IMX8MP-EVK Screen Timeout issue
1,631 次查看
Shanga
Hi NXP,
Android 13 (imx-android-13.0.0_1.2.0) with IMX8MP , we are setting time 5 seconds for Screen timeout  in setting
expected behaviour after 5 second of screen inactivity Display should time out
but Screen is not turned off after the duration
Please share your input how to achieve screen time out.
IMX8MPLUS
标记 (2)
1,607 次查看
Bio_TICFSL
To adjust the screen timeout please use the given below command.
adb shell settings put system screen_off_timeout <time_in_ms>
After setting the value please check via the below-given command.
adb shell settings get system screen_off_timeout
1,583 次查看
Shanga
Hi ,
We tried to set it as directed,we notice only a slight dim of the display brightness.Rather than getting it done through adb shell ,Is it possible to perform this successfully from the UI.
