Is it possible to configure IMX8M Plus with one port as USB 3.0 host and simultaneously the other port as USB 3.0 device.
Solved! Go to Solution.
Hi @reg_davoust,
I hope you are doing well.
One can use one of the USB ports in Host mode and the other port in Device mode.
Thanks & Regards,
Ritesh M Patel
Hi @reg_davoust,
Thanks & Regards,
Ritesh M Patel
thanks for the reply, I have taken note of the possibility of using the IMX8 in mode host and device
