IMX8M Plus Display logo during kernel (Android11_2.6.0)
6,125件の閲覧回数
vachlan
Due to the BSP(android11_2.6.0) package being  by default IMX8MP_ USES_ GKI =true。
Display drivers are loaded after kernel startup,Causing inability to display logo during kernel startup。
I will use IMX8MP_ USES_ GKI=true commented out, there was a GPU error as attached.
Please advise on how to correct the errors in this section。
6 返答(返信)
6,100件の閲覧回数
Rita_Wang
Do you want the uboot logo keep in the kernel ?
6,093件の閲覧回数
vachlan
Yes, I want to do that. But first of all, I want to display the logo in the kernel in this BSP
6,102件の閲覧回数
Rita_Wang
Are you using the NXP i.MX8MP LPDDR4 EVK board?
6,092件の閲覧回数
vachlan
Yes, we are using this board, and we have designed a similar board
6,074件の閲覧回数
vachlan
Thank you, I have read these two links you sent (which I plan to follow up on). May I ask if the IMX8MP_ USES_ GKI=true commented out。 Can GPU errors be corrected?
