IMX8M Plus and USB 3.0 operating mode
已解决
跳至解决方案
1,893 次查看
reg_davoust
Is it possible to configure IMX8M Plus with one port as USB 3.0 host and simultaneously the other port as USB 3.0 device.
1 解答
1,861 次查看
riteshmpatel
Hi @reg_davoust,
I hope you are doing well.
One can use one of the USB ports in Host mode and the other port in Device mode.
Thanks & Regards,
Ritesh M Patel
在原帖中查看解决方案
2 回复数
1,862 次查看
riteshmpatel
Hi @reg_davoust,
Thanks & Regards,
Ritesh M Patel
1,820 次查看
reg_davoust
thanks for the reply, I have taken note of the possibility of using the IMX8 in mode host and device
