IMX8MM LVDS Timing Issue
2,927 次查看
FOC
Hi Everyone,
I am using dual LVDS display with MX8M Mini variscite SoM, but I think there is a problem with LCD timings. There is a flickering and scrolling problem on the screen. Can anyone check the dts and LCD timings? There is an horizontal area on the screen and distorts the application window.
2,898 次查看
Bio_TICFSL
We can not tested here but change the LCD clock for timing issue on the DTB.
2,888 次查看
FOC
Hi Bio,
Thanks for your reply.
Should I only change the clock value? Can you check the LCD datasheet and advise? Is this possible?
