IMX8M | modify Yocto device tree
9,078件の閲覧回数
shai_b
Senior Contributor II
Dear team,
My customer would like to find the location of the imx8m device tree source (DTS) in order to modify a few parameters.
1. Could you please advise where the source code of these files are located?
2. What is the best way to compile only the device tree and add the complied file (DTB) into u-boot?
Wating for your kind feedback, many thanks.
KR,
Shai
ラベル(2)
9,021件の閲覧回数
karl1688
Use "bitbake linux-imx -c devshell" open a new terminal, the path for example
<local build folder>/tmp/work-shared/imx8mp-lpddr4-evk/kernel-source
Change dts file in <local build folder>/tmp/work/imx8mp_lpddr4_evk-poky-linux/linux-imx/5.15.32+gitAUTOINC+fa6c316859-r0/git/arch/arm64/boot/dts/freescale/
Then do "make dtbs" in new terminal, the new dtb general in <local build folder>/tmp/work/imx8mp_lpddr4_evk-poky-linux/linux-imx/5.15.32+gitAUTOINC+fa6c316859-r0/build/arch/arm64/boot/dts/freescale/
9,063件の閲覧回数
Zhiming_Liu
