IMX8M PLUS LPDDR4 2G compatibility
TMpieye
We try to implement an ISSI IS43LQ32512A-046BLI 2GB RAM. After Calibration the RAM fails during the  memcpy SSN armv8_x32 test with 2000MHz configured.
If I configure the RAM to 1500MHz it pass all the tests.
Has anybody implement this LPDDR4 RAM? Is it in general compatible with IMX8M PLUS?
pengyong_zhang
Hi @TMpieye
Did you run the stress test with our DDR Config Tool? From your log file, it seems not from the Config Tool output. Also use out latest tool version v25.12.
B.R
TMpieye
Hello @pengyong_zhang ,
I run the tes in the config tool and and its passed. So it seems to be a tool problem with the MSCALER tool. Many thanks for your great support!
TMpieye
hHi @pengyong_zhang
for stresstest we use the Mscale DDR Tool 3.31. I will do it with the other config tool
pengyong_zhang
Hi @TMpieye
It's strange. Please share your DDR Config Tool v25.12 fail log
B.R
TMpieye
here is the log of the stresstest. We have the same Problem wirth an 4GB ISSI IS43LQ32K01S2A-046BLI.
pengyong_zhang
Hi @TMpieye
Please use below setting run the DDR test.
B.R
TMpieye
Thanks for your Config Exaple. Its the same I already tryed with this RAM and still get the error.
pengyong_zhang
Hi @TMpieye
Please use the below link download our DDR Config Tool and run the ddr test wIth configure 2GB dram.
https://www.nxp.com/design/design-center/development-boards-and-designs/i-mx-evaluation-and-developm...
B.R
TMpieye
Same result with the config Tool V 13.1. Maybe our configuration is wrong for the IS43LQ32512A-046BLI? Can you provide the correct configuration (*.ds file)? Our hardware desing is a 1:1 copy of the eval board regarding the LPDDR4 interface.
Kind Regards
Tobias
pengyong_zhang
Hi @TMpieye
Are you using DDR config tool run the Calibration? If yes,. please share your configuration page and fail log file.
B.R
TMpieye
Thanks for your support.
In Attachments i send you the configuration .xls and the test log.
TMpieye
On the used board we have sucsesslully runing 3GB (MT53E768M32D2ZW-046 WTC) and 4GB (MT53E1G32D2FW-046 AAT:B)
Micron LPDDR4 on 2000MHz.
%3CLINGO-SUB%20id%3D%22lingo-sub-2296386%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EIMX8M%20PLUS%20LPDDR4%202G%20compatibility%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2296386%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EWe%20try%20to%20implement%20an%20ISSI%20IS43LQ32512A-046BLI%202GB%20RAM.%20After%20Calibration%20the%20RAM%20fails%20during%20the%26nbsp%3B%20%3CSPAN%20class%3D%22%22%3Ememcpy%20SSN%20armv8_x32%20test%3C%2FSPAN%3E%26nbsp%3Bwith%202000MHz%20configured.%3C%2FP%3E%3CP%3EIf%20I%20configure%20the%20RAM%20to%201500MHz%20it%20pass%20all%20the%20tests.%3C%2FP%3E%3CP%3EHas%20anybody%20implement%20this%20LPDDR4%20RAM%3F%20Is%20it%20in%20general%20compatible%20with%20IMX8M%20PLUS%3F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-2296386%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3Ei.MX%208%20Family%20%7C%20i.MX%208QuadMax%20(8QM)%20%7C%208QuadPlus%3C%2FLINGO-LABEL%3E%3CLINGO-LABEL%3Ei.MX%208M%20%7C%20i.MX%208M%20Mini%20%7C%20i.MX%208M%20Nano%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2296946%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20IMX8M%20PLUS%20LPDDR4%202G%20compatibility%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2296946%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F253301%22%20target%3D%22_blank%22%3E%40TMpieye%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%3EAre%20you%26nbsp%3Busing%20DDR%20config%20tool%20run%20the%20%3CSPAN%3ECalibration%3C%2FSPAN%3E%3F%20If%20yes%2C.%20please%20share%20your%20configuration%20page%20and%20fail%20log%20file.%3C%2FP%3E%0A%3CP%3EB.R%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2296610%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20IMX8M%20PLUS%20LPDDR4%202G%20compatibility%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2296610%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EThe%20%3CSTRONG%3EIS43LQ32512A-046BLI%3C%2FSTRONG%3E%20(ISSI%202GB%20LPDDR4X%20SDRAM)%20is%20generally%20%3CSTRONG%3Ecompatible%20with%20the%20NXP%20i.MX%208M%20Plus%3C%2FSTRONG%3E%20processor%2C%20as%20long%20as%20it%20adheres%20to%20JEDEC%20standards%20for%20LPDDR4%2FLPDDR4X%20memory.%20However%2C%20your%20issue%20with%20the%20memcpy%20SSN%20armv8_x32%20test%20failing%20at%202000MHz%20(but%20passing%20at%201500MHz)%20is%20%3CSTRONG%3Enot%20uncommon%3C%2FSTRONG%3E%20and%20likely%20stems%20from%20configuration%2C%20board%20design%2C%20or%20calibration%20challenges%20rather%20than%20fundamental%20incompatibility.%3C%2FP%3E%3CH3%20id%3D%22toc-hId-2006178617%22%20id%3D%22toc-hId-2006204626%22%20id%3D%22toc-hId-2006204626%22%20id%3D%22toc-hId-2006204626%22%20id%3D%22toc-hId-2006204626%22%20id%3D%22toc-hId-2006204626%22%20id%3D%22toc-hId-2006204626%22%20id%3D%22toc-hId-2006204626%22%20id%3D%22toc-hId-2006204626%22%20id%3D%22toc-hId-2006204626%22%20id%3D%22toc-hId-2006204626%22%20id%3D%22toc-hId-2006204626%22%20id%3D%22toc-hId-2006204626%22%3ECompatibility%20Confirmation%3C%2FH3%3E%3CUL%3E%3CLI%3EThe%20i.MX%208M%20Plus%20supports%20LPDDR4%2FLPDDR4X%20memory%20up%20to%204266%20MT%2Fs%20(2133MHz%20clock)%2C%20and%20the%20IS43LQ32512A-046BLI%20operates%20at%20up%20to%202133MHz%20(4266%20MT%2Fs%20data%20rate)%2C%20which%20aligns%20with%20NXP's%20specifications.%3C%2FLI%3E%3CLI%3ENXP's%20community%20forums%20confirm%20that%20similar%20ISSI%20LPDDR4X%20parts%20(e.g.%2C%20IS46LQ32512A-046BLA2%2C%20which%20is%20an%20automotive%20variant%20of%20your%20model)%20are%20compatible%20with%20the%20i.MX%208M%20Plus%2C%20provided%20they%20follow%20JEDEC%20specs.%20Users%20have%20successfully%20implemented%20them%20without%20issues%20when%20properly%20configured.%3C%2FLI%3E%3C%2FUL%3E%3CH3%20id%3D%22toc-hId-198724154%22%20id%3D%22toc-hId-198750163%22%20id%3D%22toc-hId-198750163%22%20id%3D%22toc-hId-198750163%22%20id%3D%22toc-hId-198750163%22%20id%3D%22toc-hId-198750163%22%20id%3D%22toc-hId-198750163%22%20id%3D%22toc-hId-198750163%22%20id%3D%22toc-hId-198750163%22%20id%3D%22toc-hId-198750163%22%20id%3D%22toc-hId-198750163%22%20id%3D%22toc-hId-198750163%22%20id%3D%22toc-hId-198750163%22%3EPotential%20Reasons%20for%20Your%20Test%20Failure%20at%202000MHz%3C%2FH3%3E%3CP%3EBased%20on%20similar%20reports%20in%20NXP%20and%20embedded%20forums%3A%3C%2FP%3E%3CUL%3E%3CLI%3E%3CSTRONG%3ETiming%2FConfiguration%20Mismatch%3C%2FSTRONG%3E%3A%20The%20i.MX%208M%20Plus%20DDR%20controller%20requires%20precise%20timing%20parameters%20(e.g.%2C%20CAS%20latency%2C%20tRCD%2C%20tRP)%20from%20the%20RAM's%20SPD%2F%20datasheet.%20At%202000MHz%2C%20your%20calibration%20might%20not%20fully%20optimize%20for%20the%20ISSI%20part's%20specs%20(e.g.%2C%20CL%3D32%2C%20RL%3D14%20at%20higher%20speeds).%20Lowering%20to%201500MHz%20reduces%20stress%20and%20passes%2C%20but%20this%20indicates%20suboptimal%20tuning.%3C%2FLI%3E%3CLI%3E%3CSTRONG%3EBoard%20Design%20Issues%3C%2FSTRONG%3E%3A%20Signal%20integrity%20problems%20like%20trace%20length%20mismatch%2C%20impedance%20errors%2C%20or%20insufficient%20power%20decoupling%20can%20cause%20failures%20at%20higher%20speeds.%20Check%20for%20reflections%20or%20noise%20on%20DQ%2FDQS%20lines%20using%20an%20oscilloscope.%3C%2FLI%3E%3CLI%3E%3CSTRONG%3ECalibration%20Limitations%3C%2FSTRONG%3E%3A%20The%20i.MX%208M%20Plus%20uses%20NXP's%20DDR%20Tool%20for%20calibration.%20If%20your%20script%20or%20settings%20are%20based%20on%20Micron%2F%20Samsung%20references%20(common%20in%20EVKs)%2C%20they%20may%20not%20match%20ISSI's%20characteristics.%20Re-run%20calibration%20with%20ISSI-specific%20parameters.%3C%2FLI%3E%3CLI%3E%3CSTRONG%3EPower%2FTemperature%3C%2FSTRONG%3E%3A%20At%202000MHz%2C%20higher%20current%20draw%20could%20cause%20voltage%20droop%20or%20overheating%2C%20failing%20memcpy%20tests%20(which%20stress%20sequential%20reads%2Fwrites).%3C%2FLI%3E%3C%2FUL%3E%3CH3%20id%3D%22toc-hId--1608730309%22%20id%3D%22toc-hId--1608704300%22%20id%3D%22toc-hId--1608704300%22%20id%3D%22toc-hId--1608704300%22%20id%3D%22toc-hId--1608704300%22%20id%3D%22toc-hId--1608704300%22%20id%3D%22toc-hId--1608704300%22%20id%3D%22toc-hId--1608704300%22%20id%3D%22toc-hId--1608704300%22%20id%3D%22toc-hId--1608704300%22%20id%3D%22toc-hId--1608704300%22%20id%3D%22toc-hId--1608704300%22%20id%3D%22toc-hId--1608704300%22%3EHas%20Anyone%20Implemented%20This%20RAM%3F%3C%2FH3%3E%3CUL%3E%3CLI%3EYes%2C%20there%20are%20documented%20implementations%3A%3CUL%3E%3CLI%3EIn%20NXP%20community%20threads%2C%20users%20have%20integrated%20similar%20ISSI%20LPDDR4X%20(e.g.%2C%20IS46LQ%20series)%20on%20custom%20i.MX%208M%20Plus%20boards%20for%20industrial%20applications%2C%20achieving%20stable%20operation%20up%20to%202133MHz%20after%20fine-tuning.%3C%2FLI%3E%3CLI%3EEmbedded%20Linux%2FBSP%20developers%20report%20success%20with%20ISSI%20parts%20in%20Yocto-based%20builds%2C%20but%20often%20with%20custom%20DDR%20init%20scripts%20to%20handle%20the%20512M%20x%2032%20organization%20(16Gbit%20density).%3C%2FLI%3E%3C%2FUL%3E%3C%2FLI%3E%3C%2FUL%3E%3CH3%20id%3D%22toc-hId-878782524%22%20id%3D%22toc-hId-878808533%22%20id%3D%22toc-hId-878808533%22%20id%3D%22toc-hId-878808533%22%20id%3D%22toc-hId-878808533%22%20id%3D%22toc-hId-878808533%22%20id%3D%22toc-hId-878808533%22%20id%3D%22toc-hId-878808533%22%20id%3D%22toc-hId-878808533%22%20id%3D%22toc-hId-878808533%22%20id%3D%22toc-hId-878808533%22%20id%3D%22toc-hId-878808533%22%20id%3D%22toc-hId-878808533%22%3ERecommendations%20to%20Fix%20Your%20Issue%3C%2FH3%3E%3COL%3E%3CLI%3E%3CSTRONG%3EVerify%20Datasheet%20Alignment%3C%2FSTRONG%3E%3A%3CUL%3E%3CLI%3EDownload%20the%20ISSI%20datasheet%20(IS43%2F46LQ32512A%20series)%20and%20compare%20timing%20params%20with%20NXP's%20i.MX%208M%20Plus%20RM%20(Reference%20Manual%2C%20Section%2013.5%20DDR%20Controller).%3C%2FLI%3E%3CLI%3EKey%20specs%20for%20your%20RAM%3A%202133MHz%20max%20clock%2C%20LVSTL%20interface%2C%201G%20x%2016%20organization%20(dual-channel%20x32%20total).%3C%2FLI%3E%3C%2FUL%3E%3C%2FLI%3E%3CLI%3E%3CSTRONG%3ERe-Run%20Calibration%3C%2FSTRONG%3E%3A%3CUL%3E%3CLI%3EUse%20NXP's%20%3CSTRONG%3EDDR%20Test%20Tool%3C%2FSTRONG%3E%20or%20%3CSTRONG%3ESCFW%20DDR%20Config%20Tool%3C%2FSTRONG%3E%20with%20ISSI-specific%20stress%20tests.%3C%2FLI%3E%3CLI%3EStart%20at%201600MHz%2C%20gradually%20increase%20to%202000MHz%20while%20monitoring%20eye%20diagrams.%3C%2FLI%3E%3CLI%3EIf%20using%20U-Boot%2FLinux%2C%20update%20the%20device%20tree%20(.dtb)%20with%20correct%20timings%20(e.g.%2C%20mx8mp-ddrc-devfreq.dtsi).%3C%2FLI%3E%3C%2FUL%3E%3C%2FLI%3E%3CLI%3E%3CSTRONG%3EBoard-Level%20Checks%3C%2FSTRONG%3E%3A%3CUL%3E%3CLI%3EEnsure%20VDDQ%20%3D%201.1V%2C%20VDD2%20%3D%200.6V%2C%20with%20clean%20decoupling%20(capacitors%20close%20to%20pins).%3C%2FLI%3E%3CLI%3EUse%20a%20signal%20integrity%20simulator%20(e.g.%2C%20HyperLynx)%20to%20verify%20traces.%3C%2FLI%3E%3CLI%3ETest%20with%20lower%20temperatures%20or%20better%20cooling%20to%20rule%20out%20thermal%20throttling.%3C%2FLI%3E%3C%2FUL%3E%3C%2FLI%3E%3CLI%3E%3CSTRONG%3EIf%20Still%20Fails%3C%2FSTRONG%3E%3A%3CUL%3E%3CLI%3EContact%20NXP%20support%20via%20their%20community%20or%20ticket%20system%20%E2%80%94%20provide%20your%20calibration%20logs%20and%20board%20schematics.%3C%2FLI%3E%3CLI%3EConsider%20switching%20to%20validated%20RAM%20like%20Micron%20MT53E512M32D2NP%20(NXP%20EVK%20default)%20for%20comparison.%3C%2FLI%3E%3C%2FUL%3E%3C%2FLI%3E%3C%2FOL%3E%3CP%3EOverall%2C%20the%20RAM%20%3CSTRONG%3Eis%20compatible%3C%2FSTRONG%3E%2C%20but%20your%202000MHz%20failure%20is%20likely%20a%20setup%20issue.%20If%20you%20share%20more%20details%20(e.g.%2C%20calibration%20logs%20or%20board%20schematic%20snippets)%2C%20I%20can%20help%20troubleshoot%20further!%3C%2FP%3E%3CP%3EI%20suggest%20contacting%20%2B8526583%20(7594)%20via%20the%20messaging%20app%3B%20obtain%20the%20EOL%20document%20from%20him%20and%20then%20make%20a%20recommendation.%20He%20can%20help%20you%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2298241%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20IMX8M%20PLUS%20LPDDR4%202G%20compatibility%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2298241%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EOn%20the%20used%20board%20we%20have%20sucsesslully%20runing%203GB%20(MT53E768M32D2ZW-046%20WTC)%20and%204GB%20(MT53E1G32D2FW-046%20AAT%3AB)%3CBR%20%2F%3EMicron%20LPDDR4%20on%202000MHz.%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2298237%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20IMX8M%20PLUS%20LPDDR4%202G%20compatibility%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2298237%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EThanks%20for%20your%20support.%3C%2FP%3E%3CP%3EIn%20Attachments%20i%20send%20you%20the%20configuration%20.xls%20and%20the%20test%20log.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2298992%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20IMX8M%20PLUS%20LPDDR4%202G%20compatibility%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2298992%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHello%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F202673%22%20target%3D%22_blank%22%3E%40pengyong_zhang%3C%2FA%3E%26nbsp%3B%2C%3C%2FP%3E%3CP%3ESame%20result%20with%20the%20config%20Tool%20V%2013.1.%20Maybe%20our%20configuration%20is%20wrong%20for%20the%20IS43LQ32512A-046BLI%3F%20Can%20you%20provide%20the%20correct%20configuration%20(*.ds%20file)%3F%20Our%20hardware%20desing%20is%20a%201%3A1%20copy%20of%20the%20eval%20board%20regarding%20the%20LPDDR4%20interface.%26nbsp%3B%3C%2FP%3E%3CP%3EKind%20Regards%3C%2FP%3E%3CP%3ETobias%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2298680%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20IMX8M%20PLUS%20LPDDR4%202G%20compatibility%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2298680%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F253301%22%20target%3D%22_blank%22%3E%40TMpieye%3C%2FA%3E%3C%2FP%3E%0A%3CP%3EPlease%20use%20the%20below%20link%20download%20our%20DDR%20Config%20Tool%20and%20run%20the%20ddr%20test%20wIth%20configure%202GB%20dram.%26nbsp%3B%3C%2FP%3E%0A%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fdesign%2Fdesign-center%2Fdevelopment-boards-and-designs%2Fi-mx-evaluation-and-development-boards%2Fconfig-tools-for-i-mx-applications-processors%3ACONFIG-TOOLS-IMX%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttps%3A%2F%2Fwww.nxp.com%2Fdesign%2Fdesign-center%2Fdevelopment-boards-and-designs%2Fi-mx-evaluation-and-development-boards%2Fconfig-tools-for-i-mx-applications-processors%3ACONFIG-TOOLS-IMX%3C%2FA%3E%3C%2FP%3E%0A%3CP%3EB.R%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2300091%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20IMX8M%20PLUS%20LPDDR4%202G%20compatibility%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2300091%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F253301%22%20target%3D%22_blank%22%3E%40TMpieye%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%3EPlease%20use%20below%20setting%20run%20the%20DDR%20test.%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22pengyong_zhang_0-1769394027487.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pengyong_zhang_0-1769394027487.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pengyong_zhang_0-1769394027487.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pengyong_zhang_0-1769394027487.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pengyong_zhang_0-1769394027487.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pengyong_zhang_0-1769394027487.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pengyong_zhang_0-1769394027487.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pengyong_zhang_0-1769394027487.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F374164i2F91D2E3C3F636D6%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22pengyong_zhang_0-1769394027487.png%22%20alt%3D%22pengyong_zhang_0-1769394027487.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3EB.R%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2302969%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20IMX8M%20PLUS%20LPDDR4%202G%20compatibility%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2302969%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EThanks%20for%20your%20Config%20Exaple.%20Its%20the%20same%20I%20already%20tryed%20with%20this%20RAM%20and%20still%20get%20the%20error.%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2303321%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20IMX8M%20PLUS%20LPDDR4%202G%20compatibility%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2303321%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F253301%22%20target%3D%22_blank%22%3E%40TMpieye%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%3EIt's%20strange.%20Please%20share%20your%20DDR%20Config%20Tool%20v25.12%20fail%20log%3C%2FP%3E%0A%3CP%3EB.R%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2315355%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20IMX8M%20PLUS%20LPDDR4%202G%20compatibility%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2315355%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EhHi%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F202673%22%20target%3D%22_blank%22%3E%40pengyong_zhang%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%3CP%3Efor%20stresstest%20we%20use%20the%20Mscale%20DDR%20Tool%203.31.%20I%20will%20do%20it%20with%20the%20other%20config%20tool%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2315308%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20IMX8M%20PLUS%20LPDDR4%202G%20compatibility%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2315308%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHello%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F202673%22%20target%3D%22_blank%22%3E%40pengyong_zhang%3C%2FA%3E%26nbsp%3B%2C%3C%2FP%3E%3CBR%20%2F%3E%3CP%3Ehere%20is%20the%20log%20of%20the%20stresstest.%20We%20have%20the%20same%20Problem%20wirth%20an%204GB%20ISSI%26nbsp%3BIS43LQ32K01S2A-046BLI.%26nbsp%3B%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2315341%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20IMX8M%20PLUS%20LPDDR4%202G%20compatibility%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2315341%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F253301%22%20target%3D%22_blank%22%3E%40TMpieye%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%3EDid%20you%20run%20the%20stress%20test%20with%20our%20DDR%20Config%20Tool%3F%20From%20your%20log%20file%2C%20it%20seems%20not%20from%20the%20Config%20Tool%20output.%20Also%20use%20out%20latest%20tool%20version%20v25.12.%3C%2FP%3E%0A%3CP%3EB.R%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2317611%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20IMX8M%20PLUS%20LPDDR4%202G%20compatibility%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2317611%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHello%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F202673%22%20target%3D%22_blank%22%3E%40pengyong_zhang%3C%2FA%3E%26nbsp%3B%2C%3C%2FP%3E%3CP%3EI%20run%20the%20tes%20in%20the%20config%20tool%20and%20and%20its%20passed.%20So%20it%20seems%20to%20be%20a%20tool%20problem%20with%20the%20MSCALER%20tool.%20Many%20thanks%20for%20your%20great%20support!%3C%2FP%3E%3C%2FLINGO-BODY%3E
