[IMX8MP] Correct process of generating SDK
1,740件の閲覧回数
dteng
From i.MX Linux® User's Guide I learned that to generate a cross compile SDK, I need to do
  • DISTRO=fsl-imx-wayland MACHINE=imx8mp-lpddr4-evk source imx-setup-release.sh -b ./build
  • bitbake imx-image-multimedia
  • bitbake imx-image-multimedia -c populate_sdk
My question is, what does the commands
  • bitbake meta-toolchain
  • bitbake meta-ide-support
do. Do I need to run this command before the populate_sdk command, for the SDK to be generated correctly?
1,724件の閲覧回数
joanxie
you can refer to the chapter Chapter 2 Porting Kernel of  porting guide, the toolchain is  environment-setup-aarch64-poky-linux, pls see the attachment
if you bitbake meta-toolchain, you can refer to the training
"https://community.nxp.com/t5/i-MX-Processors-Knowledge-Base/Task-8-Build-kernel-manually-using-creat..."
