IMX8MP HDMI 1024x600 resolution
3,020 次查看
lgalvao
I have a custom imx8mp board which direct HDMI video output and it works fine with 1920x1080 display.
I need to configure a custom HDMI resolution 1024x600@60 with pixel clock 40000000.
Display: https://www.lcdwiki.com/10.1inch_HDMI_Display-H
Thank you for support.
2,582 次查看
lgalvao
Hello, I found a solution that worked for my case.
I generated a custom EDID using this tool: https://github.com/akatrevorjay/edid-generator.git then I copied it to /lib/firmware/edid
In the kernel config I enabled:
CONFIG_DRM_LOAD_EDID_FIRMWARE=y
CONFIG_DRM_IMX_HDMI=m
And finally, I added these parameters to the cmdline:
drm.edid_firmware=HDMI-A-1:edid/1024x600.bin video=HDMI-A-1:1024x600-16@60
标记 (1)
7 回复数
1,909 次查看
luo44atosu
what's the samsung_phy_pll_cfg setting for 77MHZ pixel clock? Also could you please post the correct register setting in the imx8mp user manual? Is the imx8mp and imx8mm the same on HDMI?
2,986 次查看
Bio_TICFSL
This isn't a standard resolution can be supported by current bsp, I need to generate timings parameters by tools, so please add these parameters in the table samsung_phy_pll_cfg of drivers/phy/freescale/phy-fsl-samsung-hdmi.c
Depend of your pixel clock, can be workable.
2,980 次查看
lgalvao
Can you help me to add these parameters in the table samsung_phy_pll_cfg?
My linux-imx version is lf-6.12.y.
标记 (1)
2,920 次查看
Bio_TICFSL
is not an standar resolution, so please check it, for 1080x720, try the patch as below
--- a/drivers/phy/freescale/phy-fsl-samsung-hdmi.c
+++ b/drivers/phy/freescale/phy-fsl-samsung-hdmi.c
@@ -324,6 +324,15 @@ const struct phy_config samsung_phy_pll_cfg[] = {
0x00, 0x80, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0xE0, 0x83, 0x0F, 0x3E, 0xF8, 0x00, 0x00,
+ 65000000, {
+ 0x00, 0xD1, 0x51, 0x58, 0x8D, 0x04, 0x9A, 0x57,
+ 0x4F, 0x30, 0x33, 0x65, 0x10, 0xBE, 0x24, 0x80,
+ 0x6C, 0xF2, 0x67, 0x00, 0x10, 0x85, 0x30, 0x3A,
+ 0x74, 0x8F, 0x00, 0x00, 0x08, 0x00, 0x00, 0x00,
+ 0x00, 0x80, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
+ 0x00, 0xE0, 0x83, 0x0F, 0x3E, 0xF8, 0x00, 0x00,
67500000, {
0x00, 0xD1, 0x54, 0x52, 0x87, 0x03, 0x80, 0x40,
2,803 次查看
lgalvao
in linux version 6.12 the file has this format:
.pixclk = 63500000,
.pll_div_regs = { 0x69, 0x74, 0x89, 0x08, 0x80, 0x40 },
.pixclk = 67500000,
.pll_div_regs = { 0x54, 0x52, 0x87, 0x03, 0x80, 0x40 },
Can you help me to add patch in this file?
Do I need to add any modifications in the kernel command line?
2,791 次查看
Bio_TICFSL
Hi.
No this resolution is not standard you will have to do the change.
2,583 次查看
lgalvao
标记 (1)
%3CLINGO-SUB%20id%3D%22lingo-sub-2139566%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EIMX8MP%20HDMI%201024x600%20%E5%88%86%E8%BE%A8%E7%8E%87%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2139566%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%3C%2FP%3E%3CP%3E%E6%88%91%E6%9C%89%E4%B8%80%E5%9D%97%E8%87%AA%E5%AE%9A%E4%B9%89%20imx8mp%20%E6%9D%BF%E5%8F%AF%E4%BB%A5%E7%9B%B4%E6%8E%A5%20HDMI%20%E8%A7%86%E9%A2%91%E8%BE%93%E5%87%BA%EF%BC%8C%E5%AE%83%E5%9C%A8%201920x1080%20%E7%9A%84%E6%98%BE%E7%A4%BA%E5%99%A8%E4%B8%8A%E8%BF%90%E8%A1%8C%E8%89%AF%E5%A5%BD%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3E%E6%88%91%E9%9C%80%E8%A6%81%E9%85%8D%E7%BD%AE%E8%87%AA%E5%AE%9A%E4%B9%89%20HDMI%20%E5%88%86%E8%BE%A8%E7%8E%87%201024x600%4060%EF%BC%8C%E5%83%8F%E7%B4%A0%E6%97%B6%E9%92%9F%2040000000%E3%80%82%3C%2FP%3E%3CP%3E%E6%98%BE%E7%A4%BA%E5%B1%8F%3CA%20href%3D%22https%3A%2F%2Fwww.lcdwiki.com%2F10.1inch_HDMI_Display-H%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3E%EF%BC%9A%20https%3A%2F%2Fwww.lcdwiki.com%2F10.1inch_HDMI_Display-H%3C%2FA%3E%3C%2FP%3E%3CP%3E%E6%84%9F%E8%B0%A2%E6%82%A8%E7%9A%84%E6%94%AF%E6%8C%81%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2156801%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20IMX8MP%20HDMI%201024x600%20resolution%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2156801%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%EF%BC%8C%E6%88%91%E6%89%BE%E5%88%B0%E4%BA%86%E4%B8%80%E4%B8%AA%E9%80%82%E5%90%88%E6%88%91%E7%9A%84%E8%A7%A3%E5%86%B3%E6%96%B9%E6%A1%88%E3%80%82%3C%2FP%3E%3CP%3E%E6%88%91%E4%BD%BF%E7%94%A8%E4%BB%A5%E4%B8%8B%E5%B7%A5%E5%85%B7%E7%94%9F%E6%88%90%E4%BA%86%E8%87%AA%E5%AE%9A%E4%B9%89%20EDID%3CA%20href%3D%22https%3A%2F%2Fgithub.com%2Fakatrevorjay%2Fedid-generator.git%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3E%EF%BC%9Ahttps%3A%2F%2Fgithub.com%2Fakatrevorjay%2Fedid-generator.git%3C%2FA%3E%EF%BC%8C%E7%84%B6%E5%90%8E%E5%B0%86%E5%85%B6%E5%A4%8D%E5%88%B6%E5%88%B0%20%2Flib%2Ffirmware%2Fedid%20%E4%B8%AD%E3%80%82%3C%2FP%3E%3CP%3E%E5%9C%A8%E5%86%85%E6%A0%B8%E9%85%8D%E7%BD%AE%E4%B8%AD%EF%BC%8C%E6%88%91%E5%90%AF%E7%94%A8%E4%BA%86%3C%2FP%3E%3CP%3ECONFIG_DRM_LOAD_EDID_FIRMWARE%3Dy%3CBR%20%2F%3ECONFIG_DRM_IMX_HDMI%3Dm%3C%2FP%3E%3CP%3E%E6%9C%80%E5%90%8E%EF%BC%8C%E6%88%91%E5%9C%A8%20cmdline%20%E4%B8%AD%E6%B7%BB%E5%8A%A0%E4%BA%86%E8%BF%99%E4%BA%9B%E5%8F%82%E6%95%B0%EF%BC%9A%3C%2FP%3E%3CP%3Edrm.edid_firmware%3DHDMI-A-1%3Aedid%2F1024x600.bin%20video%3DHDMI-A-1%3A1024x600-16%4060%3C%2FP%3E%3CP%3E%E6%84%9F%E8%B0%A2%E6%82%A8%E7%9A%84%E6%94%AF%E6%8C%81%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2145226%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20IMX8MP%20HDMI%201024x600%20resolution%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2145226%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%E3%80%82%3C%2FP%3E%0A%3CP%3E%E4%B8%8D%EF%BC%8C%E8%AF%A5%E5%86%B3%E8%AE%AE%E4%B8%8D%E6%98%AF%E6%A0%87%E5%87%86%E5%86%B3%E8%AE%AE%EF%BC%8C%E6%82%A8%E5%BF%85%E9%A1%BB%E8%BF%9B%E8%A1%8C%E6%9B%B4%E6%94%B9%E3%80%82%3C%2FP%3E%0A%3CP%3E%E6%AD%A4%E8%87%B4%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2144615%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20IMX8MP%20HDMI%201024x600%20resolution%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2144615%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CDIV%3E%E4%BD%A0%E5%A5%BD%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%E5%9C%A8%20linux%206.12%20%E7%89%88%E6%9C%AC%E4%B8%AD%EF%BC%8C%E6%96%87%E4%BB%B6%E6%A0%BC%E5%BC%8F%E6%98%AF%E8%BF%99%E6%A0%B7%E7%9A%84%EF%BC%9A%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%7D%2C%20%7B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E.pixclk%20%3D%2063500000%E3%80%81%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E.pll_div_regs%20%3D%20%7B%200x69%2C%200x74%2C%200x89%2C%200x08%2C%200x80%2C%200x40%20%7D%E3%80%81%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%7D%2C%20%7B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E.pixclk%20%3D%2067500000%E3%80%81%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E.pll_div_regs%20%3D%20%7B%200x54%2C%200x52%2C%200x87%2C%200x03%2C%200x80%2C%200x40%20%7D%E3%80%81%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%7D%2C%20%7B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%E6%82%A8%E8%83%BD%E5%B8%AE%E6%88%91%E5%9C%A8%E8%AF%A5%E6%96%87%E4%BB%B6%E4%B8%AD%E6%B7%BB%E5%8A%A0%E8%A1%A5%E4%B8%81%E5%90%97%EF%BC%9F%3CBR%20%2F%3E%3CBR%20%2F%3E%E6%88%91%E9%9C%80%E8%A6%81%E5%9C%A8%E5%86%85%E6%A0%B8%E5%91%BD%E4%BB%A4%E8%A1%8C%E4%B8%AD%E6%B7%BB%E5%8A%A0%E4%BB%BB%E4%BD%95%E4%BF%AE%E6%94%B9%E5%90%97%EF%BC%9F%3C%2FDIV%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2140956%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20IMX8MP%20HDMI%201024x600%20resolution%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2140956%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%3C%2FP%3E%0A%3CP%3E1080x720%20%E5%88%86%E8%BE%A8%E7%8E%87%E4%B8%8D%E6%98%AF%E6%A0%87%E5%87%86%E5%88%86%E8%BE%A8%E7%8E%87%EF%BC%8C%E8%AF%B7%E6%A3%80%E6%9F%A5%E4%B8%80%E4%B8%8B%E3%80%82%3C%2FP%3E%0A%3CP%3E---%20a%2Fdrivers%2Fphy%2Ffreescale%2Fphy-fsl-samsung-hdmi.c%3CBR%20%2F%3E%2B%2B%2B%20b%2Fdrivers%2Fphy%2Ffreescale%2Fphy-fsl-samsung-hdmi.c%3CBR%20%2F%3E%40%20-324%2C6%20%2B324%2C15%20%40%40%20const%20struct%20phy_config%20samsung_phy_pll_cfg%5B%5D%20%3D%20%7B%3CBR%20%2F%3E0x00%2C%200x80%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%3CBR%20%2F%3E0x00%2C%200xE0%2C%200x83%E3%80%810x0F%2C%200x3E%2C%200xF8%2C%200x00%2C%200x00%2C%3CBR%20%2F%3E%7D%2C%3CBR%20%2F%3E%2B%20%7D%2C%20%7B%3CBR%20%2F%3E%2B%2065000000%2C%20%7B%3CBR%20%2F%3E%2B%200x00%2C%200xD1%2C%200x51%2C%200x58%2C%200x8D%2C%200x04%2C%200x9A%2C%200x57%2C%3CBR%20%2F%3E%2B%200x4F%2C%200x30%2C%200x33%2C%200x65%2C%200x10%2C%200xBE%E3%80%810x24%2C%200x80%2C%3CBR%20%2F%3E%2B%200x6C%2C%200xF2%2C%200x67%2C%200x00%2C%200x10%2C%200x85%2C%200x30%2C%200x3A%2C%3CBR%20%2F%3E%2B%200x74%2C%200x8F%2C%200x00%2C%200x00%2C%200x08%2C%200x00%2C%200x00%2C%200x00%2C%3CBR%20%2F%3E%2B%200x00%2C%200x80%2C%200x00%2C%200x00%2C%200x00%2C%200x00%E3%80%810x00%2C%200x00%2C%200x00%2C%3CBR%20%2F%3E%2B%200x00%2C%200xE0%2C%200x83%2C%200x0F%2C%200x3E%2C%200xF8%2C%200x00%2C%200x00%2C%3CBR%20%2F%3E%2B%20%7D%2C%3CBR%20%2F%3E%7D%2C%20%7B%3CBR%20%2F%3E67500000%2C%20%7B%3CBR%20%2F%3E0x00%2C%200xD1%2C%200x54%2C%200x52%2C%200x87%2C%200x03%2C%200x80%2C%200x40%2C%3CBR%20%2F%3E--%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E6%AD%A4%E8%87%B4%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2140247%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20IMX8MP%20HDMI%201024x600%20resolution%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2140247%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E6%82%A8%E8%83%BD%E5%B8%AE%E6%88%91%E5%9C%A8%20samsung_phy_pll_cfg%20%E8%A1%A8%E4%B8%AD%E6%B7%BB%E5%8A%A0%E8%BF%99%E4%BA%9B%E5%8F%82%E6%95%B0%E5%90%97%EF%BC%9F%3C%2FP%3E%3CP%3E%E6%88%91%E7%9A%84%20linux-imx%20%E7%89%88%E6%9C%AC%E6%98%AF%20lf-6.12.y%E3%80%82%3C%2FP%3E%3CP%3E%E6%84%9F%E8%B0%A2%E6%82%A8%E7%9A%84%E6%94%AF%E6%8C%81%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2140237%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20IMX8MP%20HDMI%201024x600%20resolution%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2140237%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%3C%2FP%3E%0A%3CP%3E%E8%BF%99%E4%B8%8D%E6%98%AF%E5%BD%93%E5%89%8D%E7%94%B5%E8%B7%AF%E6%9D%BF%E6%94%AF%E6%8C%81%E5%8C%85%E5%8F%AF%E4%BB%A5%E6%94%AF%E6%8C%81%E7%9A%84%E6%A0%87%E5%87%86%E5%88%86%E8%BE%A8%E7%8E%87%EF%BC%8C%E6%88%91%E9%9C%80%E8%A6%81%E9%80%9A%E8%BF%87%E5%B7%A5%E5%85%B7%E7%94%9F%E6%88%90%E8%AE%A1%E6%97%B6%E5%8F%82%E6%95%B0%EF%BC%8C%E6%89%80%E4%BB%A5%E8%AF%B7%E5%B0%86%E8%BF%99%E4%BA%9B%E5%8F%82%E6%95%B0%E6%B7%BB%E5%8A%A0%E5%88%B0%20drivers%2Fphy%2Ffreescale%2Fphy%2Ffreescale%2Fphy-fsl-samsung-hdmi.c%20%E7%9A%84%E8%A1%A8%E4%B8%AD%20samsung_pll_cfg%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Bio_TICFSL_0-1753368299853.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Bio_TICFSL_0-1753368299853.png%22%20style%3D%22width%3A%20194px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Bio_TICFSL_0-1753368299853.png%22%20style%3D%22width%3A%20194px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F349354i5733B851E2BA26B3%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22Bio_TICFSL_0-1753368299853.png%22%20alt%3D%22Bio_TICFSL_0-1753368299853.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Bio_TICFSL_1-1753368299863.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Bio_TICFSL_1-1753368299863.png%22%20style%3D%22width%3A%20226px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Bio_TICFSL_1-1753368299863.png%22%20style%3D%22width%3A%20226px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F349353i31BADB10039D348A%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22Bio_TICFSL_1-1753368299863.png%22%20alt%3D%22Bio_TICFSL_1-1753368299863.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E8%BF%99%E5%8F%96%E5%86%B3%E4%BA%8E%E6%82%A8%E7%9A%84%E5%83%8F%E7%B4%A0%E6%97%B6%E9%92%9F%EF%BC%8C%E4%BD%86%E4%B9%9F%E6%98%AF%E5%8F%AF%E8%A1%8C%E7%9A%84%E3%80%82%3C%2FP%3E%0A%3CP%3E%E6%AD%A4%E8%87%B4%3C%2FP%3E%0A%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2258262%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20IMX8MP%20HDMI%201024x600%20resolution%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2258262%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E77MHZ%20%E5%83%8F%E7%B4%A0%E6%97%B6%E9%92%9F%E7%9A%84%20samsung_phy_pll_cfg%20%E8%AE%BE%E7%BD%AE%E6%98%AF%E4%BB%80%E4%B9%88%EF%BC%9F%E5%8F%A6%E5%A4%96%EF%BC%8C%E8%83%BD%E5%90%A6%E8%AF%B7%E6%82%A8%E5%9C%A8%20imx8mp%20%E7%94%A8%E6%88%B7%E6%89%8B%E5%86%8C%E4%B8%AD%E6%8F%90%E4%BE%9B%E6%AD%A3%E7%A1%AE%E7%9A%84%E5%AF%84%E5%AD%98%E5%99%A8%E8%AE%BE%E7%BD%AE%EF%BC%9Fimx8mp%20%E5%92%8C%20imx8mm%20%E5%9C%A8%20HDMI%20%E4%B8%8A%E6%98%AF%E5%90%A6%E4%B8%80%E6%A0%B7%EF%BC%9F%3C%2FP%3E%3C%2FLINGO-BODY%3E
