IMX8MM shutdown command casuing Reset (POR)
1,457 次查看
deepakraj
For LEC-IMX8MM Kirkstone, when we run shutdown command, our module get reset (POR). We cross refered with scarthgap u-boot(scarthgap uboot + krikstone kernel ,FS) same setup module get shutdown properly.
we suspect kirkstone u-boot causing module to enter reset when providing shutdown command.
1,409 次查看
deepakraj
thanks for you information, could you please share the release note or document  ,where issue has been mentioned.
1,431 次查看
Bio_TICFSL
Yes, that correct, this is suppose to be fixed in scargapth, so you have to migrate your bsp to the new one.
