IMX8MP CLK register error
925 次查看
fuyao
hi, I use kernel 5.10.52,  the audio can not speaker, i found the sai3_mclk is not get.
The clk-blk-ctrl.c  is probe after clk-imx8mp.c
but clk-imx8mp.c use sai3_mclk which probe use clk-blk-ctrl.c.
is a method to probe clk-blk-ctrl.c first ?
the log is :
[ 1.012312] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[ 1.012327] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering...
[ 1.012355] jffs2: version 2.2. (NAND) © 2001-2006 Red Hat, Inc.
[ 1.012696] 9p: Installing v9fs 9p2000 file system support
[ 1.048754] Key type asymmetric registered
[ 1.048768] Asymmetric key parser 'x509' registered
[ 1.048807] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 241)
[ 1.048825] io scheduler mq-deadline registered
[ 1.048836] io scheduler kyber registered
[ 1.051718] samsung-hdmi-phy 32fdff00.hdmiphy: failed to get phy apb clk: -517
[ 1.051888] imx8-pcie-phy 32f00000.pcie-phy: failed to get imx pcie phy clock
[ 1.056638] pwm-backlight lvds_backlight: supply power not found, using dummy regulator
[ 1.057357] EINJ: ACPI disabled.
[ 1.061880] i.MX clk 324: register failed with -2
[ 1.061901] i.MX clk 325: register failed with -2
[ 1.061912] i.MX clk 326: register failed with -2
[ 1.061922] i.MX clk 328: register failed with -2
[ 1.061932] i.MX clk 329: register failed with -2
[ 1.061942] i.MX clk 330: register failed with -2
[ 1.067866] imx-sdma 30bd0000.dma-controller: no event needs to be remapped
[ 1.069686] imx-sdma 30bd0000.dma-controller: firmware found.
[ 1.069880] imx-sdma 30bd0000.dma-controller: loaded firmware 4.6
0 回复数
