IMX8MM shutdown command casuing Reset (POR)
deepakraj
For LEC-IMX8MM Kirkstone, when we run shutdown command, our module get reset (POR). We cross refered with scarthgap u-boot(scarthgap uboot + krikstone kernel ,FS) same setup module get shutdown properly.
we suspect kirkstone u-boot causing module to enter reset when providing shutdown command.
deepakraj
thanks for you information, could you please share the release note or document  ,where issue has been mentioned.
Bio_TICFSL
Yes, that correct, this is suppose to be fixed in scargapth, so you have to migrate your bsp to the new one.
