IMX8MP HDMI 1024x600 resolution
lgalvao
I have a custom imx8mp board which direct HDMI video output and it works fine with 1920x1080 display.
I need to configure a custom HDMI resolution 1024x600@60 with pixel clock 40000000.
Display: https://www.lcdwiki.com/10.1inch_HDMI_Display-H
Thank you for support.
lgalvao
Hello, I found a solution that worked for my case.
I generated a custom EDID using this tool: https://github.com/akatrevorjay/edid-generator.git then I copied it to /lib/firmware/edid
In the kernel config I enabled:
CONFIG_DRM_LOAD_EDID_FIRMWARE=y
CONFIG_DRM_IMX_HDMI=m
And finally, I added these parameters to the cmdline:
drm.edid_firmware=HDMI-A-1:edid/1024x600.bin video=HDMI-A-1:1024x600-16@60
luo44atosu
what's the samsung_phy_pll_cfg setting for 77MHZ pixel clock? Also could you please post the correct register setting in the imx8mp user manual? Is the imx8mp and imx8mm the same on HDMI?
Bio_TICFSL
This isn't a standard resolution can be supported by current bsp, I need to generate timings parameters by tools, so please add these parameters in the table samsung_phy_pll_cfg of drivers/phy/freescale/phy-fsl-samsung-hdmi.c
Depend of your pixel clock, can be workable.
lgalvao
Can you help me to add these parameters in the table samsung_phy_pll_cfg?
My linux-imx version is lf-6.12.y.
Bio_TICFSL
is not an standar resolution, so please check it, for 1080x720, try the patch as below
--- a/drivers/phy/freescale/phy-fsl-samsung-hdmi.c
+++ b/drivers/phy/freescale/phy-fsl-samsung-hdmi.c
@@ -324,6 +324,15 @@ const struct phy_config samsung_phy_pll_cfg[] = {
0x00, 0x80, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0xE0, 0x83, 0x0F, 0x3E, 0xF8, 0x00, 0x00,
+ 65000000, {
+ 0x00, 0xD1, 0x51, 0x58, 0x8D, 0x04, 0x9A, 0x57,
+ 0x4F, 0x30, 0x33, 0x65, 0x10, 0xBE, 0x24, 0x80,
+ 0x6C, 0xF2, 0x67, 0x00, 0x10, 0x85, 0x30, 0x3A,
+ 0x74, 0x8F, 0x00, 0x00, 0x08, 0x00, 0x00, 0x00,
+ 0x00, 0x80, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
+ 0x00, 0xE0, 0x83, 0x0F, 0x3E, 0xF8, 0x00, 0x00,
67500000, {
0x00, 0xD1, 0x54, 0x52, 0x87, 0x03, 0x80, 0x40,
lgalvao
in linux version 6.12 the file has this format:
.pixclk = 63500000,
.pll_div_regs = { 0x69, 0x74, 0x89, 0x08, 0x80, 0x40 },
.pixclk = 67500000,
.pll_div_regs = { 0x54, 0x52, 0x87, 0x03, 0x80, 0x40 },
Can you help me to add patch in this file?
Do I need to add any modifications in the kernel command line?
Bio_TICFSL
Hi.
No this resolution is not standard you will have to do the change.
lgalvao
%3CLINGO-SUB%20id%3D%22lingo-sub-2139566%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EIMX8MP%20HDMI%201024x600%20resolution%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2139566%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHello%2C%3C%2FP%3E%3CP%3EI%20have%20a%20custom%20imx8mp%20board%20which%20direct%20HDMI%20video%20output%20and%20it%20works%20fine%20with%201920x1080%20display.%3CBR%20%2F%3E%3CBR%20%2F%3EI%20need%20to%20configure%20a%20custom%20HDMI%20resolution%201024x600%4060%20with%20pixel%20clock%2040000000.%3C%2FP%3E%3CP%3EDisplay%3A%20%3CA%20href%3D%22https%3A%2F%2Fwww.lcdwiki.com%2F10.1inch_HDMI_Display-H%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttps%3A%2F%2Fwww.lcdwiki.com%2F10.1inch_HDMI_Display-H%3C%2FA%3E%3C%2FP%3E%3CP%3EThank%20you%20for%20support.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2156801%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20IMX8MP%20HDMI%201024x600%20resolution%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2156801%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHello%2C%20I%20found%20a%20solution%20that%20worked%20for%20my%20case.%3C%2FP%3E%3CP%3EI%20generated%20a%20custom%20EDID%20using%20this%20tool%3A%20%3CA%20href%3D%22https%3A%2F%2Fgithub.com%2Fakatrevorjay%2Fedid-generator.git%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttps%3A%2F%2Fgithub.com%2Fakatrevorjay%2Fedid-generator.git%3C%2FA%3E%26nbsp%3Bthen%20I%20copied%20it%20to%26nbsp%3B%2Flib%2Ffirmware%2Fedid%3C%2FP%3E%3CP%3EIn%20the%20kernel%20config%20I%20enabled%3A%3C%2FP%3E%3CP%3ECONFIG_DRM_LOAD_EDID_FIRMWARE%3Dy%3CBR%20%2F%3ECONFIG_DRM_IMX_HDMI%3Dm%3C%2FP%3E%3CP%3EAnd%20finally%2C%20I%20added%20these%20parameters%20to%20the%20cmdline%3A%3C%2FP%3E%3CP%3Edrm.edid_firmware%3DHDMI-A-1%3Aedid%2F1024x600.bin%20video%3DHDMI-A-1%3A1024x600-16%4060%3C%2FP%3E%3CP%3EThank%20you%20for%20support%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2145226%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20IMX8MP%20HDMI%201024x600%20resolution%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2145226%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi.%3C%2FP%3E%0A%3CP%3ENo%20this%20resolution%20is%20not%20standard%20you%20will%20have%20to%20do%20the%20change.%3C%2FP%3E%0A%3CP%3ERegards%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2144615%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20IMX8MP%20HDMI%201024x600%20resolution%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2144615%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CDIV%3EHello%2C%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3Ein%20linux%20version%206.12%20the%20file%20has%20this%20format%3A%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%7D%2C%20%7B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E.pixclk%20%3D%2063500000%2C%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E.pll_div_regs%20%3D%20%7B%200x69%2C%200x74%2C%200x89%2C%200x08%2C%200x80%2C%200x40%20%7D%2C%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%7D%2C%20%7B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E.pixclk%20%3D%2067500000%2C%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E.pll_div_regs%20%3D%20%7B%200x54%2C%200x52%2C%200x87%2C%200x03%2C%200x80%2C%200x40%20%7D%2C%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%7D%2C%20%7B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3ECan%20you%20help%20me%20to%20add%20patch%20in%20this%20file%3F%3CBR%20%2F%3E%3CBR%20%2F%3EDo%20I%20need%20to%20add%20any%20modifications%20in%20the%20kernel%20command%20line%3F%3C%2FDIV%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2140956%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20IMX8MP%20HDMI%201024x600%20resolution%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2140956%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHello%2C%3C%2FP%3E%0A%3CP%3Eis%20not%20an%20standar%20resolution%2C%20so%20please%20check%20it%2C%20for%201080x720%2C%20try%20the%20patch%20as%20below%3C%2FP%3E%0A%3CP%3E---%20a%2Fdrivers%2Fphy%2Ffreescale%2Fphy-fsl-samsung-hdmi.c%3CBR%20%2F%3E%2B%2B%2B%20b%2Fdrivers%2Fphy%2Ffreescale%2Fphy-fsl-samsung-hdmi.c%3CBR%20%2F%3E%40%40%20-324%2C6%20%2B324%2C15%20%40%40%20const%20struct%20phy_config%20samsung_phy_pll_cfg%5B%5D%20%3D%20%7B%3CBR%20%2F%3E0x00%2C%200x80%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%3CBR%20%2F%3E0x00%2C%200xE0%2C%200x83%2C%200x0F%2C%200x3E%2C%200xF8%2C%200x00%2C%200x00%2C%3CBR%20%2F%3E%7D%2C%3CBR%20%2F%3E%2B%20%7D%2C%20%7B%3CBR%20%2F%3E%2B%2065000000%2C%20%7B%3CBR%20%2F%3E%2B%200x00%2C%200xD1%2C%200x51%2C%200x58%2C%200x8D%2C%200x04%2C%200x9A%2C%200x57%2C%3CBR%20%2F%3E%2B%200x4F%2C%200x30%2C%200x33%2C%200x65%2C%200x10%2C%200xBE%2C%200x24%2C%200x80%2C%3CBR%20%2F%3E%2B%200x6C%2C%200xF2%2C%200x67%2C%200x00%2C%200x10%2C%200x85%2C%200x30%2C%200x3A%2C%3CBR%20%2F%3E%2B%200x74%2C%200x8F%2C%200x00%2C%200x00%2C%200x08%2C%200x00%2C%200x00%2C%200x00%2C%3CBR%20%2F%3E%2B%200x00%2C%200x80%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%3CBR%20%2F%3E%2B%200x00%2C%200xE0%2C%200x83%2C%200x0F%2C%200x3E%2C%200xF8%2C%200x00%2C%200x00%2C%3CBR%20%2F%3E%2B%20%7D%2C%3CBR%20%2F%3E%7D%2C%20%7B%3CBR%20%2F%3E67500000%2C%20%7B%3CBR%20%2F%3E0x00%2C%200xD1%2C%200x54%2C%200x52%2C%200x87%2C%200x03%2C%200x80%2C%200x40%2C%3CBR%20%2F%3E--%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3ERegards%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2140247%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20IMX8MP%20HDMI%201024x600%20resolution%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2140247%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3ECan%20you%20help%20me%20to%20add%20these%20parameters%20in%20the%20table%20samsung_phy_pll_cfg%3F%3C%2FP%3E%3CP%3EMy%20linux-imx%20version%20is%20lf-6.12.y.%3C%2FP%3E%3CP%3EThank%20you%20for%20support.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2140237%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20IMX8MP%20HDMI%201024x600%20resolution%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2140237%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHello%2C%3C%2FP%3E%0A%3CP%3EThis%20isn't%20a%20standard%20resolution%20can%20be%20supported%20by%20current%20bsp%2C%20I%20need%20to%20generate%20timings%20parameters%20by%26nbsp%3Btools%2C%20so%20please%26nbsp%3Badd%20these%20parameters%20in%20the%20table%20samsung_phy_pll_cfg%20of%20drivers%2Fphy%2Ffreescale%2Fphy-fsl-samsung-hdmi.c%26nbsp%3B%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Bio_TICFSL_0-1753368299853.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Bio_TICFSL_0-1753368299853.png%22%20style%3D%22width%3A%20194px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Bio_TICFSL_0-1753368299853.png%22%20style%3D%22width%3A%20194px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F349354i5733B851E2BA26B3%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22Bio_TICFSL_0-1753368299853.png%22%20alt%3D%22Bio_TICFSL_0-1753368299853.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Bio_TICFSL_1-1753368299863.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Bio_TICFSL_1-1753368299863.png%22%20style%3D%22width%3A%20226px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Bio_TICFSL_1-1753368299863.png%22%20style%3D%22width%3A%20226px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F349353i31BADB10039D348A%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22Bio_TICFSL_1-1753368299863.png%22%20alt%3D%22Bio_TICFSL_1-1753368299863.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3EDepend%20of%20your%20pixel%20clock%2C%20can%20be%20workable.%3C%2FP%3E%0A%3CP%3ERegards%3C%2FP%3E%0A%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2258262%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20IMX8MP%20HDMI%201024x600%20resolution%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2258262%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3Ewhat's%20the%20samsung_phy_pll_cfg%20setting%20for%2077MHZ%20pixel%20clock%3F%20Also%20could%20you%20please%20post%20the%20correct%20register%20setting%20in%20the%20imx8mp%20user%20manual%3F%20Is%20the%20imx8mp%20and%20imx8mm%20the%20same%20on%20HDMI%3F%3C%2FP%3E%3C%2FLINGO-BODY%3E
