HI @kartheek!
Thank you for contacting NXP Support!
Your device tree looks good, but I need to check the entire device tree.
Can you share the entire device tree file?
What board and BSP are you using?
What commands are you using to transmit data?
Can you share the wave forms of the SPI bus?
In our EVk boards we use the pad UART2_TXD for debug console, what pads are you using for your console?
Best Regards!
Chavira
