IMX8M Mini EVK step by step flashing
3,453件の閲覧回数
VinithNama
Hi sir,
       I have build my kernel in standalone environment then it generates image file in arch/arm64/boot
in the similar manner i build u-boot in the standalone environment it generates flash.bin file.
Now, how can i flash each individual image like rootfs, dtb,Image and flash.bin to sdcard.
There is any script for converting these four files to .wic file or any different procedure for dumping the images into sdcard.
3,443件の閲覧回数
AldoG
You can actually flash your SD/eMMC with the files you have as they are, you may refer to the Linux Users Guide attached for this, section 4.3 Preparing an SD/MMC card to boot, just skip section 4.3.2
Aldo.
