IMX8M Mini input transition time on GPIO
1,349件の閲覧回数
Sylvain_B
I haven't found any specification for the transition time of GPIO inputs when CMOS input is selected with registers (Hysteresis Enable field bit disable).
Where can I find it?
Regards.
2 返答(返信)
1,322件の閲覧回数
Manuel_Salas
Hello @Sylvain_B
I hope you are doing well.
Unfortunately we have not documented your exact requirement but you can take a look to the AN5078 (Influence of Pin Setting on System Function and Performance).
Salas.
1,308件の閲覧回数
Sylvain_B
Thanks your for your reply.
On the oscillograms, the horizontal scale  ((??ns/div) is not visible. and this is not mentioned in the explanations. It's a pity, because if I'd been able to read it, I'd have been able to evaluate the input transition time.
