IMX8MP CSI port 2 configuration
1,895件の閲覧回数
Vilius
Greetings,
I was wondering what is the correct way to setup the IMX8MP CSI port 2 as a single camera interface with 4 lanes?
I have tried similar stuff to this as we are running a compulab bsp.
https://github.com/compulab-yokneam/linux-compulab/blob/bca57e9940b5454a8c77a3a1bf50bc2a23c6c68e/arc...
But seems like something is not getting wired correctly and the subdev device in v4l2 is not getting brought up.
When running on CSI1, I get the expected result of (and the expected media graph):
root@ucm-imx8m-plus:~# v4l2-ctl --list-devices
        /dev/v4l-subdev0
        /dev/v4l-subdev1
        /dev/v4l-subdev2
 (csi0):
        /dev/v4l-subdev3
FSL Capture Media Device (platform:32c00000.bus:camera):
        /dev/media1
VIV (platform:viv0):
        /dev/video2
vsi_v4l2dec (platform:vsi_v4l2dec):
        /dev/video1
vsi_v4l2enc (platform:vsi_v4l2enc):
        /dev/video0
viv_media (platform:vvcam-video.0):
        /dev/media0
and dmesg output of:
[ 8.715165] mx8-img-md: Registered sensor subdevice: imx67x 4-001a (1) [ 8.720058] enter isp_mi_stop [ 8.722050] mx8-img-md: created link [imx67x 4-001a] => [mxc-mipi-csi2.0] [ 8.731969] mxc-md 32c00000.bus:camera: mxc_md_create_links
But when using a DTB for CSI port 2, then I dont get the subdevices linked/registered.
So my question is what is important to get the subdevice up and running? And how are they getting linked? Does the CSI port 2 require ISP2? Does the registers change or what?
タグ(4)
1,751件の閲覧回数
Vilius
This DTB works, ensure you load the kernel modules in the correct order.
3 返答(返信)
1,845件の閲覧回数
Manuel_Salas
Hello @Vilius
I hope you are doing very well.
Please take a look to the imx8mp-frdm-ap1302-dual.dts.
Salas.
1,828件の閲覧回数
Vilius
Well, like I mentioned, I have looked into other dtbs with csi port 2, but even checking the one you linked, I still have yet to get the media graph setup correctly.
DTB snippet of what I'm currently trying to use
&i2c5 {
       pinctrl-0 = <&pinctrl_i2c5>;
       scl-gpios = <&gpio3 26>;
       sda-gpios = <&gpio3 27>;
       status = "okay";
       /delete-node/ ov5640_mipi@3c;
       imx_camera: camera_mipi@1a {
               compatible = "framos,imx67x";
               reg = <0x1a>;
               pinctrl-names = "default";
               pinctrl-0 = <&pinctrl_csi_mclk>;
               clocks = <&clk IMX8MP_CLK_IPP_DO_CLKO2>;
               clock-names = "csi_mclk";
               csi_id = <1>;
               en-gpios = <&gpio1 0 GPIO_ACTIVE_LOW>;
               rst-gpios = <&gpio1 1 GPIO_ACTIVE_LOW>;
               mipi_csi;
               status = "okay";
               port {
                       camera_mipi_1_ep: endpoint {
                               remote-endpoint = <&mipi_csi1_ep>;
                               data-lanes = <1 2 3 4>;
                               clock-lanes = <0>;
                               max-pixel-frequency = /bits/ 64 <266000000>;
&mipi_csi_0 {
       status = "disabled";
&mipi_csi_1 {
       #address-cells = <1>;
       #size-cells = <0>;
       status = "okay";
       port@1 {
               reg = <1>;
               mipi_csi1_ep: endpoint {
                       remote-endpoint = <&camera_mipi_1_ep>;
                       data-lanes = <4>;
                       csis-hs-settle = <13>;
                       csis-clk-settle = <2>;
                       csis-wclk;
&isi_0 {
&isi_1 {
&isp_0 {
       status = "okay";
1,752件の閲覧回数
Vilius
%3CLINGO-SUB%20id%3D%22lingo-sub-2222628%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EIMX8MP%20CSI%E3%83%9D%E3%83%BC%E3%83%882%E3%81%AE%E6%A7%8B%E6%88%90%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2222628%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%94%E6%8C%A8%E6%8B%B6%3C%2FP%3E%3CP%3EIMX8MP%20CSI%20%E3%83%9D%E3%83%BC%E3%83%88%202%20%E3%82%92%204%20%E3%83%AC%E3%83%BC%E3%83%B3%E3%81%AE%E5%8D%98%E4%B8%80%E3%82%AB%E3%83%A1%E3%83%A9%20%E3%82%A4%E3%83%B3%E3%82%BF%E3%83%BC%E3%83%95%E3%82%A7%E3%83%BC%E3%82%B9%E3%81%A8%E3%81%97%E3%81%A6%E8%A8%AD%E5%AE%9A%E3%81%99%E3%82%8B%E6%AD%A3%E3%81%97%E3%81%84%E6%96%B9%E6%B3%95%E3%81%AF%E4%BD%95%E3%81%A7%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3CP%3E%E7%A7%81%E3%81%9F%E3%81%A1%E3%81%AF%20Compulab%20BSP%20%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E3%81%AE%E3%81%A7%E3%80%81%E3%81%93%E3%82%8C%E3%81%AB%E4%BC%BC%E3%81%9F%E3%82%82%E3%81%AE%E3%82%92%E8%A9%A6%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3CBR%20%2F%3E%20%3CA%20href%3D%22https%3A%2F%2Fgithub.com%2Fcompulab-yokneam%2Flinux-compulab%2Fblob%2Fbca57e9940b5454a8c77a3a1bf50bc2a23c6c68e%2Farch%2Farm64%2Fboot%2Fdts%2Fcompulab%2Fsom-imx8m-plus_mipi-csi2.dtsi%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttps%3A%2F%2Fgithub.com%2Fcompulab-yokneam%2Flinux-compulab%2Fblob%2Fbca57e9940b5454a8c77a3a1bf50bc2a23c6c68e%2Farch%2Farm64%2Fboot%2Fdts%2Fcompulab%2Fsom-imx8m-plus_mipi-csi2.dtsi%3C%2FA%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%E3%81%97%E3%81%8B%E3%81%97%E3%80%81%E4%BD%95%E3%81%8B%E3%81%8C%E6%AD%A3%E3%81%97%E3%81%8F%E9%85%8D%E7%B7%9A%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%AA%E3%81%84%E3%82%88%E3%81%86%E3%81%A7%E3%80%81v4l2%20%E3%81%AE%E3%82%B5%E3%83%96%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%81%8C%E8%B5%B7%E5%8B%95%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FP%3E%3CP%3ECSI1%20%E3%81%A7%E5%AE%9F%E8%A1%8C%E3%81%99%E3%82%8B%E3%81%A8%E3%80%81%E6%9C%9F%E5%BE%85%E3%81%A9%E3%81%8A%E3%82%8A%E3%81%AE%E7%B5%90%E6%9E%9C%20(%E3%81%8A%E3%82%88%E3%81%B3%E6%9C%9F%E5%BE%85%E3%81%A9%E3%81%8A%E3%82%8A%E3%81%AE%E3%83%97%E3%83%AC%E3%82%B9%E3%83%AA%E3%83%AA%E3%83%BC%E3%82%B9%E3%80%81%E8%A3%BD%E5%93%81%E3%83%8B%E3%83%A5%E3%83%BC%E3%82%B9%20%E3%82%B0%E3%83%A9%E3%83%95)%20%E3%81%8C%E5%BE%97%E3%82%89%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CPRE%20class%3D%22lia-code-sample%20language-markup%22%3E%3CCODE%20translate%3D%22no%22%3Eroot%40ucm-imx8m-plus%3A~%23%20v4l2-ctl%20--list-devices%0A%20()%3A%0A%20%20%20%20%20%20%20%20%2Fdev%2Fv4l-subdev0%0A%20%20%20%20%20%20%20%20%2Fdev%2Fv4l-subdev1%0A%20%20%20%20%20%20%20%20%2Fdev%2Fv4l-subdev2%0A%20(csi0)%3A%0A%20%20%20%20%20%20%20%20%2Fdev%2Fv4l-subdev3%0AFSL%20Capture%20Media%20Device%20(platform%3A32c00000.bus%3Acamera)%3A%0A%20%20%20%20%20%20%20%20%2Fdev%2Fmedia1%0AVIV%20(platform%3Aviv0)%3A%0A%20%20%20%20%20%20%20%20%2Fdev%2Fvideo2%0Avsi_v4l2dec%20(platform%3Avsi_v4l2dec)%3A%0A%20%20%20%20%20%20%20%20%2Fdev%2Fvideo1%0Avsi_v4l2enc%20(platform%3Avsi_v4l2enc)%3A%0A%20%20%20%20%20%20%20%20%2Fdev%2Fvideo0%0Aviv_media%20(platform%3Avvcam-video.0)%3A%0A%20%20%20%20%20%20%20%20%2Fdev%2Fmedia0%3C%2FCODE%3E%3C%2FPRE%3E%3CP%3Edmesg%20%E3%81%AE%E5%87%BA%E5%8A%9B%E3%81%AF%E6%AC%A1%E3%81%AE%E3%82%88%E3%81%86%E3%81%AB%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%99%3A%3C%2FP%3E%3CPRE%20class%3D%22lia-code-sample%20language-markup%22%3E%3CCODE%20translate%3D%22no%22%3E%5B%208.715165%5D%20mx8-img-md%3A%20Registered%20sensor%20subdevice%3A%20imx67x%204-001a%20(1)%20%5B%208.720058%5D%20enter%20isp_mi_stop%20%5B%208.722050%5D%20mx8-img-md%3A%20created%20link%20%5Bimx67x%204-001a%5D%20%3D%26gt%3B%20%5Bmxc-mipi-csi2.0%5D%20%5B%208.731969%5D%20mxc-md%2032c00000.bus%3Acamera%3A%20mxc_md_create_links%3C%2FCODE%3E%3C%2FPRE%3E%3CP%3E%E3%81%97%E3%81%8B%E3%81%97%E3%80%81CSI%20%E3%83%9D%E3%83%BC%E3%83%88%202%20%E3%81%AB%20DTB%20%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%E3%81%A8%E3%80%81%E3%82%B5%E3%83%96%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%81%8C%E3%83%AA%E3%83%B3%E3%82%AF%2F%E7%99%BB%E9%8C%B2%E3%81%95%E3%82%8C%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FP%3E%3CP%3ESO%E7%A7%81%E3%81%AE%E8%B3%AA%E5%95%8F%E3%81%AF%E3%80%81%E3%82%B5%E3%83%96%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%82%92%E8%B5%B7%E5%8B%95%E3%81%97%E3%81%A6%E5%AE%9F%E8%A1%8C%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AB%E4%BD%95%E3%81%8C%E9%87%8D%E8%A6%81%E3%81%AA%E3%81%AE%E3%81%8B%E3%81%A8%E3%81%84%E3%81%86%E3%81%93%E3%81%A8%E3%81%A7%E3%81%99%E3%80%82%E3%81%9D%E3%81%97%E3%81%A6%E3%81%9D%E3%82%8C%E3%82%89%E3%81%AF%E3%81%A9%E3%81%AE%E3%82%88%E3%81%86%E3%81%AB%E3%83%AA%E3%83%B3%E3%82%AF%E3%81%95%E3%82%8C%E3%82%8B%E3%81%AE%E3%81%A7%E3%81%97%E3%82%87%E3%81%86%E3%81%8B%3FCSI%20%E3%83%9D%E3%83%BC%E3%83%88%202%20%E3%81%AB%E3%81%AF%20ISP2%20%E3%81%8C%E5%BF%85%E8%A6%81%E3%81%A7%E3%81%99%E3%81%8B%3F%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF%E3%83%BC%E3%81%AF%E5%A4%89%E6%9B%B4%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2232768%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20IMX8MP%20CSI%20port%202%20configuration%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2232768%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%BE%E3%81%82%E3%80%81%E5%89%8D%E8%BF%B0%E3%81%97%E3%81%9F%E3%82%88%E3%81%86%E3%81%AB%E3%80%81%E7%A7%81%E3%81%AF%20CSI%20%E3%83%9D%E3%83%BC%E3%83%88%202%20%E3%82%92%E5%82%99%E3%81%88%E3%81%9F%E4%BB%96%E3%81%AE%20dtb%20%E3%82%92%E8%AA%BF%E3%81%B9%E3%81%BE%E3%81%97%E3%81%9F%E3%81%8C%E3%80%81%E3%83%AA%E3%83%B3%E3%82%AF%E3%81%97%E3%81%9F%E3%82%82%E3%81%AE%E3%82%92%E3%83%81%E3%82%A7%E3%83%83%E3%82%AF%E3%81%97%E3%81%A6%E3%82%82%E3%80%81%E3%83%97%E3%83%AC%E3%82%B9%E3%83%AA%E3%83%AA%E3%83%BC%E3%82%B9%E3%80%81%E8%A3%BD%E5%93%81%E3%83%8B%E3%83%A5%E3%83%BC%E3%82%B9%20%E3%82%B0%E3%83%A9%E3%83%95%E3%82%92%E6%AD%A3%E3%81%97%E3%81%8F%E8%A8%AD%E5%AE%9A%E3%81%A7%E3%81%8D%E3%81%A6%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FP%3E%3CP%3E%E7%8F%BE%E5%9C%A8%E4%BD%BF%E7%94%A8%E3%81%97%E3%82%88%E3%81%86%E3%81%A8%E3%81%97%E3%81%A6%E3%81%84%E3%82%8BDTB%E3%82%B9%E3%83%8B%E3%83%9A%E3%83%83%E3%83%88%3C%2FP%3E%3CPRE%20class%3D%22lia-code-sample%20language-markup%22%3E%3CCODE%20translate%3D%22no%22%3E%26amp%3Bi2c5%20%7B%0A%20%20%20%20%20%20%20pinctrl-0%20%3D%20%26lt%3B%26amp%3Bpinctrl_i2c5%26gt%3B%3B%0A%20%20%20%20%20%20%20scl-gpios%20%3D%20%26lt%3B%26amp%3Bgpio3%2026%26gt%3B%3B%0A%20%20%20%20%20%20%20sda-gpios%20%3D%20%26lt%3B%26amp%3Bgpio3%2027%26gt%3B%3B%0A%20%20%20%20%20%20%20status%20%3D%20%22okay%22%3B%0A%20%20%20%0A%20%20%20%20%20%20%20%2Fdelete-node%2F%20ov5640_mipi%403c%3B%0A%20%20%20%20%20%20%20imx_camera%3A%20camera_mipi%401a%20%7B%0A%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20compatible%20%3D%20%22framos%2Cimx67x%22%3B%0A%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20reg%20%3D%20%26lt%3B0x1a%26gt%3B%3B%0A%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20pinctrl-names%20%3D%20%22default%22%3B%0A%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20pinctrl-0%20%3D%20%26lt%3B%26amp%3Bpinctrl_csi_mclk%26gt%3B%3B%0A%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20clocks%20%3D%20%26lt%3B%26amp%3Bclk%20IMX8MP_CLK_IPP_DO_CLKO2%26gt%3B%3B%0A%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20clock-names%20%3D%20%22csi_mclk%22%3B%0A%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20csi_id%20%3D%20%26lt%3B1%26gt%3B%3B%0A%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20en-gpios%20%3D%20%26lt%3B%26amp%3Bgpio1%200%20GPIO_ACTIVE_LOW%26gt%3B%3B%0A%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20rst-gpios%20%3D%20%26lt%3B%26amp%3Bgpio1%201%20GPIO_ACTIVE_LOW%26gt%3B%3B%0A%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20mipi_csi%3B%0A%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20status%20%3D%20%22okay%22%3B%0A%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20port%20%7B%0A%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20camera_mipi_1_ep%3A%20endpoint%20%7B%0A%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20remote-endpoint%20%3D%20%26lt%3B%26amp%3Bmipi_csi1_ep%26gt%3B%3B%0A%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20data-lanes%20%3D%20%26lt%3B1%202%203%204%26gt%3B%3B%0A%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20clock-lanes%20%3D%20%26lt%3B0%26gt%3B%3B%0A%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20max-pixel-frequency%20%3D%20%2Fbits%2F%2064%20%26lt%3B266000000%26gt%3B%3B%0A%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%7D%3B%0A%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%7D%3B%0A%20%20%20%20%20%20%20%7D%3B%0A%7D%3B%0A%0A%26amp%3Bmipi_csi_0%20%7B%0A%20%20%20%20%20%20%20status%20%3D%20%22disabled%22%3B%0A%7D%3B%0A%0A%26amp%3Bmipi_csi_1%20%7B%0A%20%20%20%20%20%20%20%23address-cells%20%3D%20%26lt%3B1%26gt%3B%3B%0A%20%20%20%20%20%20%20%23size-cells%20%3D%20%26lt%3B0%26gt%3B%3B%0A%20%20%20%20%20%20%20status%20%3D%20%22okay%22%3B%0A%20%20%20%20%20%20%20port%401%20%7B%0A%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20reg%20%3D%20%26lt%3B1%26gt%3B%3B%0A%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20mipi_csi1_ep%3A%20endpoint%20%7B%0A%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20remote-endpoint%20%3D%20%26lt%3B%26amp%3Bcamera_mipi_1_ep%26gt%3B%3B%0A%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20data-lanes%20%3D%20%26lt%3B4%26gt%3B%3B%0A%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20csis-hs-settle%20%3D%20%26lt%3B13%26gt%3B%3B%0A%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20csis-clk-settle%20%3D%20%26lt%3B2%26gt%3B%3B%0A%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20csis-wclk%3B%0A%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%7D%3B%0A%20%20%20%20%20%20%20%7D%3B%0A%7D%3B%0A%0A%26amp%3Bisi_0%20%7B%0A%20%20%20%20%20%20%20status%20%3D%20%22disabled%22%3B%0A%7D%3B%0A%0A%26amp%3Bisi_1%20%7B%0A%20%20%20%20%20%20%20status%20%3D%20%22disabled%22%3B%0A%7D%3B%0A%0A%26amp%3Bisp_0%20%7B%0A%20%20%20%20%20%20%20status%20%3D%20%22okay%22%3B%0A%7D%3B%3C%2FCODE%3E%3C%2FPRE%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2228824%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20IMX8MP%20CSI%20port%202%20configuration%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2228824%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F248662%22%20target%3D%22_blank%22%3E%40Vilius%3C%2FA%3E%3C%2FP%3E%0A%3CP%3E%E3%81%8A%E5%85%83%E6%B0%97%E3%81%A7%E3%81%8A%E9%81%8E%E3%81%94%E3%81%97%E3%81%AE%E3%81%93%E3%81%A8%E3%81%A8%E6%80%9D%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fgithub.com%2Fnxp-imx%2Flinux-imx%2Fblob%2Fbe78e49cb4339fd38c9a40019df49b72fbb8bcb7%2Farch%2Farm64%2Fboot%2Fdts%2Ffreescale%2Fimx8mp-frdm-ap1302-dual.dts%23L125%22%20target%3D%22_self%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Eimx8mp-frdm-ap1302-dual.dts%3C%2FA%3E%E3%82%92%E3%81%94%E8%A6%A7%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%84%E3%81%9F%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%E3%82%B5%E3%83%A9%E3%82%B9%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E
