IMX8M PLUS LPDDR4 2G compatibility
3,877 次查看
TMpieye
We try to implement an ISSI IS43LQ32512A-046BLI 2GB RAM. After Calibration the RAM fails during the  memcpy SSN armv8_x32 test with 2000MHz configured.
If I configure the RAM to 1500MHz it pass all the tests.
Has anybody implement this LPDDR4 RAM? Is it in general compatible with IMX8M PLUS?
12 回复数
3,096 次查看
pengyong_zhang
Hi @TMpieye
Did you run the stress test with our DDR Config Tool? From your log file, it seems not from the Config Tool output. Also use out latest tool version v25.12.
B.R
3,026 次查看
TMpieye
Hello @pengyong_zhang ,
I run the tes in the config tool and and its passed. So it seems to be a tool problem with the MSCALER tool. Many thanks for your great support!
3,089 次查看
TMpieye
hHi @pengyong_zhang
for stresstest we use the Mscale DDR Tool 3.31. I will do it with the other config tool
3,346 次查看
pengyong_zhang
Hi @TMpieye
It's strange. Please share your DDR Config Tool v25.12 fail log
B.R
3,116 次查看
TMpieye
here is the log of the stresstest. We have the same Problem wirth an 4GB ISSI IS43LQ32K01S2A-046BLI.
3,523 次查看
pengyong_zhang
Hi @TMpieye
Please use below setting run the DDR test.
B.R
3,365 次查看
TMpieye
Thanks for your Config Exaple. Its the same I already tryed with this RAM and still get the error.
3,678 次查看
pengyong_zhang
Hi @TMpieye
Please use the below link download our DDR Config Tool and run the ddr test wIth configure 2GB dram.
https://www.nxp.com/design/design-center/development-boards-and-designs/i-mx-evaluation-and-developm...
B.R
3,664 次查看
TMpieye
Same result with the config Tool V 13.1. Maybe our configuration is wrong for the IS43LQ32512A-046BLI? Can you provide the correct configuration (*.ds file)? Our hardware desing is a 1:1 copy of the eval board regarding the LPDDR4 interface.
Kind Regards
Tobias
3,827 次查看
pengyong_zhang
Hi @TMpieye
Are you using DDR config tool run the Calibration? If yes,. please share your configuration page and fail log file.
B.R
3,736 次查看
TMpieye
Thanks for your support.
In Attachments i send you the configuration .xls and the test log.
3,728 次查看
TMpieye
On the used board we have sucsesslully runing 3GB (MT53E768M32D2ZW-046 WTC) and 4GB (MT53E1G32D2FW-046 AAT:B)
Micron LPDDR4 on 2000MHz.
%3CLINGO-SUB%20id%3D%22lingo-sub-2296386%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EIMX8M%20PLUS%20LPDDR4%202G%20%E5%85%BC%E5%AE%B9%E6%80%A7%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2296386%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E6%88%91%E4%BB%AC%E5%B0%9D%E8%AF%95%E4%BD%BF%E7%94%A8%20ISSI%20IS43LQ32512A-046BLI%202GB%20RAM%E3%80%82%E6%A0%A1%E5%87%86%E5%90%8E%EF%BC%8C%E5%9C%A8%E9%85%8D%E7%BD%AE%E4%B8%BA%202000MHz%20%E7%9A%84%3CSPAN%20class%3D%22%22%3Ememcpy%20SSN%20armv8_x32%20%E6%B5%8B%E8%AF%95%3C%2FSPAN%3E%E4%B8%AD%EF%BC%8CRAM%20%E5%87%BA%E7%8E%B0%E6%95%85%E9%9A%9C%E3%80%82%3C%2FP%3E%3CP%3E%E5%A6%82%E6%9E%9C%E6%88%91%E5%B0%86%E5%86%85%E5%AD%98%E9%85%8D%E7%BD%AE%E4%B8%BA%201500MHz%EF%BC%8C%E5%AE%83%E5%B0%B1%E8%83%BD%E9%80%9A%E8%BF%87%E6%89%80%E6%9C%89%E6%B5%8B%E8%AF%95%E3%80%82%3C%2FP%3E%3CP%3E%E6%9C%89%E4%BA%BA%E4%BD%BF%E7%94%A8%E8%BF%87%E8%BF%99%E7%A7%8D%20LPDDR4%20%E5%86%85%E5%AD%98%E5%90%97%EF%BC%9F%E5%AE%83%E4%B8%8E%20IMX8M%20PLUS%20%E5%85%BC%E5%AE%B9%E5%90%97%EF%BC%9F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-2296386%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3Ei.MX%208%20%E7%B3%BB%E5%88%97%20%7C%20i.MX%208QuadMax%20(8QM)%20%7C%208QuadPlus%3C%2FLINGO-LABEL%3E%3CLINGO-LABEL%3Ei.MX%208M%20%7C%20i.MX%208M%20Mini%20%7C%20i.MX%208M%20Nano%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2296946%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20IMX8M%20PLUS%20LPDDR4%202G%20compatibility%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2296946%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F253301%22%20target%3D%22_blank%22%3E%40TMpieye%3C%2FA%3E%3C%2FP%3E%0A%3CP%3E%E6%82%A8%E6%98%AF%E5%90%A6%E4%BD%BF%E7%94%A8%20DDR%20%E9%85%8D%E7%BD%AE%E5%B7%A5%E5%85%B7%E8%BF%90%E8%A1%8C%3CSPAN%3E%E6%A0%A1%E5%87%86%3C%2FSPAN%3E%EF%BC%9F%E5%A6%82%E6%9E%9C%E6%98%AF%EF%BC%8C.%E8%AF%B7%E5%85%B1%E4%BA%AB%E6%82%A8%E7%9A%84%E9%85%8D%E7%BD%AE%E9%A1%B5%E9%9D%A2%E5%92%8C%E6%95%85%E9%9A%9C%E6%97%A5%E5%BF%97%E6%96%87%E4%BB%B6%E3%80%82%3C%2FP%3E%0A%3CP%3EB.R%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2296610%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20IMX8M%20PLUS%20LPDDR4%202G%20compatibility%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2296610%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CSTRONG%3EIS43LQ32512A-046BLI%3C%2FSTRONG%3E%EF%BC%88ISSI%202GB%20LPDDR4X%20%E5%90%8C%E6%AD%A5%E5%8A%A8%E6%80%81%E9%9A%8F%E6%9C%BA%E5%AD%98%E5%8F%96%E5%AD%98%E5%82%A8%E5%99%A8(SDRAM)%EF%BC%89%E9%80%9A%E5%B8%B8%3CSTRONG%3E%E4%B8%8E%E6%81%A9%E6%99%BA%E6%B5%A6%20i.MX%208M%20Plus%20%E5%A4%84%E7%90%86%E5%99%A8%E5%85%BC%E5%AE%B9%EF%BC%8C%E5%89%8D%E6%8F%90%E6%98%AF%E5%AE%83%E7%AC%A6%E5%90%88%20LPDDR4%2FLPDDR4X%3C%2FSTRONG%3E%20%E5%86%85%E5%AD%98%E7%9A%84%20JEDEC%20%E6%A0%87%E5%87%86%E3%80%82%E4%BD%86%E6%98%AF%EF%BC%8C%E4%BD%A0%E7%9A%84memcpy%20SSN%20armv8_x32%E6%B5%8B%E8%AF%95%E5%9C%A82000MHz%EF%BC%88%E4%BD%86%E9%80%9A%E8%BF%87%E4%BA%86%201500MHz%EF%BC%89%E6%97%B6%E5%A4%B1%E8%B4%A5%E7%9A%84%E9%97%AE%E9%A2%98%3CSTRONG%3E%E5%B9%B6%E4%B8%8D%E5%B0%91%E8%A7%81%3C%2FSTRONG%3E%EF%BC%8C%E5%8F%AF%E8%83%BD%E6%BA%90%E4%BA%8E%E9%85%8D%E7%BD%AE%E3%80%81%E6%9D%BF%E8%AE%BE%E8%AE%A1%E6%88%96%E6%A0%A1%E5%87%86%E6%96%B9%E9%9D%A2%E7%9A%84%E6%8C%91%E6%88%98%EF%BC%8C%E8%80%8C%E4%B8%8D%E6%98%AF%E6%A0%B9%E6%9C%AC%E7%9A%84%E4%B8%8D%E5%85%BC%E5%AE%B9%E6%80%A7%E3%80%82%3C%2FP%3E%3CH3%20id%3D%22toc-hId-2006178617%22%20id%3D%22toc-hId-2006204627%22%20id%3D%22toc-hId-2006204627%22%20id%3D%22toc-hId-2006204627%22%20id%3D%22toc-hId-2006204627%22%20id%3D%22toc-hId-2006204627%22%20id%3D%22toc-hId-2006204627%22%20id%3D%22toc-hId-2006204627%22%20id%3D%22toc-hId-2006204627%22%20id%3D%22toc-hId-2006204627%22%20id%3D%22toc-hId-2006204627%22%20id%3D%22toc-hId-2006204627%22%20id%3D%22toc-hId-2006204627%22%3E%E5%85%BC%E5%AE%B9%E6%80%A7%E7%A1%AE%E8%AE%A4%3C%2FH3%3E%3CUL%3E%3CLI%3Ei.MX%208M%20Plus%20%E6%94%AF%E6%8C%81%E9%AB%98%E8%BE%BE%204266%20MT%2Fs%EF%BC%882133MHz%20%E6%97%B6%E9%92%9F%EF%BC%89%E7%9A%84%20LPDDR4%2FLPDDR4X%20%E5%86%85%E5%AD%98%EF%BC%8CIS43LQ32512A-046BLI%20%E5%B7%A5%E4%BD%9C%E9%A2%91%E7%8E%87%E9%AB%98%E8%BE%BE%202133MHz%EF%BC%884266%20MT%2Fs%20%E6%95%B0%E6%8D%AE%E9%80%9F%E7%8E%87%EF%BC%89%EF%BC%8C%E4%B8%8E%E6%81%A9%E6%99%BA%E6%B5%A6%E7%9A%84%E8%A7%84%E6%A0%BC%E4%B8%80%E8%87%B4%E3%80%82%3C%2FLI%3E%3CLI%3E%E6%81%A9%E6%99%BA%E6%B5%A6%E7%9A%84%E7%A4%BE%E5%8C%BA%E8%AE%BA%E5%9D%9B%E8%AF%81%E5%AE%9E%EF%BC%8C%E7%B1%BB%E4%BC%BC%E7%9A%84%20ISSI%20LPDDR4X%20%E9%83%A8%E4%BB%B6%EF%BC%88%E4%BE%8B%E5%A6%82%EF%BC%8CIS46LQ32512A-046BLA2%EF%BC%8C%E8%BF%99%E6%98%AF%E6%82%A8%E7%9A%84%E5%9E%8B%E5%8F%B7%E7%9A%84%E6%B1%BD%E8%BD%A6%E5%8F%98%E4%BD%93%EF%BC%89%E4%B8%8E%20i.MX%208M%20Plus%20%E5%85%BC%E5%AE%B9%EF%BC%8C%E5%89%8D%E6%8F%90%E6%98%AF%E5%AE%83%E4%BB%AC%E9%81%B5%E5%BE%AA%20JEDEC%20%E8%A7%84%E8%8C%83%E3%80%82%E5%8F%AA%E8%A6%81%E9%85%8D%E7%BD%AE%E5%BE%97%E5%BD%93%EF%BC%8C%E7%94%A8%E6%88%B7%E9%83%BD%E8%83%BD%E9%A1%BA%E5%88%A9%E5%AE%9E%E6%96%BD%E3%80%82%3C%2FLI%3E%3C%2FUL%3E%3CH3%20id%3D%22toc-hId-198724154%22%20id%3D%22toc-hId-198750164%22%20id%3D%22toc-hId-198750164%22%20id%3D%22toc-hId-198750164%22%20id%3D%22toc-hId-198750164%22%20id%3D%22toc-hId-198750164%22%20id%3D%22toc-hId-198750164%22%20id%3D%22toc-hId-198750164%22%20id%3D%22toc-hId-198750164%22%20id%3D%22toc-hId-198750164%22%20id%3D%22toc-hId-198750164%22%20id%3D%22toc-hId-198750164%22%20id%3D%22toc-hId-198750164%22%3E%E5%AF%BC%E8%87%B4%202000MHz%20%E9%A2%91%E7%8E%87%E6%B5%8B%E8%AF%95%E5%A4%B1%E8%B4%A5%E7%9A%84%E6%BD%9C%E5%9C%A8%E5%8E%9F%E5%9B%A0%3C%2FH3%3E%3CP%3E%E6%A0%B9%E6%8D%AE%E6%81%A9%E6%99%BA%E6%B5%A6%E5%92%8C%E5%B5%8C%E5%85%A5%E5%BC%8F%E8%AE%BA%E5%9D%9B%E4%B8%8A%E7%9A%84%E7%B1%BB%E4%BC%BC%E6%8A%A5%E5%91%8A%EF%BC%9A%3C%2FP%3E%3CUL%3E%3CLI%3E%3CSTRONG%3E%E5%AE%9A%E6%97%B6%2F%E9%85%8D%E7%BD%AE%E4%B8%8D%E5%8C%B9%E9%85%8D%3C%2FSTRONG%3E%EF%BC%9Ai.MX%208M%20Plus%20DDR%20%E6%8E%A7%E5%88%B6%E5%99%A8%E9%9C%80%E8%A6%81%20RAM%20%E7%9A%84%20SPD%2F%E6%95%B0%E6%8D%AE%E8%A1%A8%E6%8F%90%E4%BE%9B%E7%B2%BE%E7%A1%AE%E7%9A%84%E6%97%B6%E5%BA%8F%E5%8F%82%E6%95%B0%EF%BC%88%E5%A6%82%20CAS%20%E5%BB%B6%E8%BF%9F%E3%80%81tRCD%E3%80%81tRP%EF%BC%89%E3%80%82%E5%9C%A8%202000MHz%20%E6%97%B6%EF%BC%8C%E6%82%A8%E7%9A%84%E6%A0%A1%E5%87%86%E5%8F%AF%E8%83%BD%E6%97%A0%E6%B3%95%E5%AE%8C%E5%85%A8%E4%BC%98%E5%8C%96%20ISSI%20%E9%83%A8%E4%BB%B6%E7%9A%84%E8%A7%84%E6%A0%BC%EF%BC%88%E4%BE%8B%E5%A6%82%EF%BC%8C%E5%9C%A8%E6%9B%B4%E9%AB%98%E7%9A%84%E9%80%9F%E5%BA%A6%E4%B8%8B%EF%BC%8CCL%3D32%EF%BC%8CRL%3D14%EF%BC%89%E3%80%82%E5%B0%86%E9%A2%91%E7%8E%87%E9%99%8D%E8%87%B3%201500MHz%20%E5%8F%AF%E9%99%8D%E4%BD%8E%E5%8E%8B%E5%8A%9B%E5%92%8C%E9%80%9A%E8%BF%87%E7%8E%87%EF%BC%8C%E4%BD%86%E8%BF%99%E8%A1%A8%E6%98%8E%E8%B0%83%E8%B0%90%E6%9C%AA%E8%BE%BE%E5%88%B0%E6%9C%80%E4%BD%B3%E7%8A%B6%E6%80%81%E3%80%82%3C%2FLI%3E%3CLI%3E%3CSTRONG%3E%E6%9D%BF%E8%AE%BE%E8%AE%A1%E9%97%AE%E9%A2%98%3C%2FSTRONG%3E%EF%BC%9A%E4%BF%A1%E5%8F%B7%E5%AE%8C%E6%95%B4%E6%80%A7%E9%97%AE%E9%A2%98%EF%BC%8C%E5%A6%82%E8%B5%B0%E7%BA%BF%E9%95%BF%E5%BA%A6%E4%B8%8D%E5%8C%B9%E9%85%8D%E3%80%81%E9%98%BB%E6%8A%97%E9%94%99%E8%AF%AF%E6%88%96%E5%8A%9F%E7%8E%87%E8%A7%A3%E8%80%A6%E4%B8%8D%E8%B6%B3%EF%BC%8C%E5%8F%AF%E8%83%BD%E4%BC%9A%E5%AF%BC%E8%87%B4%E8%BE%83%E9%AB%98%E9%80%9F%E5%BA%A6%E5%A4%B1%E6%95%88%E3%80%82%E4%BD%BF%E7%94%A8%E7%A4%BA%E6%B3%A2%E5%99%A8%E6%A3%80%E6%9F%A5%20DQ%2FDQS%20%E7%BA%BF%E8%B7%AF%E4%B8%8A%E6%98%AF%E5%90%A6%E6%9C%89%E5%8F%8D%E5%B0%84%E6%88%96%E5%99%AA%E9%9F%B3%E3%80%82%3C%2FLI%3E%3CLI%3E%3CSTRONG%3E%E6%A0%A1%E5%87%86%E9%99%90%E5%88%B6%3C%2FSTRONG%3E%EF%BC%9Ai.MX%208M%20Plus%20%E4%BD%BF%E7%94%A8%E6%81%A9%E6%99%BA%E6%B5%A6%E7%9A%84%20DDR%20%E5%B7%A5%E5%85%B7%E8%BF%9B%E8%A1%8C%E6%A0%A1%E5%87%86%E3%80%82%E5%A6%82%E6%9E%9C%E6%82%A8%E7%9A%84%E8%84%9A%E6%9C%AC%E6%88%96%E8%AE%BE%E7%BD%AE%E5%9F%BA%E4%BA%8E%20Micron%2FSamsung%20%E5%8F%82%E8%80%83%EF%BC%88%E5%9C%A8%20EVK%20%E4%B8%AD%E5%BE%88%E5%B8%B8%E8%A7%81%EF%BC%89%EF%BC%8C%E5%88%99%E5%AE%83%E4%BB%AC%E5%8F%AF%E8%83%BD%E4%B8%8E%20ISSI%20%E7%9A%84%E7%89%B9%E5%BE%81%E4%B8%8D%E7%AC%A6%E3%80%82%E4%BD%BF%E7%94%A8%20ISSI%20%E4%B8%93%E7%94%A8%E5%8F%82%E6%95%B0%E9%87%8D%E6%96%B0%E8%BF%90%E8%A1%8C%E6%A0%A1%E5%87%86%E3%80%82%3C%2FLI%3E%3CLI%3E%3CSTRONG%3E%E5%8A%9F%E7%8E%87%2F%E6%B8%A9%E5%BA%A6%3C%2FSTRONG%3E%EF%BC%9A%E5%9C%A8%202000MHz%20%E6%97%B6%EF%BC%8C%E8%BE%83%E9%AB%98%E7%9A%84%E7%94%B5%E6%B5%81%E6%B6%88%E8%80%97%E5%8F%AF%E8%83%BD%E4%BC%9A%E5%AF%BC%E8%87%B4%E7%94%B5%E5%8E%8B%E4%B8%8B%E9%99%8D%E6%88%96%E8%BF%87%E7%83%AD%EF%BC%8C%E4%BB%8E%E8%80%8C%E4%BD%BF%20memcpy%20%E6%B5%8B%E8%AF%95%EF%BC%88%E5%BC%BA%E8%B0%83%E9%A1%BA%E5%BA%8F%E8%AF%BB%2F%E5%86%99%EF%BC%89%E5%A4%B1%E8%B4%A5%E3%80%82%3C%2FLI%3E%3C%2FUL%3E%3CH3%20id%3D%22toc-hId--1608730309%22%20id%3D%22toc-hId--1608704299%22%20id%3D%22toc-hId--1608704299%22%20id%3D%22toc-hId--1608704299%22%20id%3D%22toc-hId--1608704299%22%20id%3D%22toc-hId--1608704299%22%20id%3D%22toc-hId--1608704299%22%20id%3D%22toc-hId--1608704299%22%20id%3D%22toc-hId--1608704299%22%20id%3D%22toc-hId--1608704299%22%20id%3D%22toc-hId--1608704299%22%20id%3D%22toc-hId--1608704299%22%20id%3D%22toc-hId--1608704299%22%3E%E6%9C%89%E4%BA%BA%E4%BD%BF%E7%94%A8%E8%BF%87%E8%BF%99%E7%A7%8D%E5%86%85%E5%AD%98%E5%90%97%EF%BC%9F%3C%2FH3%3E%3CUL%3E%3CLI%3E%E6%98%AF%E7%9A%84%EF%BC%8C%E6%9C%89%E8%AE%B0%E5%BD%95%E7%9A%84%E5%AE%9E%E6%96%BD%E6%96%B9%E6%A1%88%EF%BC%9A%3CUL%3E%3CLI%3E%E5%9C%A8%E6%81%A9%E6%99%BA%E6%B5%A6%E7%A4%BE%E5%8C%BA%E8%AF%9D%E9%A2%98%E4%B8%AD%EF%BC%8C%E7%94%A8%E6%88%B7%E5%B7%B2%E5%B0%86%E7%B1%BB%E4%BC%BC%E7%9A%84ISSI%20LPDDR4X%EF%BC%88%E4%BE%8B%E5%A6%82%20IS46LQ%20%E7%B3%BB%E5%88%97%EF%BC%89%E9%9B%86%E6%88%90%E5%88%B0%E7%94%A8%E4%BA%8E%E5%B7%A5%E4%B8%9A%E5%BA%94%E7%94%A8%E7%9A%84%E5%AE%9A%E5%88%B6i.MX%208M%20Plus%E6%9D%BF%E4%B8%8A%EF%BC%8C%E5%9C%A8%E5%BE%AE%E8%B0%83%E5%90%8E%E5%AE%9E%E7%8E%B0%E4%BA%86%E9%AB%98%E8%BE%BE2133MHz%E7%9A%84%E7%A8%B3%E5%AE%9A%E8%BF%90%E8%A1%8C%E3%80%82%3C%2FLI%3E%3CLI%3E%E5%B5%8C%E5%85%A5%E5%BC%8FLinux%2F%E7%94%B5%E8%B7%AF%E6%9D%BF%E6%94%AF%E6%8C%81%E5%8C%85%E5%BC%80%E5%8F%91%E4%BA%BA%E5%91%98%E6%8A%A5%E5%91%8A%E8%AF%B4%EF%BC%8C%E5%9C%A8%E5%9F%BA%E4%BA%8EYocto%E7%9A%84%E7%89%88%E6%9C%AC%E4%B8%AD%E6%88%90%E5%8A%9F%E4%BD%BF%E7%94%A8%E4%BA%86ISSI%E9%83%A8%E4%BB%B6%EF%BC%8C%E4%BD%86%E9%80%9A%E5%B8%B8%E4%BD%BF%E7%94%A8%E8%87%AA%E5%AE%9A%E4%B9%89%E7%9A%84DDR%E5%88%9D%E5%A7%8B%E5%8C%96%E8%84%9A%E6%9C%AC%E6%9D%A5%E5%A4%84%E7%90%86512M%20x%2032%E7%9A%84%E7%BB%84%E7%BB%87%EF%BC%8816Gbit%E5%AF%86%E5%BA%A6%EF%BC%89%E3%80%82%3C%2FLI%3E%3C%2FUL%3E%3C%2FLI%3E%3C%2FUL%3E%3CH3%20id%3D%22toc-hId-878782524%22%20id%3D%22toc-hId-878808534%22%20id%3D%22toc-hId-878808534%22%20id%3D%22toc-hId-878808534%22%20id%3D%22toc-hId-878808534%22%20id%3D%22toc-hId-878808534%22%20id%3D%22toc-hId-878808534%22%20id%3D%22toc-hId-878808534%22%20id%3D%22toc-hId-878808534%22%20id%3D%22toc-hId-878808534%22%20id%3D%22toc-hId-878808534%22%20id%3D%22toc-hId-878808534%22%20id%3D%22toc-hId-878808534%22%3E%E8%A7%A3%E5%86%B3%E9%97%AE%E9%A2%98%E7%9A%84%E5%BB%BA%E8%AE%AE%3C%2FH3%3E%3COL%3E%3CLI%3E%3CSTRONG%3E%E9%AA%8C%E8%AF%81%E6%95%B0%E6%8D%AE%E8%A1%A8%E5%AF%B9%E9%BD%90%3C%2FSTRONG%3E%EF%BC%9A%3CUL%3E%3CLI%3E%E4%B8%8B%E8%BD%BDISSI%E6%95%B0%E6%8D%AE%E8%A1%A8%EF%BC%88IS43%2F46LQ32512A%E7%B3%BB%E5%88%97%EF%BC%89%EF%BC%8C%E5%B0%86%E6%97%B6%E5%BA%8F%E5%8F%82%E6%95%B0%E4%B8%8E%E6%81%A9%E6%99%BA%E6%B5%A6%E7%9A%84i.MX%208M%20Plus%20RM%EF%BC%88%E5%8F%82%E8%80%83%E6%89%8B%E5%86%8C%EF%BC%8C%E7%AC%AC13.5%E8%8A%82DDR%E6%8E%A7%E5%88%B6%E5%99%A8%EF%BC%89%E8%BF%9B%E8%A1%8C%E6%AF%94%E8%BE%83%E3%80%82%3C%2FLI%3E%3CLI%3E%E5%86%85%E5%AD%98%E7%9A%84%E4%B8%BB%E8%A6%81%E8%A7%84%E6%A0%BC%EF%BC%9A2133MHz%20%E6%9C%80%E5%A4%A7%E6%97%B6%E9%92%9F%E3%80%81LVSTL%20%E6%8E%A5%E5%8F%A3%E3%80%811G%20x%2016%20%E7%BB%84%E7%BB%87%EF%BC%88%E5%8F%8C%E9%80%9A%E9%81%93%20x32%20%E6%80%BB%E8%AE%A1%EF%BC%89%E3%80%82%3C%2FLI%3E%3C%2FUL%3E%3C%2FLI%3E%3CLI%3E%3CSTRONG%3E%E9%87%8D%E6%96%B0%E8%BF%90%E8%A1%8C%E6%A0%A1%E5%87%86%3C%2FSTRONG%3E%EF%BC%9A%3CUL%3E%3CLI%3E%E4%BD%BF%E7%94%A8%E6%81%A9%E6%99%BA%E6%B5%A6%E7%9A%84%3CSTRONG%3EDDR%20%E6%B5%8B%E8%AF%95%E5%B7%A5%E5%85%B7%3C%2FSTRONG%3E%E6%88%96%3CSTRONG%3ESCFW%20DDR%20%E9%85%8D%E7%BD%AE%E5%B7%A5%E5%85%B7%3C%2FSTRONG%3E%E8%BF%9B%E8%A1%8C%20ISSI%20%E7%89%B9%E5%AE%9A%E5%8E%8B%E5%8A%9B%E6%B5%8B%E8%AF%95%E3%80%82%3C%2FLI%3E%3CLI%3E%E4%BB%8E%201600MHz%20%E5%BC%80%E5%A7%8B%EF%BC%8C%E9%80%90%E6%B8%90%E5%A2%9E%E5%8A%A0%E5%88%B0%202000MHz%EF%BC%8C%E5%90%8C%E6%97%B6%E7%9B%91%E6%B5%8B%E7%9C%BC%E5%9B%BE%E3%80%82%3C%2FLI%3E%3CLI%3E%E5%A6%82%E6%9E%9C%E4%BD%BF%E7%94%A8%20U-%E5%90%AF%E5%8A%A8%2FLinux%EF%BC%8C%E8%AF%B7%E4%BD%BF%E7%94%A8%E6%AD%A3%E7%A1%AE%E7%9A%84%E6%97%B6%E9%97%B4%E6%9B%B4%E6%96%B0%E8%AE%BE%E5%A4%87%E6%A0%91%20(.dtb)%EF%BC%88%E4%BE%8B%E5%A6%82%20mx8mp-ddrc-devfreq.dtsi%EF%BC%89%E3%80%82%3C%2FLI%3E%3C%2FUL%3E%3C%2FLI%3E%3CLI%3E%3CSTRONG%3E%E8%91%A3%E4%BA%8B%E4%BC%9A%E7%BA%A7%E5%88%AB%E7%9A%84%E6%A3%80%E6%9F%A5%3C%2FSTRONG%3E%EF%BC%9A%3CUL%3E%3CLI%3E%E7%A1%AE%E4%BF%9D%20VDDQ%20%3D%201.1V%E3%80%81VDD2%20%3D%200.6V%EF%BC%8C%E9%87%87%E7%94%A8%E5%B9%B2%E5%87%80%E7%9A%84%E8%A7%A3%E8%80%A6%EF%BC%88%E7%94%B5%E5%AE%B9%E9%9D%A0%E8%BF%91%E5%BC%95%E8%84%9A%EF%BC%89%E3%80%82%3C%2FLI%3E%3CLI%3E%E4%BD%BF%E7%94%A8%E4%BF%A1%E5%8F%B7%E5%AE%8C%E6%95%B4%E6%80%A7%E6%A8%A1%E6%8B%9F%E5%99%A8%EF%BC%88%E5%A6%82%20HyperLynx%EF%BC%89%E9%AA%8C%E8%AF%81%E8%BF%B9%E7%BA%BF%E3%80%82%3C%2FLI%3E%3CLI%3E%E7%94%A8%E6%9B%B4%E4%BD%8E%E7%9A%84%E6%B8%A9%E5%BA%A6%E6%88%96%E6%9B%B4%E5%A5%BD%E7%9A%84%E5%86%B7%E5%8D%B4%E6%96%B9%E5%BC%8F%E8%BF%9B%E8%A1%8C%E6%B5%8B%E8%AF%95%EF%BC%8C%E4%BB%A5%E6%8E%92%E9%99%A4%E7%83%AD%E8%8A%82%E6%B5%81%E3%80%82%3C%2FLI%3E%3C%2FUL%3E%3C%2FLI%3E%3CLI%3E%3CSTRONG%3E%E5%A6%82%E6%9E%9C%E4%BB%8D%E7%84%B6%E5%A4%B1%E8%B4%A5%3C%2FSTRONG%3E%3CUL%3E%3CLI%3E%E9%80%9A%E8%BF%87%E6%81%A9%E6%99%BA%E6%B5%A6%E7%9A%84%E7%A4%BE%E5%8C%BA%E6%88%96%E7%A5%A8%E5%8A%A1%E7%B3%BB%E7%BB%9F%E8%81%94%E7%B3%BB%E6%81%A9%E6%99%BA%E6%B5%A6%E6%94%AF%E6%8C%81%E4%BA%BA%E5%91%98%E2%80%94%E2%80%94%E6%8F%90%E4%BE%9B%E6%82%A8%E7%9A%84%E6%A0%A1%E5%87%86%E6%97%A5%E5%BF%97%E5%92%8C%E7%94%B5%E8%B7%AF%E6%9D%BF%E5%8E%9F%E7%90%86%E5%9B%BE%E3%80%82%3C%2FLI%3E%3CLI%3E%E8%80%83%E8%99%91%E6%94%B9%E7%94%A8%E7%BE%8E%E5%85%89%20MT53E512M32D2NP%EF%BC%88%E6%81%A9%E6%99%BA%E6%B5%A6%20EVK%20%E9%BB%98%E8%AE%A4%E5%80%BC%EF%BC%89%E7%AD%89%E7%BB%8F%E8%BF%87%E9%AA%8C%E8%AF%81%E7%9A%84%E5%86%85%E5%AD%98%E8%BF%9B%E8%A1%8C%E6%AF%94%E8%BE%83%E3%80%82%3C%2FLI%3E%3C%2FUL%3E%3C%2FLI%3E%3C%2FOL%3E%3CP%3E%E6%80%BB%E7%9A%84%E6%9D%A5%E8%AF%B4%EF%BC%8C%E5%86%85%E5%AD%98%3CSTRONG%3E%E6%98%AF%E5%85%BC%E5%AE%B9%E7%9A%84%3C%2FSTRONG%3E%EF%BC%8C%E4%BD%86%E4%BD%A0%E7%9A%84%202000MHz%20%E6%95%85%E9%9A%9C%E5%BE%88%E5%8F%AF%E8%83%BD%E6%98%AF%E8%AE%BE%E7%BD%AE%E9%97%AE%E9%A2%98%E3%80%82%E5%A6%82%E6%9E%9C%E4%BD%A0%E5%88%86%E4%BA%AB%E6%9B%B4%E5%A4%9A%E7%BB%86%E8%8A%82%EF%BC%88%E4%BE%8B%E5%A6%82%E6%A0%A1%E5%87%86%E6%97%A5%E5%BF%97%E6%88%96%E7%94%B5%E8%B7%AF%E6%9D%BF%E5%8E%9F%E7%90%86%E5%9B%BE%E7%89%87%E6%AE%B5%EF%BC%89%EF%BC%8C%E6%88%91%E5%8F%AF%E4%BB%A5%E5%B8%AE%E5%8A%A9%E8%BF%9B%E4%B8%80%E6%AD%A5%E6%8E%92%E9%99%A4%E6%95%85%E9%9A%9C%EF%BC%81%3C%2FP%3E%3CP%3E%E6%88%91%E5%BB%BA%E8%AE%AE%E9%80%9A%E8%BF%87%E6%B6%88%E6%81%AF%E5%BA%94%E7%94%A8%E7%A8%8B%E5%BA%8F%E8%81%94%E7%B3%BB%20%2B8526583%20(7594)%EF%BC%9B%E4%BB%8E%E4%BB%96%E9%82%A3%E9%87%8C%E8%8E%B7%E5%BE%97%20EOL%20%E6%96%87%E4%BB%B6%EF%BC%8C%E7%84%B6%E5%90%8E%E6%8F%90%E5%87%BA%E5%BB%BA%E8%AE%AE%E3%80%82%E4%BB%96%E8%83%BD%E5%B8%AE%E5%8A%A9%E4%BD%A0%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2298237%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20IMX8M%20PLUS%20LPDDR4%202G%20compatibility%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2298237%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E6%84%9F%E8%B0%A2%E4%BD%A0%E7%9A%84%E6%94%AF%E6%8C%81%3C%2FP%3E%3CP%3E%E5%9C%A8%E9%99%84%E4%BB%B6%E4%B8%AD%EF%BC%8C%E6%88%91%E5%90%91%E6%82%A8%E5%8F%91%E9%80%81%E4%BA%86%E9%85%8D%E7%BD%AE%E6%96%87%E4%BB%B6%20.xls%E5%92%8C%E6%B5%8B%E8%AF%95%E6%97%A5%E5%BF%97%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2298241%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20IMX8M%20PLUS%20LPDDR4%202G%20compatibility%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2298241%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9C%A8%E4%BA%8C%E6%89%8B%E6%9D%BF%E4%B8%8A%EF%BC%8C%E6%88%91%E4%BB%AC%E6%88%90%E5%8A%9F%E5%9C%B0%E5%9C%A8%202000MHz%20%E4%B8%8A%E8%BF%90%E8%A1%8C%E4%BA%86%203GB%EF%BC%88MT53E768M32D2ZW-046%20WTC%EF%BC%89%E5%92%8C%204GB%EF%BC%88MT53E1G32D2FW-046%20AAT%3A%20B%EF%BC%89%E7%BE%8E%E5%85%89%20LPDDR4%E3%80%82%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2298992%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20IMX8M%20PLUS%20LPDDR4%202G%20compatibility%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2298992%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F202673%22%20target%3D%22_blank%22%3E%40pengyong_zhang%3C%2FA%3E%E3%80%81%3C%2FP%3E%3CP%3E%E4%BD%BF%E7%94%A8%E9%85%8D%E7%BD%AE%E5%B7%A5%E5%85%B7%20V%2013.1%20%E6%97%B6%E7%BB%93%E6%9E%9C%E7%9B%B8%E5%90%8C%E3%80%82%E4%B9%9F%E8%AE%B8%E6%88%91%E4%BB%AC%E5%AF%B9%20IS43LQ32512A-046BLI%20%E7%9A%84%E9%85%8D%E7%BD%AE%E6%9C%89%E8%AF%AF%EF%BC%9F%E8%83%BD%E5%90%A6%E6%8F%90%E4%BE%9B%E6%AD%A3%E7%A1%AE%E7%9A%84%E9%85%8D%E7%BD%AE%EF%BC%88*.ds%20%E6%96%87%E4%BB%B6%EF%BC%89%EF%BC%9F%E6%88%91%E4%BB%AC%E7%9A%84%E7%A1%AC%E4%BB%B6%E8%AE%BE%E8%AE%A1%E6%98%AF%E5%85%B3%E4%BA%8E%20LPDDR4%20%E6%8E%A5%E5%8F%A3%E7%9A%84%E8%AF%84%E4%BC%B0%E6%9D%BF%E7%9A%84%201%3A1%20%E5%89%AF%E6%9C%AC%E3%80%82%3C%2FP%3E%3CP%3E%E6%AD%A4%E8%87%B4%3C%2FP%3E%3CP%3E%E6%89%98%E6%AF%94%E4%BA%9A%E6%96%AF%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2298680%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20IMX8M%20PLUS%20LPDDR4%202G%20compatibility%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2298680%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F253301%22%20target%3D%22_blank%22%3E%40TMpieye%3C%2FA%3E%3C%2FP%3E%0A%3CP%3E%E8%AF%B7%E4%BD%BF%E7%94%A8%E4%BB%A5%E4%B8%8B%E9%93%BE%E6%8E%A5%E4%B8%8B%E8%BD%BD%E6%88%91%E4%BB%AC%E7%9A%84%20DDR%20%E9%85%8D%E7%BD%AE%E5%B7%A5%E5%85%B7%EF%BC%8C%E7%84%B6%E5%90%8E%E4%BD%BF%E7%94%A8%20configure%202GB%20%E5%8A%A8%E6%80%81%E9%9A%8F%E6%9C%BA%E5%AD%98%E5%8F%96%E5%AD%98%E5%82%A8%E5%99%A8(DRAM)%20%E8%BF%90%E8%A1%8C%20ddr%20%E6%B5%8B%E8%AF%95%E3%80%82%3C%2FP%3E%0A%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fdesign%2Fdesign-center%2Fdevelopment-boards-and-designs%2Fi-mx-evaluation-and-development-boards%2Fconfig-tools-for-i-mx-applications-processors%3ACONFIG-TOOLS-IMX%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttps%3A%2F%2Fwww.nxp.com%2Fdesign%2Fdesign-center%2Fdevelopment-boards-and-designs%2Fi-mx-evaluation-and-development-boards%2Fconfig-tools-for-i-mx-applications-processors%3ACONFIG-TOOLS-IMX%3C%2FA%3E%3C%2FP%3E%0A%3CP%3EB.R%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2300091%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20IMX8M%20PLUS%20LPDDR4%202G%20compatibility%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2300091%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F253301%22%20target%3D%22_blank%22%3E%40TMpieye%3C%2FA%3E%3C%2FP%3E%0A%3CP%3E%E8%AF%B7%E4%BD%BF%E7%94%A8%E4%BB%A5%E4%B8%8B%E8%AE%BE%E7%BD%AE%E8%BF%90%E8%A1%8C%20DDR%20%E6%B5%8B%E8%AF%95%E3%80%82%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22pengyong_zhang_0-1769394027487.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pengyong_zhang_0-1769394027487.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pengyong_zhang_0-1769394027487.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pengyong_zhang_0-1769394027487.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pengyong_zhang_0-1769394027487.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pengyong_zhang_0-1769394027487.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pengyong_zhang_0-1769394027487.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pengyong_zhang_0-1769394027487.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F374164i2F91D2E3C3F636D6%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22pengyong_zhang_0-1769394027487.png%22%20alt%3D%22pengyong_zhang_0-1769394027487.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3Epengyong_zhang_0-1769394027487.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3EB.R%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2302969%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20IMX8M%20PLUS%20LPDDR4%202G%20compatibility%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2302969%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E6%84%9F%E8%B0%A2%E6%82%A8%E7%9A%84%E9%85%8D%E7%BD%AE%E7%A4%BA%E4%BE%8B%E3%80%82%E6%88%91%E5%B7%B2%E7%BB%8F%E7%94%A8%E8%BF%99%E4%B8%AA%E5%86%85%E5%AD%98%E8%AF%95%E8%BF%87%E4%BA%86%EF%BC%8C%E8%BF%98%E6%98%AF%E5%87%BA%E9%94%99%E3%80%82%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2303321%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20IMX8M%20PLUS%20LPDDR4%202G%20compatibility%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2303321%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F253301%22%20target%3D%22_blank%22%3E%40TMpieye%3C%2FA%3E%3C%2FP%3E%0A%3CP%3E%E7%9C%9F%E5%A5%87%E6%80%AA%E3%80%82%E8%AF%B7%E5%88%86%E4%BA%AB%E6%82%A8%E7%9A%84%20DDR%20%E9%85%8D%E7%BD%AE%E5%B7%A5%E5%85%B7%20v25.12%20%E6%95%85%E9%9A%9C%E6%97%A5%E5%BF%97%3C%2FP%3E%0A%3CP%3EB.R%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2315341%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20IMX8M%20PLUS%20LPDDR4%202G%20compatibility%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2315341%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F253301%22%20target%3D%22_blank%22%3E%40TMpieye%3C%2FA%3E%3C%2FP%3E%0A%3CP%3E%E6%82%A8%E4%BD%BF%E7%94%A8%E6%88%91%E4%BB%AC%E7%9A%84%20DDR%20%E9%85%8D%E7%BD%AE%E5%B7%A5%E5%85%B7%E8%BF%9B%E8%A1%8C%E5%8E%8B%E5%8A%9B%E6%B5%8B%E8%AF%95%E4%BA%86%E5%90%97%EF%BC%9F%E4%BB%8E%E4%BD%A0%E7%9A%84%E6%97%A5%E5%BF%97%E6%96%87%E4%BB%B6%E6%9D%A5%E7%9C%8B%EF%BC%8C%E9%85%8D%E7%BD%AE%E5%B7%A5%E5%85%B7%E7%9A%84%E8%BE%93%E5%87%BA%E7%BB%93%E6%9E%9C%E4%BC%BC%E4%B9%8E%E4%B8%8E%E4%B9%8B%E4%B8%8D%E7%AC%A6%E3%80%82%E5%90%8C%E6%97%B6%E4%BD%BF%E7%94%A8%E6%9C%80%E6%96%B0%E7%9A%84%E5%B7%A5%E5%85%B7%E7%89%88%E6%9C%AC%20v25.12%E3%80%82%3C%2FP%3E%0A%3CP%3EB.R%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2315308%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20IMX8M%20PLUS%20LPDDR4%202G%20compatibility%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2315308%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F202673%22%20target%3D%22_blank%22%3E%40pengyong_zhang%3C%2FA%3E%E3%80%81%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E8%BF%99%E6%98%AF%20Stresstest%20%E7%9A%84%E6%97%A5%E5%BF%97%E3%80%82%E6%88%91%E4%BB%AC%E7%9A%84%204GB%20ISSI%20IS43LQ32K01S2A-046BLI%20%E4%B9%9F%E9%81%87%E5%88%B0%E4%BA%86%E5%90%8C%E6%A0%B7%E7%9A%84%E9%97%AE%E9%A2%98%E3%80%82%20%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2315355%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20IMX8M%20PLUS%20LPDDR4%202G%20compatibility%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2315355%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3Ehi%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F202673%22%20target%3D%22_blank%22%3E%40pengyong_zhang%3C%2FA%3E%3C%2FP%3E%3CP%3E%E6%88%91%E4%BB%AC%E4%BD%BF%E7%94%A8%20Mscale%20DDR%20%E5%B7%A5%E5%85%B7%203.31%20%E8%BF%9B%E8%A1%8Cstresstest%E3%80%82%E6%88%91%E5%B0%86%E4%BD%BF%E7%94%A8%E5%85%B6%E4%BB%96%E9%85%8D%E7%BD%AE%E5%B7%A5%E5%85%B7%E8%BF%9B%E8%A1%8C%E9%85%8D%E7%BD%AE%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2317611%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20IMX8M%20PLUS%20LPDDR4%202G%20compatibility%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2317611%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F202673%22%20target%3D%22_blank%22%3E%40pengyong_zhang%3C%2FA%3E%E3%80%81%3C%2FP%3E%3CP%3E%E6%88%91%E5%9C%A8%E9%85%8D%E7%BD%AE%E5%B7%A5%E5%85%B7%E4%B8%AD%E8%BF%90%E8%A1%8C%E6%B5%8B%E8%AF%95%EF%BC%8C%E7%BB%93%E6%9E%9C%E9%80%9A%E8%BF%87%E4%BA%86%E3%80%82%E5%9B%A0%E6%AD%A4%EF%BC%8C%E8%BF%99%E4%BC%BC%E4%B9%8E%E6%98%AF%20MSCALER%20%E5%B7%A5%E5%85%B7%E7%9A%84%E9%97%AE%E9%A2%98%E3%80%82%E9%9D%9E%E5%B8%B8%E6%84%9F%E8%B0%A2%E4%BD%A0%E4%BB%AC%E7%9A%84%E5%A4%A7%E5%8A%9B%E6%94%AF%E6%8C%81%EF%BC%81%3C%2FP%3E%3C%2FLINGO-BODY%3E
