]</LSC_SAMPLES_greenB>
            <LSC_SAMPLES_blue index="1" type="double" size="[17 17]">[1803 1654 1503 1403 1304 1238 1186 1155 1149 1167 1218 1285 1390 1535 1706 1929 2151 1743 1595 1492 1380 1274 1209 1171 1139 1125 1155 1198 1267 1362 1495 1679 1816 2038 1669 1548 1447 1344 1255 1192 1145 1122 1110 1130 1175 1245 1336 1456 1583 1781 1902 1612 1505 1399 1309 1221 1157 1129 1099 1090 1110 1149 1218 1307 1415 1559 1701 1811 1575 1469 1369 1279 1207 1141 1106 1080 1076 1094 1129 1196 1278 1393 1512 1653 1757 1544 1465 1347 1259 1185 1126 1090 1066 1061 1079 1114 1180 1256 1359 1484 1607 1698 1507 1419 1328 1245 1176 1115 1079 1053 1044 1065 1103 1160 1239 1336 1461 1564 1656 1480 1434 1315 1232 1166 1104 1068 1037 1030 1051 1092 1150 1227 1325 1450 1542 1636 1490 1412 1309 1226 1155 1100 1064 1028 1030 1044 1088 1143 1220 1313 1431 1528 1611 1474 1396 1311 1228 1160 1095 1082 1037 1024 1044 1089 1139 1221 1319 1422 1514 1602 1476 1410 1324 1241 1169 1100 1070 1038 1027 1053 1096 1150 1220 1328 1429 1525 1591 1498 1441 1343 1259 1177 1117 1076 1049 1048 1067 1108 1160 1242 1335 1439 1539 1618 1517 1469 1368 1276 1200 1141 1092 1067 1065 1084 1122 1187 1258 1359 1456 1548 1665 1543 1485 1395 1308 1232 1161 1115 1090 1082 1104 1135 1214 1281 1387 1489 1588 1703 1593 1518 1437 1329 1255 1192 1144 1108 1104 1129 1167 1233 1321 1430 1508 1639 1776 1652 1569 1485 1362 1303 1222 1176 1134 1130 1160 1204 1274 1370 1476 1562 1700 1899 1687 1595 1523 1412 1329 1242 1189 1158 1148 1179 1228 1301 1396 1491 1591 1800 1963]</LSC_SAMPLES_blue>
         </cell>
            <name index="1" type="char" size="[1 16]">1920x1080_F2_100</name>
            <illumination index="1" type="char" size="[1 2]">F2</illumination>
            <LSC_SECT_SIZE_X index="1" type="double" size="[1 8]">[63 87 101 118 128 144 156 163]</LSC_SECT_SIZE_X>
            <LSC_SECT_SIZE_Y index="1" type="double" size="[1 8]">[55 60 63 68 73 73 75 73]</LSC_SECT_SIZE_Y>
            <LSC_SAMPLES_red index="1" type="double" size="[17 17]">[2024 1846 1648 1522 1397 1310 1242 1207 1196 1221 1278 1373 1498 1683 1890 2216 2491 1946 1755 1616 1477 1349 1261 1211 1173 1160 1188 1245 1329 1451 1611 1860 2046 2363 1857 1688 1557 1427 1313 1234 1176 1147 1133 1155 1208 1296 1408 1563 1726 2007 2202 1784 1633 1498 1382 1270 1191 1151 1114 1104 1128 1175 1260 1366 1513 1693 1904 2084 1728 1587 1458 1340 1249 1165 1120 1088 1082 1102 1147 1229 1327 1475 1630 1833 2012 1680 1575 1420 1315 1218 1146 1099 1072 1064 1085 1127 1203 1299 1432 1593 1777 1933 1643 1519 1398 1293 1205 1130 1086 1055 1046 1068 1113 1183 1279 1401 1565 1720 1885 1610 1535 1383 1278 1193 1120 1075 1040 1029 1056 1103 1169 1263 1387 1548 1702 1853 1620 1511 1374 1274 1186 1115 1074 1033 1028 1048 1096 1163 1259 1378 1529 1688 1829 1608 1498 1383 1279 1191 1112 1096 1043 1024 1049 1101 1163 1263 1387 1520 1679 1828 1610 1514 1399 1292 1201 1119 1082 1048 1030 1062 1107 1174 1266 1395 1529 1699 1808 1635 1553 1421 1315 1211 1139 1088 1058 1055 1076 1122 1189 1289 1408 1546 1724 1863 1661 1584 1456 1329 1235 1166 1109 1080 1074 1097 1138 1219 1308 1431 1581 1744 1941 1688 1609 1485 1371 1271 1186 1132 1098 1095 1119 1157 1247 1336 1468 1629 1806 1967 1743 1643 1529 1397 1302 1221 1162 1115 1114 1142 1191 1267 1380 1517 1674 1881 2006 1799 1687 1579 1428 1347 1249 1193 1141 1134 1171 1223 1308 1423 1577 1721 1938 2105 1867 1734 1634 1502 1385 1284 1220 1171 1163 1199 1255 1348 1463 1614 1796 2037 2180]</LSC_SAMPLES_red>
            <LSC_SAMPLES_greenR index="1" type="double" size="[17 17]">[2099 1883 1666 1530 1403 1309 1243 1206 1198 1220 1282 1375 1512 1706 1935 2303 2642 1996 1788 1634 1484 1349 1262 1211 1171 1158 1189 1247 1334 1460 1631 1902 2107 2479 1899 1707 1568 1430 1315 1235 1175 1147 1132 1156 1210 1298 1417 1582 1747 2062 2283 1808 1650 1506 1383 1271 1191 1151 1114 1104 1130 1176 1262 1376 1524 1714 1942 2146 1749 1599 1462 1341 1246 1165 1117 1087 1080 1102 1147 1230 1333 1486 1649 1860 2060 1700 1586 1423 1312 1218 1143 1098 1069 1062 1084 1127 1206 1303 1440 1604 1801 1973 1651 1530 1399 1293 1204 1128 1084 1052 1043 1066 1112 1182 1284 1405 1575 1738 1909 1618 1542 1384 1277 1192 1117 1073 1037 1024 1054 1101 1170 1266 1395 1559 1714 1876 1636 1521 1377 1274 1185 1114 1072 1031 1026 1047 1097 1165 1263 1384 1538 1702 1854 1618 1508 1387 1279 1192 1112 1098 1041 1024 1049 1104 1166 1268 1394 1530 1694 1852 1626 1526 1404 1297 1204 1121 1084 1047 1031 1063 1111 1179 1271 1407 1544 1716 1830 1652 1568 1429 1319 1214 1142 1092 1060 1056 1080 1127 1194 1298 1420 1563 1741 1893 1678 1605 1465 1341 1247 1171 1113 1082 1078 1102 1145 1227 1318 1449 1597 1763 1974 1714 1628 1496 1379 1280 1195 1136 1108 1100 1124 1163 1256 1348 1486 1644 1830 2014 1769 1665 1547 1404 1309 1226 1168 1126 1122 1148 1197 1277 1391 1541 1687 1907 2092 1834 1716 1595 1438 1355 1255 1198 1150 1142 1179 1232 1317 1439 1599 1742 1974 2219 1906 1768 1657 1511 1395 1290 1224 1184 1170 1206 1264 1359 1482 1637 1815 2101 2306]</LSC_SAMPLES_greenR>
            <LSC_SAMPLES_greenB index="1" type="double" size="[17 17]">[2108 1880 1669 1530 1400 1309 1244 1204 1198 1221 1279 1374 1508 1704 1927 2299 2638 2001 1788 1634 1484 1350 1263 1210 1173 1157 1189 1247 1332 1460 1627 1898 2101 2472 1895 1712 1569 1432 1316 1234 1177 1146 1132 1157 1211 1298 1417 1579 1744 2058 2273 1813 1654 1505 1385 1270 1190 1153 1115 1104 1129 1176 1261 1373 1522 1711 1937 2136 1752 1602 1464 1340 1248 1166 1119 1087 1081 1103 1147 1231 1333 1485 1646 1859 2051 1701 1588 1422 1316 1218 1144 1097 1070 1061 1083 1127 1204 1302 1438 1602 1797 1969 1652 1529 1401 1293 1204 1129 1084 1053 1043 1066 1113 1181 1281 1405 1575 1734 1906 1624 1547 1384 1279 1193 1118 1074 1037 1025 1053 1102 1170 1266 1394 1557 1714 1877 1636 1521 1380 1275 1187 1114 1073 1031 1026 1047 1097 1165 1262 1384 1536 1702 1849 1622 1510 1388 1282 1194 1114 1098 1043 1024 1050 1103 1165 1267 1394 1529 1693 1851 1628 1531 1407 1298 1205 1122 1085 1047 1032 1062 1112 1180 1272 1405 1545 1713 1831 1655 1571 1432 1321 1216 1143 1094 1061 1057 1081 1128 1195 1298 1420 1564 1739 1891 1682 1606 1468 1343 1249 1173 1115 1084 1079 1103 1145 1227 1318 1449 1597 1762 1970 1715 1634 1497 1382 1281 1196 1137 1109 1101 1125 1162 1256 1347 1485 1646 1827 2014 1774 1667 1550 1404 1312 1229 1171 1127 1121 1149 1199 1277 1391 1541 1687 1908 2089 1838 1720 1598 1441 1356 1256 1200 1153 1143 1181 1233 1318 1439 1599 1742 1974 2220 1915 1768 1662 1515 1398 1291 1225 1185 1171 1207 1264 1360 1480 1639 1815 2106 2300]</LSC_SAMPLES_greenB>
            <LSC_SAMPLES_blue index="1" type="double" size="[17 17]">[1720 1583 1448 1364 1280 1220 1177 1150 1144 1160 1205 1261 1355 1473 1615 1807 1996 1667 1532 1442 1342 1253 1199 1162 1135 1125 1148 1189 1246 1329 1441 1591 1716 1900 1605 1484 1400 1308 1235 1178 1139 1119 1108 1127 1164 1226 1303 1407 1511 1681 1793 1548 1449 1356 1277 1201 1146 1122 1093 1087 1105 1140 1197 1278 1368 1489 1619 1714 1514 1416 1327 1246 1186 1126 1096 1076 1070 1087 1117 1176 1246 1340 1448 1568 1663 1480 1407 1299 1229 1163 1112 1079 1058 1053 1070 1102 1157 1223 1312 1417 1528 1613 1447 1366 1284 1212 1153 1099 1068 1044 1037 1055 1091 1138 1208 1289 1397 1489 1572 1428 1381 1272 1203 1144 1090 1060 1030 1024 1047 1081 1130 1197 1280 1389 1472 1556 1439 1363 1269 1201 1138 1089 1060 1027 1029 1041 1080 1127 1195 1275 1374 1464 1541 1430 1356 1280 1207 1146 1090 1080 1037 1028 1046 1086 1129 1201 1285 1374 1459 1537 1436 1374 1294 1222 1158 1099 1071 1043 1032 1057 1094 1141 1202 1295 1388 1469 1534 1461 1401 1312 1240 1168 1115 1079 1055 1055 1071 1108 1153 1226 1306 1394 1487 1558 1471 1426 1336 1255 1190 1137 1096 1072 1069 1088 1119 1178 1239 1326 1411 1492 1597 1491 1440 1352 1281 1211 1152 1112 1090 1086 1103 1130 1198 1258 1348 1436 1522 1625 1530 1463 1389 1293 1235 1176 1136 1104 1101 1121 1156 1211 1287 1382 1449 1558 1685 1572 1500 1422 1321 1270 1199 1159 1124 1120 1146 1186 1244 1325 1420 1491 1604 1780 1600 1520 1454 1364 1287 1219 1170 1144 1137 1161 1204 1268 1350 1429 1511 1682 1832]</LSC_SAMPLES_blue>
         </cell>
      </LSC>
      <CC index="1" type="cell" size="[1 6]">
            <name index="1" type="char" size="[1 5]">A_100</name>
            <saturation index="1" type="double" size="[1 1]">[ 100]</saturation>
            <ccMatrix index="1" type="double" size="[3 3]">[1.70554 0.0634162 -0.768386 -0.872631 2.41039 -0.439703 -0.369813 0.491819 1.4153]</ccMatrix>
            <ccOffsets index="1" type="double" size="[1 3]">[-2.32714 -118.193 -1512.336]</ccOffsets>
            <wb index="1" type="double" size="[1 4]">[1.12853 1 1 2.6864]</wb>
         </cell>
            <name index="1" type="char" size="[1 7]">D50_100</name>
            <ccMatrix index="1" type="double" size="[3 3]">[1.63872 -0.100647 -0.395879 -0.508077 2.0874 -0.41751 -0.291141 -1.05548 3.482]</ccMatrix>
            <ccOffsets index="1" type="double" size="[1 3]">[-582.302 -193.36 -1121.9325]</ccOffsets>
            <wb index="1" type="double" size="[1 4]">[1.71912 1 1 1.5623]</wb>
         </cell>
            <name index="1" type="char" size="[1 7]">D65_100</name>
            <ccMatrix index="1" type="double" size="[3 3]">[1.82783 0.03077 -0.743202 -0.449706 1.95856 -0.445475 -0.0445922 -0.361816 1.6574]</ccMatrix>
            <ccOffsets index="1" type="double" size="[1 3]">[-472.566 -127.732 -564.3045]</ccOffsets>
            <wb index="1" type="double" size="[1 4]">[1.83168 1 1 1.6323]</wb>
         </cell>
            <name index="1" type="char" size="[1 7]">D75_100</name>
            <ccMatrix index="1" type="double" size="[3 3]">[1.57609 0.0675493 -0.546618 -0.480967 2.41898 -0.590472 0.0123617 -0.766672 2.9685]</ccMatrix>
            <ccOffsets index="1" type="double" size="[1 3]">[-397.317 -144.073 -696.0122]</ccOffsets>
            <wb index="1" type="double" size="[1 4]">[1.915 1 1 1.5221]</wb>
         </cell>
            <name index="1" type="char" size="[1 7]">F11_100</name>
            <ccMatrix index="1" type="double" size="[3 3]">[1.6608 -0.0812034 -0.514466 -0.732627 2.05142 -0.229307 -0.992776 0.103685 2.4784]</ccMatrix>
            <ccOffsets index="1" type="double" size="[1 3]">[-266.708 -180.449 -1304.605]</ccOffsets>
            <wb index="1" type="double" size="[1 4]">[1.36013 1 1 2.4169]</wb>
         </cell>
            <name index="1" type="char" size="[1 6]">F2_100</name>
            <ccMatrix index="1" type="double" size="[3 3]">[1.99494 -0.314082 -0.603437 -0.688478 1.89 -0.145871 -0.166597 -0.255025 1.7868]</ccMatrix>
            <ccOffsets index="1" type="double" size="[1 3]">[-317.018 -131.518 -1000.3296]</ccOffsets>
            <wb index="1" type="double" size="[1 4]">[1.64295 1 1 2.6265]</wb>
         </cell>
      </CC>
      <AF index="1" type="struct" size="[1 1]">
         <tbd index="1" type="double" size="[1 1]">[ -1]</tbd>
      </AF>
      <AEC index="1" type="struct" size="[1 1]">
         <SetPoint index="1" type="double" size="[1 1]">[ 80]</SetPoint>
         <ClmTolerance index="1" type="double" size="[1 1]">[ 20]</ClmTolerance>
         <DampOver index="1" type="double" size="[1 1]">[ 0.2]</DampOver>
         <DampUnder index="1" type="double" size="[1 1]">[ 0.3]</DampUnder>
         <DampOverVideo index="1" type="double" size="[1 1]">[ 0.7]</DampOverVideo>
         <DampUnderVideo index="1" type="double" size="[1 1]">[ 0.9]</DampUnderVideo>
         <ECM index="1" type="cell" size="[1 3]">
               <name index="1" type="char" size="[1 16]">1920x1080_FPS_15</name>
               <PrioritySchemes index="1" type="cell" size="[1 3]">
                     <name index="1" type="char" size="[1 4]">fast</name>
                     <OffsetT0Fac index="1" type="double" size="[1 1]">[ 1]</OffsetT0Fac>
                     <SlopeA0 index="1" type="double" size="[1 1]">[ 2]</SlopeA0>
                  </cell>
                     <name index="1" type="char" size="[1 6]">normal</name>
                     <SlopeA0 index="1" type="double" size="[1 1]">[ 1]</SlopeA0>
                  </cell>
                     <name index="1" type="char" size="[1 4]">slow</name>
                     <OffsetT0Fac index="1" type="double" size="[1 1]">[ 2]</OffsetT0Fac>
                  </cell>
               </PrioritySchemes>
            </cell>
               <name index="1" type="char" size="[1 16]">1920x1080_FPS_10</name>
                  </cell>
                  </cell>
                  </cell>
               </PrioritySchemes>
            </cell>
               <name index="1" type="char" size="[1 16]">1920x1080_FPS_05</name>
                  </cell>
                     <SlopeA0 index="1" type="double" size="[1 1]">[ 0.9]</SlopeA0>
                  </cell>
                     <OffsetT0Fac index="1" type="double" size="[1 1]">[ 4]</OffsetT0Fac>
                  </cell>
               </PrioritySchemes>
            </cell>
         </ECM>
         <aFpsMaxGain index="1" type="double" size="[1 1]">[ 8]</aFpsMaxGain>
      </AEC>
      <BLS index="1" type="cell" size="[1 1]">
            <blsData index="1" type="double" size="[1 4]">[64 64 64 64]</blsData>
         </cell>
      </BLS>
      <CAC index="1" type="cell" size="[1 1]">
            <x_normshift index="1" type="double" size="[1 1]">[ 6]</x_normshift>
            <x_normfactor index="1" type="double" size="[1 1]">[ 29]</x_normfactor>
            <y_normshift index="1" type="double" size="[1 1]">[ 6]</y_normshift>
            <y_normfactor index="1" type="double" size="[1 1]">[ 29]</y_normfactor>
            <x_offset index="1" type="double" size="[1 1]">[ 0]</x_offset>
            <y_offset index="1" type="double" size="[1 1]">[ 0]</y_offset>
            <red_parameters index="1" type="double" size="[1 3]">[-0.625 -0.4375 1.3125]</red_parameters>
            <blue_parameters index="1" type="double" size="[1 3]">[0.375 -4.25 2.875]</blue_parameters>
         </cell>
      </CAC>
      <DPF index="1" type="cell" size="[1 1]">
            <NLL_SEGMENTATION index="1" type="double" size="[1 1]">[ 1]</NLL_SEGMENTATION>
            <nll_coeff_n index="1" type="double" size="[1 17]">[1023 1023 1023 1023 1023 1023 1023 855 682 519 435 382 317 277 248 227 212]</nll_coeff_n>
            <SigmaGreen index="1" type="double" size="[1 1]">[ 4]</SigmaGreen>
            <SigmaRedBlue index="1" type="double" size="[1 1]">[ 4]</SigmaRedBlue>
            <Gradient index="1" type="double" size="[1 1]">[ 0.15]</Gradient>
            <Offset index="1" type="double" size="[1 1]">[ 0]</Offset>
            <NlGains index="1" type="double" size="[1 4]">[1 1 1 1]</NlGains>
         </cell>
      </DPF>
      <DPCC index="1" type="cell" size="[1 1]">
            <register index="1" type="cell" size="[1 23]">
                  <name index="1" type="char" size="[1 13]">ISP_DPCC_MODE</name>
                  <value index="1" type="char" size="[1 6]">0x0004</value>
               </cell>
                  <name index="1" type="char" size="[1 17]">ISP_DPCC_OUT_MODE</name>
                  <value index="1" type="char" size="[1 6]">0x0003</value>
               </cell>
                  <name index="1" type="char" size="[1 16]">ISP_DPCC_SET_USE</name>
                  <value index="1" type="char" size="[1 6]">0x0007</value>
               </cell>
                  <name index="1" type="char" size="[1 21]">ISP_DPCC_METHODS_SET1</name>
                  <value index="1" type="char" size="[1 6]">0x1D1D</value>
               </cell>
                  <name index="1" type="char" size="[1 21]">ISP_DPCC_METHODS_SET2</name>
                  <value index="1" type="char" size="[1 6]">0x0707</value>
               </cell>
                  <name index="1" type="char" size="[1 21]">ISP_DPCC_METHODS_SET3</name>
                  <value index="1" type="char" size="[1 6]">0x1F1F</value>
               </cell>
               <cell index="7" type="struct" size="[1 1]">
                  <name index="1" type="char" size="[1 22]">ISP_DPCC_LINE_THRESH_1</name>
                  <value index="1" type="char" size="[1 6]">0x0808</value>
               </cell>
               <cell index="8" type="struct" size="[1 1]">
                  <name index="1" type="char" size="[1 23]">ISP_DPCC_LINE_MAD_FAC_1</name>
                  <value index="1" type="char" size="[1 6]">0x0404</value>
               </cell>
               <cell index="9" type="struct" size="[1 1]">
                  <name index="1" type="char" size="[1 17]">ISP_DPCC_PG_FAC_1</name>
                  <value index="1" type="char" size="[1 6]">0x0403</value>
               </cell>
               <cell index="10" type="struct" size="[1 1]">
                  <name index="1" type="char" size="[1 21]">ISP_DPCC_RND_THRESH_1</name>
                  <value index="1" type="char" size="[1 6]">0x0A0A</value>
               </cell>
               <cell index="11" type="struct" size="[1 1]">
                  <name index="1" type="char" size="[1 17]">ISP_DPCC_RG_FAC_1</name>
                  <value index="1" type="char" size="[1 6]">0x2020</value>
               </cell>
               <cell index="12" type="struct" size="[1 1]">
                  <name index="1" type="char" size="[1 22]">ISP_DPCC_LINE_THRESH_2</name>
                  <value index="1" type="char" size="[1 6]">0x100C</value>
               </cell>
               <cell index="13" type="struct" size="[1 1]">
                  <name index="1" type="char" size="[1 23]">ISP_DPCC_LINE_MAD_FAC_2</name>
                  <value index="1" type="char" size="[1 6]">0x1810</value>
               </cell>
               <cell index="14" type="struct" size="[1 1]">
                  <name index="1" type="char" size="[1 17]">ISP_DPCC_PG_FAC_2</name>
               </cell>
               <cell index="15" type="struct" size="[1 1]">
                  <name index="1" type="char" size="[1 21]">ISP_DPCC_RND_THRESH_2</name>
               </cell>
               <cell index="16" type="struct" size="[1 1]">
                  <name index="1" type="char" size="[1 17]">ISP_DPCC_RG_FAC_2</name>
               </cell>
               <cell index="17" type="struct" size="[1 1]">
                  <name index="1" type="char" size="[1 22]">ISP_DPCC_LINE_THRESH_3</name>
               </cell>
               <cell index="18" type="struct" size="[1 1]">
                  <name index="1" type="char" size="[1 23]">ISP_DPCC_LINE_MAD_FAC_3</name>
               </cell>
               <cell index="19" type="struct" size="[1 1]">
                  <name index="1" type="char" size="[1 17]">ISP_DPCC_PG_FAC_3</name>
               </cell>
               <cell index="20" type="struct" size="[1 1]">
                  <name index="1" type="char" size="[1 21]">ISP_DPCC_RND_THRESH_3</name>
                  <value index="1" type="char" size="[1 6]">0x0806</value>
               </cell>
               <cell index="21" type="struct" size="[1 1]">
                  <name index="1" type="char" size="[1 17]">ISP_DPCC_RG_FAC_3</name>
               </cell>
               <cell index="22" type="struct" size="[1 1]">
                  <name index="1" type="char" size="[1 18]">ISP_DPCC_RO_LIMITS</name>
               </cell>
               <cell index="23" type="struct" size="[1 1]">
                  <name index="1" type="char" size="[1 17]">ISP_DPCC_RND_OFFS</name>
                  <value index="1" type="char" size="[1 6]">0x0FFF</value>
               </cell>
            </register>
         </cell>
      </DPCC>
   </sensor>
   <system type="struct" size="[1 1]">
      <AFPS index="1" type="struct" size="[1 1]">
         <aFpsDefault index="1" type="char" size="[1 2]">on</aFpsDefault>
      </AFPS>
   </system>
   <tuning>
      <awb enable="true">
         <damping>true</damping>
         <index>2</index>
         <mode>2</mode>
      </awb>
      <dpf enable="false" adaptive="true">
         <division.factor>64</division.factor>
         <gradient>0.15000001</gradient>
         <minimum.bound>2</minimum.bound>
         <offset>0</offset>
         <sigma.green>1</sigma.green>
         <sigma.red.blue>1</sigma.red.blue>
      </dpf>
   </tuning>
</matfile>
Alan_Jia
Hi @jp4,
For the gain polygon modifier, you need to keep all points representing the color temperatures inside the black polygon and the black polygon inside the orange polygon.
When you use AWB out of the lab, the environment blue/red gain will also create a point and lie inside the polygons. If the environment blue/red gain is inside the black polygon, the ISP will use the AWB parameters of the color temperature which is closest to the point. If the point is outside the black polygon but inside the orange polygon, the point will be clipped to the closet black border. However, if the point is outside the orange polygon, the ISP will regard the current situation as an abnormal situation and the AWB parameters will lock.
Alan
